Question about Toshiba 32A33 32" TV
Sound why is it that my tv sound on high is very low but on one channel it is high or if we run a dvd player for movie it is very high volume
  • nyyaup Jan 14, 2009
    have done that still the same with the tv
  • 4,234 Answers
This may sound silly, but check to verify that you have not turned on the SAP feature for your set. If that is not the case, a few more details are needed here:
1) Are you using cable or overair?
2) Is the DVD connected to Video input using the red/white/yellow?
Thanks,
Dan
Posted on Jan 14, 2009
    Champion:
  • 240 Answers
I would do away with the vhs cabl and only run rca composit .
then see how things are working sumtimes when looping vcr's and cd'
you can hook up too manny conections and cause audio loss
I have an audiosonic KM3608N DVD player and an LG TV. I have perfect sound when watching TV but seemed to have pressed something on either TV or DVD remote that has caused the DVD player to play at...
Please go to audio output menu on your DVD screen check them and when on the DVD channel check your audio input menu. You could have turned on the volume limit on your DVD settings menu
Nov 02, 2017 | Car Audio & Video
Very weak sound on television from dvd. player recently bought. It is a Silvercest KH 6524 player and some official dvd discs.. Even using maximum volume of my t.v. , a flatscreen Samsung and my...
Some brand name of the DVD player.Some brand name DVD player,u must used it own DVD player remote to turn on the volume higer or lower to get it up or lower on the movie DVD discs or any kind of DVD discs are playing.The tv dosen't control the output volume of the movie,if the function require the DVD player remote to do it.Check ur DVD player remote see if u have a volume control buttons + - used those buttons on the DVD remote control u will control the volume of the movie DVD disc it is playing on the DVD player.
Aug 09, 2011 | Televison & Video
My Polaroid 1911 TXLB 19in television is not working properly. The volume is very very very low. We have a DVD player hook up to it and its been working fine. Last nite was working, shut it off and today...
check the Sounds with Local TV channels.Is it still low?If it is still low sound circuit has to be repaired.if it is ok,sound switching circuit has to be repaired(TV to Video)
Jun 14, 2011 | Televison & Video
I have background sound on my TEAC HTX1800 DVD player, but I can't hear the people talking. Please help?! Regards /Hester
Chances are you are playing movies coded for Dolby Digital Surround. Depending on what kind of receiver your DVD player is plugged into, the receiver may not have the Center channel operating or turned up. Most all dialog comes from the center channel of a surround sound system. The receiver usually has a separate output for a center channel speaker, and a separate volume control as well. This will adjust the dialog volume up.
If you are not using a receiver, or plugged directly into the TV, check the audio settings on the TV. They may not be set up for the surround, hence why you are missing the dialog. Good Luck
Feb 21, 2011 | Audio Players & Recorders
Have to turn the volume to 80-100 to hear the tv in my bedroom
If it's just playing DVD's that the volume is low some DVD players have their own volume control.
You could look at the back of your tv and see if the dvd or psp is hooked up to a "line in" or a 'variable' input. The Line in is a constant audio source. The variable will be also affected by the volume on the TV.
May 31, 2009 | Televison & Video
How to program ilo TV w/universal remote to play DVD
I Believe You Can Go To Channel 2 And Right Below Those Channels Are The 3 Video Channels Turn On Your Dvd Player And Go Through Them. If That Doesn't Work Try Looking At The Buttons On Your Tv For A Tv Video. Make Sure You Dont Have A Tv Video Button On Your Remote If You Do Then Just Click It Till You Find The Appropriate Video Channel.
Jan 05, 2009 | iLO 3200 32 in. LCD Television
Philips 27PS55S/121 sound level decreases
Yes, the dynamic range on DVD's is enough to cause the high and low passages to be somewhat annoying but, sounds more like a movie theater. This kind of dynamic range showed up first on Beta HiFi and VHS HiFi VCR's because of thier range as well. If there is a feature in your audio menus on your TV such as "audio expansion, SRS, Wide mode, etc." turn it off and let the audio be processed without expansion of any kind as that will amplify your dynamic range alot more. The lock up issue could be something Philips is aware about and if under warranty contact them. Otherwise not much you can do except manke sure the voltage going to the TV is failry stable between 110 volts and 120 volts. Sometimes dramatic drops and or increases can cause lock up or confusion to the microprocessor in the TV.
Mar 25, 2007 | Philips 27PS55S 27" TV
Toshiba 32A33 32" TV Logo
57 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
