Question about Kenmore 44072 Front Load Washer
Kenmore Elite HE4T Front Load Washer
Hi. I have a front load washer by Kenmore and cannot find my manual. I have tried since yesterday to wash a load of laundry and when it gets to the spin cycle, I keep getting a flashing message "F 02". I looked on line last night to see if I could find info on it and I saw something about a balancing problem. I added more clothes to try to fix the problem and started over again. It didn't fix it so I took all of the clothes out and there was some water in the bottom of the tub so I pressed "drain and spin". Again, I got the same error message. What could be the problem and how do I fix it? Please help asap, my son has a prom tonight and I need to clean his clothes. Thanks!
  • Melody Niblett Jun 12, 2007
    Hey!
    I called everyone that I knew, including Sears to find out the problem and it all kept coming back to the drainage hose either being kinked or clogged. Since I cannot get to the entire hose, except for the piece in the drain, I pulled it out as far as I could and put it back into the drain. It still did not work. So, I also remembered another website that said it may be the door. I opened the door and pulled it up when I closed it and it worked!!! The machine works now...for now.
    Hope this helps whoever needs it.
    President:
  • 1,294 Answers
These machines have a filter you should clean depending on your usage. It is usually at the front bottom - a small door. This is a filter before the water gets to your outlet pump to be siphoned out; it is there in order not to clog up your pump.
Posted on Jun 13, 2007
I want a manual for My Kenmore HE4T Front Load Washer
This site has lots of manuals. http://www.manualslib.com/products/Kenmore-He4t-110-4508-3024385.html#.VPmnI5cyiQE.mailto
Feb 14, 2014 | Kenmore HE4t 3.8 Cu. Ft. King Size...
My Kenmore Elite He4t front load washer is making a terrible noise when it starts spinning the clothes. What could be wrong?
Sounds like the rear bearing. If you hear the noise when you manually spin the drum or if the drum has any movement when you lift up on it then you need major repairs
Feb 27, 2011 | Kenmore Elite 45986 Front Load Washer
I need a manual for Kenmore Elite HE4t front load washer. Most of the programs written at the front were erased already I want to put back all the programs. Sometimes I select the wrong program.
If you go to the following Sears site, click on "Manuals" and enter your model number, you should be able to get a PDF version of the manual.
http://www.managemyhome.com/
Apr 24, 2010 | Kenmore Elite 45986 Front Load Washer
Stop frequently on spin and rinse cycle F6 code
I have a Kenmore Elite he4t front load washer that was working fine and then we moved and now it stops washing midstream and flashes an F and a H. I have to pause and restart then it will stop washing again after a few minutes and flash the same codes again. I reset again and then it stops with 1 minute left and will not drain.
Apr 06, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE4t washer won't spin
The motor controller board is likely bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 06, 2009 | Kenmore Elite 45986 Front Load Washer
F Code for the Kenmore Elite he4t Front Load Washer (3 years old)
Hi! ricksmith
What is the first three digits of the model number.
The he4t I have reference to does not have a "F" code error. Most of the codes are two digit, PF, F1 to F9 etc.
You could try: Pressing Pause/Cancel two times to clear code. As well as unplug for 20 seconds. Do you have power fluctuations in your area.
InMrFixIt
Aug 27, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Sedona Elite 3.8 Cubic Foot HE4t Washer (Front-Loading) 45089
open lower front with a starshaped bit(screwdriver) three small screws, to get to white plastic cleanout (easy to turn by hand)may have someting stuck in it. about a gallon of water is there so have two big towels ready to soak it up.
Dec 28, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore 44072 Front Load Washer Logo
162 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
