Question about Alpine CDM-9821 CD Player
Changed battery cable now radio will not even come on.
After changing battery cable radio will not even come on. I have checked the 50 amp fuse under hood the amp fuse and the in line fuse from radio and fuse box all good. Is there a code or something wrong with amp. This is driving me nuts I can't get power to unit. Please help
  • geeper415 Jan 14, 2009
    The 50 amp fuse was for booster amp. not for radio
    Sergeant:
  • 227 Answers
When you said inline fuse I get the idea that this is not the original radio. Do you have power on the inline fuse? The 50 amp fuse you checked is a bit much for a radio. There may be a smaller fuse in another fuse area of what car type you have. If you do not have power at the inline fuse find some where you do have power (12vdc) and connect to it. If you have power at the in line fuse check the ground wire. If you have a test light or someway of checking for power test all fuses everywhere. If you have a fuse location guide for this vehicle look for the fuse for radio. If it was a add on or after market radio they probably caught power from the original source That is fused under the dash.
Posted on Jan 14, 2009
  • 1 more comment
  • Mike Schmidt
    Mike Schmidt Jan 14, 2009
  • Mike Schmidt
  • Mike Schmidt
    That explains the 50amp fuse. Did you check to see if voltage was actually getting to the amp from the fuse? And is there power getting to the fuse holder? If yes to both then you have lost your ground. I misunderstood that there was no power to the radio or the radio does not come on. Did you change both cables or just the positive? Please advise
Radio Dead and already changed fuses that were not blown
Yes and fuses are tricky some don't look blown and they r, and some look blown and r not But to check the radio itself put a volt meter to the wiring connection on back of unit
Jan 02, 2014 | 2003 Chevrolet Silverado 1500
My battery is every morning empty. Changed the dynamo, battery, steering contact. After removing the fuse of the radio / amplifier, battery keeps on level. Unplugging amplifier with fuse in results in low...
Have battery/alternator checked. Really clean connectors and battery posts even if they look ok. If battery is ok have it slowly recharged for 12-24 hrs. Alternators are not designed to recharged an empty battery but just to maintain the full charge. I large amp and sound system demands a big battery and heavy duty alternator.
Aug 04, 2013 | Cars & Trucks
My battery die and i changed for another one but my radio does't work since that day not even appears the code on dash!!2005 acura tl
Check fuses and connections. Probably loose connection when battery replaced. Do you have a radio code that must be entered. Go to Auto Zone and they will check codes for free. If you have an add on amp check for connection to +and grounds and blown fuses
Aug 01, 2013 | Car Audio & Video
Car wont turn over good battery no radio no nothing I have a 2008
look under hood remove cover for relays and fuses , should be a main fuse link where pos cable from battery and a ground come together with a fusible link in between it might need replacing
Jan 15, 2011 | 2005 Chrysler 300
Radio problems
Check the radio fuse to see if it was blown when you changed the battery. there is no rest for a radio that I am aware of for this situation.
Sep 09, 2009 | 2006 Jeep Grand Cherokee
2005 Honda Odyssey does not start (no lights, no sound)
It sounds like you have either a Bad Alternator or a loose Belt or even a loose Battery Connection. The radio will only do this when the Battery is bad or has been changed out. Check the Belt Tension and the Battery Terminals for tightness. If the Belt is even a Little loose it will not allow the Alternator Charge the Battery. The code for the Radio will have to be gotten from the Local Dealership. Call and ask for Parts. The Parts Desk will be able to give you the code by Looking up your VIN Number.
Jan 24, 2009 | 2005 Honda Odyssey
Radio and all dome lights are not working.
interior fuse should be the culprit. Look for the Radio fuse inside (normally 10A red) sometimes labeled CABIN on the fuse layout
Dec 25, 2008 | 1999 Toyota RAV4
Alpine CDM-9821 CD Player Logo
401 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
