Question about Onkyo HTR500 Receiver
Onkyo ht r530 receiver 7.1 front left speaker only one working
Did set up mode audio calibration could hear test pattern in all speakers
whats up?
  • Anonymous Feb 25, 2009
    Distorted audio Left,And Right chanels.
    center chanel Ok
  • Anonymous Apr 16, 2009
    All speakers but front left work. Why?
4 Suggested Answers
  • 319 Answers
SOURCE: Onkyo HT-R530 with powered speakers
I would not suggest hooking up powered speakers to your receiver. Only if unit has sub woofer output can you hook up powered speaker
Posted on May 07, 2008
  • 15 Answers
SOURCE: Onkyo ht-r530 Receiver troubleshooting
the 7.1 sound not all the movies has that feature and u need to emulate it, doit in the dolby digital ex and the speakers must sound.
try the volume for the SBL or SBL maybe are to low.
decrease the volume for all the speaker less the SBL, SBR and check it out.
Good Luck
Posted on Jan 12, 2009
  • 195 Answers
SOURCE: onkyo receiver HT-R530..after cable and speaker
One way or another, it sounds like the amp has blown. Probably the outpous and/or drivers and such. Perhaps one of the speakers was either shorted, wires touching or hooked up wrong.
Posted on Oct 10, 2009
Have noise on left back speaker channel of onkyo 606 blocking sound from movies etc
Hi Brendan, have you swapped the speaker from the left channel to the right one so that we can be sure that it is not the speaker? You can also try a hard reset:
To do the reset you need to turn the receiver on, then on the front panel of the receiver press and hold the "VCR/DVR" button while doing that press the "STANDBY/ON" button. You will see the word "Clear" in the display screen and the receiver will go into standby mode. PLEASE UNDERSTAND THAT YOU WILL LOSE ALL YOUR AUDIO & VIDEO ASSIGNMENTS ON THE RECEIVER PLUS YOU WILL LOSE ALL YOUR SPEAKER CONFIGURATIONS, SPEAKER DISTANCE AND ALL LEVEL CALIBRATION SETTINGS. YOU WILL ALSO LOSE ANY PROGRAMMED RADIO STATIONS IN MEMORY. Once the receiver goes into standby mode turn it back on and go thru the setup menu for all custom settings.
If you need further assistance please email me at askOnkyo@us.onkyo.com, Thanks,JT
May 04, 2015 | Onkyo Audio Players & Recorders
Only plays through one front speaker when in video mode.i've tried v-1 v-2 and v-3. i'm using optical for audio
Hi Richard, please make sure that the source has been assigned to the optical connection via the setup menu or you can select the source and then press the digital input button until the display shows the optical connection where the physical connection was made on the back of the Onkyo, Thanks, JT
Apr 01, 2015 | Onkyo Ht R530 Receiver 7.1 Surround Sound...
When in video mode only plays through one front speaker
Hi Richard please try the following reset:
To do the reset you need to turn the receiver on, then on the front panel of the receiver press and hold the "VCR/DVR" button while doing that press the "STANDBY/ON" button. You will see the word "Clear" in the display screen and the receiver will go into standby mode. PLEASE UNDERSTAND THAT YOU WILL LOSE ALL YOUR AUDIO & VIDEO ASSIGNMENTS ON THE RECEIVER PLUS YOU WILL LOSE ALL YOUR SPEAKER CONFIGURATIONS, SPEAKER DISTANCE AND ALL LEVEL CALIBRATION SETTINGS. YOU WILL ALSO LOSE ANY PROGRAMMED RADIO STATIONS IN MEMORY. Once the receiver goes into standby mode turn it back on and go thru the setup menu for all custom settings., Thanks, JT
Apr 01, 2015 | Onkyo HT-R560 Receiver
Onkyo ht-r530 subwoofer stopped working
Turn the out put leval down on your sub, End the reciever, I was turn up to high,End that will cause it to cut out.
Oct 20, 2012 | Onkyo Ht R530 Receiver 7.1 Surround Sound...
Onkyo HT S3300 center, left front and rear speaker not working.
check your speaker wiring, make sure both terminals are connected properly. or could just be left speaker is disconnected. and is set in stereo mode which will only play left and right front and Sub, if you have one. try chaning the surround mode to play in multi channel speaker which will send sound to all speakers. i trust your using a Digital audio cable from your source ( cable box, DVD player) if your using analog audio cable you will only get stereo sound, and nothing will ever come out of the rear speaker unless you change the surround mode to multi- channel speaker. also in the setup menu you should be able to perform a speaker setup, make sure all your speakers are able to produce sound. follow speaker setup mode in menu, make sure you have checked the boxes or Yes to speaker you have in your system. then perform calibration and a test tone will come out of each speaker as you select them.
Apr 28, 2011 | Audio Players & Recorders
Onkyo receiver HT-R530..after cable and speaker hook up = puff of smoke and blinking red light. Will only turn on for 10sec at a time. Whats UP!???
Oct 09, 2009 | Onkyo HTR500 Receiver
Good Luck
Jan 12, 2009 | Onkyo Audio Players & Recorders
Onkyo HTR500 no sound from the surround speakers or subwoofer
insted of running it thru the tv an to the reciver try doing it directly from the DVD player to the reciver just the audio jacks
Sep 08, 2008 | Onkyo HTR500 Receiver
Apr 22, 2008 | Onkyo TX-SR605 Receiver
Onkyo HTR500 Receiver Logo
333 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
