Question about Canon B210C Plain Paper Bubblejet Fax
Fax machine I get a #336# error message when I insert the new cartridge.
  • Anonymous Nov 20, 2008
    #336
  • Anonymous Feb 28, 2009
    I have the same problem. An authorized canon shop repaired my printer they change the cartridge and cost more than a $100 and after a few months back again to the same problem check printer ##336
  • 186 Answers
Try unpluging the machine and let it cool for a while, also you may have a defective cartridge.
Posted on Jun 22, 2007
Install Cartridge Message
You could have a bad cartridge and the printer is not reading the chip, causing this error. Best way to check is try a new cartridge.
Jun 19, 2017 | HEWLETT-PACKARD HP 2140 Fax
I have error 1200 on my lexmark x4270 fax machine after installing new black cartridge.
The 1200 error code indicates that the cartridge carrier has stalled. It could be due to the new black cartridge installed in the printer. Make sure you are using the correct version of black cartridge for your model and it's properly inserted in the cartridge carrier.
To remedy the problem, try to remove the black cartridge from the carrier > close the cover > unplug and re-plug the printer into the power source to reset it > when the printer turns on, re-insert the new black cartridge > check for any errors. If problem continues, try to insert a different known working black cartridge to determine if the new one is faulty.
For further troubleshooting, you may also refer to this article found in the Lexmark website: 1200 Error Message on a Lexmark X4250/X4270/F4270 All-In-One.
Jul 12, 2011 | Lexmark X4270 All-In-One InkJet Printer
Toshiba e studio 170f error message, toner not recognized
maybe the roner cartridge you inserted is not supported by Toshiba e-Studio 170f. This may be one of the reasons that the machine can't recognize the toner cartridge.
Reinstall the toner cartridge that you have. If that doesn't fix the issue try to replace the toner cartridge with new one.
If you continue experiencing this issue contact your technical support team.
Jun 19, 2011 | Toshiba EStudio 170f Fax 170f
My HP M1319f fax machine diplays a "No Print Cartridge" error.
I have checked for paper jam, remove the paper and cartridge was recognized.
Mar 02, 2010 | HP Laserjet M1319F Laser Multifunction...
Get an error message that says "Cartridge Error."
It could be an indication that it's reading the cartridge incorrectly or the cartridge isn't properly seated. Try re-inserting the old cartridge or a new one to correct your problem.
Jun 17, 2009 | Office Equipment & Supplies
We purchased a new cartridge because it said install new ink cartridge,we installed new cartridge it still says install new ink cartridge and will not receive or send faxes
it will not send or receive a fax if the error is still there. Clear the error by trying these steps:
-open cartridge door and remove the cartridge
-unplug the power cord at the back of printer
-after 30 seconds, plug the cord and turn on the printer. It will ask for the cartridge.
-Open the cartridge door and insert the cartridge
-close the access door
-if the error is cleared, try faxing again.
I hope this helps.
Regards,
Mar 02, 2009 | HP 640 Inkjet Fax Machine
Printer error on sharp ux-b700 new cartridge?
Try to reinstall the cartridge and press NEW, then go through alignment process.
Dec 08, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Samung Sf-330 fax.
probably you did not fix properly the ink cartridge.check the cartridge for proper seating.
Jun 02, 2008 | Samsung SF-330 Plain Paper Inkjet Fax
Nothing there
Did you try cleaning the print cartridge nozzles.
Press Function once and up arrow 2 times
Press the right arrow once and the up arrow once
Press Start/Memory button
It will print a test parttern page
Once you insert the new cartridge did the machine recognize the new cartridge? You had to press 1 for new
When 1 is selected you will get a prompt New Cart: OK?
OK press start.
If you selected NEW the display will show the alternating messages at right. Align Cartridge----1 Print 2 Set
Press 1 to print an alignment page
Hopefully, it will printed. Let me know one way or the other.
Mar 27, 2008 | Sharp INKJET FAX UX-A1000
Error #1203
Error #1203
A 1203 error message on the operator panel could indicate a problem with one of the ink cartridges. Please carry out the steps below the image to confirm that this is a cartridge failure rather than a hardware problem
  1. Make sure the All-In-One is powered on.
  2. Pull the control panel towards you, and then open the cartridge access door. The print cartridge carrier moves and stops at the loading position.
  3. Pull the old cartridges towards you, and then lift them out.
  4. With the cartridges out of the printer, shut the access door and the control panel.
  5. Power the printer OFF and then back ON.
  6. Check the operator panel to see if the same error has returned or if a new message has appeared.
  7. If the message displayed is 1203, there is something wrong with the printer hardware.
    If the message now displaying is Cartridge Missing, do the following:
    1. Reinstall the cartridges into the printer.
    2. Insert the color cartridge in the left carrier. Insert the black cartridge in the right carrier.
    3. Push back firmly on the cartridges until they snap securely into place.
    4. Close the cartridge access door, and then close the control panel.
    5. If the 1203 message is still present on the operator panel, you need to insert one cartridge at a time to determine which cartridge is producing the failure.
    6. With one cartridge in the carrier, close the access door and control panel.
    7. Check the operator panel. If the 1203 error is displayed, this cartridge is the defective item.
      If the Cartridge Missing message is displayed, the second cartridge is producing the failure.
    8. Please replace the defective cartridge.
Mar 03, 2008 | Lexmark F4270 Plain Paper Inkjet Fax
Canon B210C Plain Paper Bubblejet Fax Logo
57 people viewed this question
old marine
old marine
