Question about Microwave Ovens
Microwave acts normal but no longer heats
Same
  • 25 Answers
Basicaly you need to know if ot has 110 volts on the primary of the mag transformer. If you do its someting in the cap or the mag tube. If not then its in the relay or the timer.
If it just slowely started taking longer and longer to heat over months then the mag tube has gone bad.
Posted on Jan 14, 2009
I have a GE Spacemaker LX1800 that is not heating up the food. It acts like it was working normal but is not heating the food.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101==]---=]
May 11, 2010 | GE Profile Spacemaker Over-the-Range...
Acts like working, but no heat.
Microwave Oven Basic Troubleshooting Tips
heatman101
dgyj57we
Apr 21, 2010 | Jenn-Air JMC7000 Microwave Oven
Kenmore Microwave Oven 721.80019401 has power but no longer heats
i think you will find its the magnatron they are very dangerous and expensive to replace i would buy a new microwave ..sorry
Apr 20, 2010 | Microwave Ovens
Microwave now taking longer to heat same cup of water - safe?
Actually if there is a larger than normal power demand in your area from a cold spell and the input line voltage drops even 5 volts from 120V to 115V it can make a huge difference in the performance of your microwave. It can also be signs of a weak high voltage capacitor or a failing high voltage diode. Neither of those are an excess espense repair.
If it is working normally but taking up to 30 seconds longer to get the results you had in the past check the input power first. I would also check the fuse holder inside the chasis to see if it had weak contacts and not grasping the fuse very well. If it looks like it has been hot or the fuse is a solder type and you see signs of melted solder there is a problem with either the fuse or fuse holder (this can act like a resistor and drop the input power voltage.)
Jan 12, 2010 | General Electric Microwave Oven
Whirlpool MH1160XSQ-1 microwave oven will not heat
all microwaves have a magenetron which produces the heat. if this is gone and it is not under warranty, it is not cost effective to repair. check you manual, most mag's have a 3 - 5 year warranty.
Nov 07, 2009 | Microwave Ovens
I have a microwave built in 1998. It is a GE Model # JES1244WA001 and it won't heat. When we turn it on, it acts normal, but it just won't heat. I unplugged it and plugged it back in but that didn't help....
hello, let me see if i can assist you.
When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem. To resolve this problem, you need the assistance of a qualified appliance repair technician.
Since your microwave is 11 years old, most technicians would recommend that you trash it and buy a new one. The repair will cost more than a new microwave.
May 14, 2009 | General Electric Microwave Oven
Microwave oven not heating thoroughly
u need to clean the cavity inside the microwave .. step to clean that .. put a cup of water nearly half filled( 30 ml ) and start microwave for five minutes .. after that just open microwave and clean from inside with clean cotton cloth .. this will surely help ..
Mar 23, 2009 | Kenmore 63683 Stainless Steel 1200 Watts...
GH7145XFB-1 not heating properly
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Nov 16, 2007 | Whirlpool GH7145XF Microwave Oven
Microwave Ovens Logo
90 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
