Question about GE Security Simon 3 Wireless Home Security System
The alarm says module ok every few seconds
The alarm is going off and keeps saying, "module ok". Any ideas of how to stop this problem?
  • 4 more comments
  • Anonymous Jan 20, 2009
    I am having the same problem for the past few days.The alarm was ok for 3+ years, then it's giving problems. Is it a battery issue?
  • Anonymous Feb 01, 2009
    I have the same problem, and as above I have had this unit about 3 years without problems till a couple days ago.
  • ct6082 Feb 07, 2009
    I had my home security system installed yesterday at approximately 5:00 pm. It has been saying "module ok" every 5 seconds since. The tech who installed it said it would continue for 18-24 hours until the internal battery was fully charged. It has been 29 hours now, and it is still going.
  • Anonymous Feb 07, 2009
    bababewy
  • Anonymous Mar 03, 2009
    i have the same problem. It's very random. Everyonce in awhile the status button light turns on and when you push it it says "module low battery"
    Don't know what the problem is yet.
  • Anonymous Apr 20, 2009
    same issue here, we've had our system for over 2 years.. can anyone tell me how to fix it please?
Reason: The reason why the sys is saying module ok is becasue of the panel battery. This is a common problem with simon 3 and thats why i would not suggest this sys to anyone. The module is the cell unit thats send the signal to the central station wirelessly and it gets it power from the batteries.
Fixes. The only way to fix this issue is by replacing the panel batteries.
Posted on Aug 14, 2009
My Van Was Running OK The nekt day I started the engine, & runs for 5 sec, & stop, keep douing the same thing
Your alarm went off. This is common if it was your crank or cam it would start shut off but give you more than five seconds, Try this roll down a window disconnect the battery and put both terminal together, this will try the BCM(body control module) hod terminal together for 30 seconds reattach the battery put the key in the ignition for 10 seconds in the ACC position then start it. see if that works
May 19, 2011 | 1997 Chrysler Town & Country
I have the Caddx NX-6 alarm system. Problem: Alarm system will not arm when entering the 4 digit code. Symptom: I have all doors/windows/zones closed. LED displays READY. I press the code and get 3...
If the power was out for 5 hours and the control panel still shows 'low battery', it's probably time to replace the battery for the control panel. However, this shouldn't keep the alarm panel from arming up. I would first try to re-start the control panel by removing the power and battery connection for a few seconds and plugging it back in. After that, it would be a good idea to re-enroll all of your attached sensors, etc. by entering into programming mode and exiting. Press * 8 + {go code} then just press exit. The default 'go' code is 9713. After about 15 seconds, the panel will have auto-enrolled each attached device. Try arming and disarming the panel. Be careful of setting off the alarm, as your monitoring station may dispatch police, etc. in the event of alarm. This is why having a certified alarm installer do this work is a good idea, as they can put your account with the monitoring station on 'test' so alarm signals are recorded for testing purposes but are not acted upon.
Feb 11, 2011 | GE / Caddx NX 6 Fastpack with NX 1308E LED...
I purchased the AGA-1201 remote start alarm system and am having a big problem. The car starts remotely, but only runs for a couple 5-6 seconds before it stops, it then retries two more times with the same...
if the starter keeps going while the car is running for those few seconds, the issue is with the tach signal wire that runs from the remote start module to a coil signal wire under the hood. check it and make sure the connections are good and the wire isnt broken.
Feb 17, 2010 | Vehicle Parts & Accessories
Our system keeps repeating module ok how can
replace the 6VDC 1.2AH battery. The module runs directly off the battery and it is not keeping a charge.
Alarm Professor.net
Oct 08, 2009 | GE Security Simon 3 Wireless Home Security...
Whirlpool fridge freezer alarm s20D RSB33AG-B
Hi, you have a common problem with your control boards; there is a cheap fix if you can use a soldering iron or you can have your modules repaired.
Let me know
bb
Aug 31, 2009 | Whirlpool Freezers
Car alarm keeps going off. i have locked and unlocked the doors. alarm will go off, but when you try to start the car the alarm comes on an the car will n ot start. any ideas
the starter kill relay inside the module is malfunctioning. the module needs to be replaced and reprogrammed to the remotes.
Mar 28, 2009 | 1999 Volkswagen Passat
I cant disarm my alarm
Get inside the car, turn the key to the on position, the alarm is going to sound so do not panic when the alarm sounds press the valet button one time and the alarm should stop. To place the alarm in valet mode cycle the key with the door open on then off then press the valet button one time and the alarm should go into valet mode meaning the alarm light will be on steady.
Feb 03, 2009 | Viper Security and Remote Start System...
GE Security Simon 3 Wireless Home Security System Logo
2,085 people viewed this question
Top GE Home Security Experts
Sean
Jim Goldsmith
Jim Goldsmith
Grantec 2000
Level 1 Expert
Are you a GE Home Security Expert? Answer questions, earn points and help others
