Question about Insignia IS-LCDTV32 32 in. Television
Television is working but the screen
My television model number is NS-15LCD
The televisin comes on and then the screen goes to black. I do have audio with the channel of choice through cable, and a faint picture is available, but there is a black sreen.What can I do to solve this problem? Do I have to take the television to a TV repair shop? I do have the remote but I have to get directly upon the TV to see the options on the menu bar. Please advise. I do think this problem is minir dueb to the fact that there is a slight picture available
  • roach_wong Jan 21, 2009
    I have the exact same problem with Insignia NS-LCD15N television as well. Just seemed to start. not sure if it matters but my location switched over to Digital broadcasting on Jan 15, 2009 however I'm using a coaxal cable feed into my NS-LCD15N. The light in the back doesn't go dead because when it happen, the screen still illuminates light from the screen just don't get any color or menu options. If I take the power out from the back and let it go dead for a bit and plug it back in, the picture came back but then suddenly went black again. Left it off overnight and started it back on this morning and no problem. Will monitor the problem more.
  • 54 Answers
Most likely the power supply has gone bad. in lcd tv's there are lights behind the screen that illuminate the picture so you can see it. if the power supply doesn't supply the voltage to light these up you won't be able to see it. try mcmelectronics.com for parts. if the power supply doesn't fix this problem your lcd panel will need to be replaced.......too expensive as it costs more than the tv did when you bought it. good luck
Posted on Jan 16, 2009
Emerson flat screen tv, 32 inch, model number LC320EM2F, will not come on
does the digital television come up on the screen for a second then it goes black? If so its usually the inverter which has the issue.
Apr 04, 2013 | Emerson Televison & Video
Does an insignia ns 15lcd have an internal voltage regulator?
All sets have one in some form or another to compensate for changes (WITHIN REASON) in line voltage coming into the set.
May 24, 2012 | Televison & Video
I have the Sony KDF E50A10 TV and it appears that there is color of shadow blue and some inprint burnt into the bottomof the screen. How can I fix this?
The problem is from the lamp of the televisin, it is devloping some fault, therefore it will start to malfunction gradually till it goes completely bad.
The solution to that is for you to open up the television and try to assess the lamp. some of these televisions come with three lamps to you assess the three, while others come with just one, once you assess the lamp and find it faulty, all you need to do is to apply some force to pull it out, and if it is screwed to the board, unscrew it and replace it with a new one.
After doing this, you would be able to enjoy your television once again. Also do not open up the television unless it is unplugged.
Take care and good luck
Oct 25, 2010 | Sony KDF-E50A10 50 in. LCD HDTV
Screen will begin turning blue, then go black and standby timer light blinks 8x in sequence. I can repower and screen will come back on temporarily. Tv may work for days then suddenly start doing again....
hello ,Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
shaun
Nov 10, 2009 | Sony KP-51WS500 51" Rear Projection...
I have a ns-15lcd and it won't turn on. I tried putting it a different outlet and nothing. When you put the ac adapter plug into the tv the red light comes on and then goes out. Any suggestions? Thanks,...
usuallly it is the adaptor that is bad yes with a load the adaptor will
produce the correct voltage but there is a capacitor that has gone south try to find a universal supply at Bestbuy with the same voltage and current output
Sep 24, 2009 | Insignia Televison & Video
Large black box appears in center of screen with date and other numbers on it. Push any button and it goes away for short time
You can try resetting the television controls by unplugging the television from the power source for a few hours. This means physically removing the power plug form the source of power. This may allow the controls to reset out of the latching position they are in now. If this does not help, you are having a problem with the main board.This board is master control for all the televisions functions,like audio, video and switching controls. You can call the Insignia customer support at this telephone number. 1-877-467-4289. Give them the model number of your television and ask them how you can find service for it. You can also use the customer support website. www.insignia-products.com. go to the customer support section and ask them for help with your problem. I hope this information helps you with your problem.
May 24, 2009 | Insignia IS-LCDTV32 32 in. Television
Sony TV picture goes blank but I still have audio
BAD SOLDER JOINTS IN HORIZONAL CIRCUIT ON DRIVER TRANSFORMER
Apr 11, 2009 | Televison & Video
Large black square appears on screen of my Insignia NS-15LCD TV.
Look for the closed captioning (CC) menu in the set up and turn CC off.
Feb 25, 2009 | Televison & Video
Line in the middle of screen
You have a bad component in the vertical circuit of your set. If you hit it on the back of the cabinet with your hand which will "jar it" and the picture flashes back on then you have loose connection. If nothing happens then the vertical circuit has a bad component most likely the Output IC. (Chip) Stargazer
Mar 27, 2007 | SansuiS2001 20" TV
Insignia IS-LCDTV32 32 in. Television Logo
139 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
