Question about Jenn-Air JCB2280WH Air Conditioner
My lennox heater is shuting off after just five minutes of being
I can raise the temp and it will shut down , there is two lights flashing on the board
  • waterstone Jan 13, 2009
    lennox model g24m2-45a-12 ,also Icut power to reset and it will click off
  • Robotinner May 11, 2010
    what are the left and right lights doing and also I need the model and serial of the unit Thanks, Greg Sunsetmech
Comfort zone infrared heater runs for a few minutes a then completely shuts off
if unit runs ok for 3 to five minutes then completely shuts all power lamps off , then its hi temp limit sensor (safety) has been tripped , this usually goes out due to failure of main temp control , in point of fact contacts in temp switch literally weld them self's together and cant separate to allow heater to control temp
Oct 15, 2016 | Comfort Zone CZ1500WC Infra-Red...
Master 125,000 propane heater will ignite but when you release the button it cuts the gas off, takes about 5 minutes before it will stay on and you can change the setting. How can this be fixed?
? doesn't this control On/off on a thermostat ?? the button your referring to is it the piliot test button ? if so I guess you've found a loophole in there test strategy by holding it down for five minutes to get it too stay on ,
what does this heater do when it shuts off on seeing a heated water temp to setpoint (or doesn't it ?) as if the test button is the only way to light it , this button bypasses a few normal safety switches (allthogh I didn't know about the five minute thing) one of the most common safetys that goes on these heaters is the heat exchanger over temp switch , seems the wires get hot and the little connectors fall off it
Mar 29, 2016 | Pool & Spa
I reset the heater by shutting it off for about
sounds like temp sensor is bad
Sep 27, 2014 | Pool & Spa
New lasko heater keeps shutting down
fatly over heat switch or tilt switch some r very picky
Dec 10, 2013 | Lasko Heating & Cooling
Runs about 4 minutes shuts down
fuel filter is pluged up or temp sensor is detecting overheat and shuting down , if it is not overheating the sensor is defetive..
Jan 10, 2011 | Reddy Heater-170,000 BTU Kerosene Deluxe
After about 10 minutes the entire heater shuts down pilot light and flame.
IF YOU WOULD LIKE TO KNOW, MY PLAN WILL COST YOU FIVE SMALL INSTALLMENTS OF $20.50.
Thank you
Dec 12, 2009 | Vanguard International Blue Flame - Large...
Lennox furnace 17 yeanrs old. flame comes on and the shuts down sometimes right away some times in a few minutes. We have the furnace go down to 58 at night. It takes all day to get back to 67.
Sounds like a dirty flame sensor.
Also 9 degrees is a large swing to recover. Most specialist will advise no more than a 5 degree set back, otherwise recovery time eliminates any savings you may achieve.
Dec 05, 2009 | Dayton (3E407) Heater
Lennox lf24 garage heater, starts then shuts down.
Here is a link to the manual for your unit heater:
http://tech.lennoxintl.com/C03e7o14l/mk6x6w5J5/503526e.pdf
The 4 flashes is a high limit or roll out switch is open. There are 2 or 3 little brown or black button looking switches with a little button on the top and a wire attached to each side. Press the button on each, you may hear a slight "click". If you do, that is the one that was open. Hope this helps.
Oct 31, 2009 | Heating & Cooling
Lennox Gas Furnace that turns on and shuts off in minutes
After troubleshooting like mad, I found that the flame sensor (rod that sits within the flame) was fouled with carbon on the surface. I believe this shields the rod from proper heat detection and the sensor reports that there is no flame and to shut off the gas valve to avoid explosion. Once I pulled out the rod and cleaned it with a wire brush, I have no problem whatsoever--fixed.
Nov 10, 2008 | Heating & Cooling
Heating & Cooling Logo
161 people viewed this question
Top Jenn-Air Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Jenn-Air Heating and Cooling Expert? Answer questions, earn points and help others
