Question about Canon ImageClass MF5770 Laser Copier Printer Fax Scanner Network
Fonts not installed
Just bought this printer/copier. Keep getting error message saying certain fonts are not available. Prints anyway - but how do I install additional fonts
  • Jordan May 11, 2010
    Does this occur when you are printing from a specific program or anytime you print?
  • 3 Answers
Fonts are typically available either for free or for a fee.
Only fonts that are visible in your C:\WINDOWS\Fonts Directory will be available to print.
You can google fonts and find more if you are looking.
Also, depending on the program you are using, you can save as a .pdf to print and this will "pack " you fonts into the document. You cna also use the "prepare for commercial printing" option in MS Publisher to store the fonts in the file.
Bottom line, if the font isnt installed, you cant use it.
You may be getting this error if the document came from someone who has the font but you dont. If that's the case, tell your friend you need the fonts. Just copy them out of the E:\WINDOWS\Fonts directory to your disc.
That should do it.
Posted on Jan 13, 2009
Can we print Courier New font with print quality UTL: Utility in OKI3320 printer
the printer normally prints the font set in the computer as it replicates the document
Mar 30, 2015 | OKI MICROLINE 3320 Matrix Printer
MY HEWLETT PACKARD DESKJET 3520 PRINTS IN SUCH SMALL FONTS ITS VERY HARD TO READ.HOW DO I CHANGE THE FONT SIZE TO A NORMAL BOOK SIZE FONT?
Change the font in the application that you are using.
The problem may be that the printer's resident fonts does not include the font you are calling. So the printer's logic says, "Go find the best font you can." The font search gives you the wrong font.
If your printer allows you to print out the fonts, do that and make sure the font you want is in the list.
If it is not, then you will have to use a "Soft font" and make sure that your application knows to download/include soft fonts to the printer
Don
Feb 15, 2010 | Office Equipment & Supplies
PCL XL error
Okay,
You printer driver is telling you that it received a font call at data position 317 that called for a Windings font, but the printer cannot find the indicated font.
More than likely you have not enabled soft fonts to be included in the datastream and the printer has no choice but to search its internal fonts to find the fonts.
If it cannot, the driver reports the failure.
If you can create a print file for me, and send it to me at don.farr@msn.com, I will be able to read the datastream and possibly fix the failure for you.
Don
Jan 29, 2010 | Dell 1700n Laser Printer
Ragged / Zig-Zag Edges on Characters
This maybe the result of one of two issues:
1 - (and most likely) you are using a bit-mapped font instead of a true-type font and at a fairly large font size. Bit-map fonts are composed of dots, much like an icon, and cannot be scaled beyond a certain value or you see the jagged edges.
2 - you are using a true-type font at a fairly large size and your printer does not have a post-script driver installed on your computer, so it takes the font and converts it to its closest bitmap representation and prints it out...rendering the font in all of its jagged glory!
Dec 01, 2009 | Office Equipment & Supplies
Zebra 105SL Prints fine through Zebra Setup Utility, but prints plain text when file copied to port. Win XP. The setup utility can never get Version Info from the printer, but Windows shows the printer...
possible fonts issue. try to change the font from the text, check setings from the driver.
try to print from the driver (test print)
Try to print from Word (need to ajust the page) with diferents text fonts.
you can check the correct firmware ( be ware with the information about the serial number) ATENTION!!! wrong firmware can cause PRINTER DEAD!!!
Install lates firmware to the printer.
Oct 12, 2009 | Zebra 105SL Thermal Label Printer
THE TYPE SIZE IS TOO SMALL ON MY MP460 PRINTER.
Some fonts might not be available to use in the printer, make certain it's a true-type font you are using in your document.
Jun 24, 2009 | Canon PIXMA MP460 All-In-One InkJet...
Unable to load post script fonts in windows-xp
Well postscript fonts are vector outline fonts, so they contain instructions about the building of their outlines and curves and such. Hence two files are required to use a postscript font under Windows.
As to how to install these fonts, well
  1. Click Start | Settings | Control Panel.
  2. Double-click on the Fonts folder.
  3. Choose File | Install New Font.
  4. In the Folders menu, navigate to the folder containing the fonts that you wish to install. A list of available fonts will appear in the List of Fonts window.
  5. Click on the font you wish to install or use the "Select All" button to install all fonts in the List of Fonts.
  6. Click on OK.
Please keep in mind:
  1. If you are installing fonts from a CD be sure the 'Add without copying files' box is NOT checked; unless the fonts are on a located somewhere (such as a network) which you will have access to at all times.
  2. Postscript fonts have two files: PFB (printer font binary has outlines that control how the font looks) and PFM (printer font metrics has information about font spacing). Be sure you have both font files.
  3. If you currently have or previously had Adobe Type Manager Deluxe 4.0, 4.1, or 4.1.1 installed you may need the Adobe Deluxe Updater in order to properly use your Postscript fonts under Windows XP. Get it from Adobe.
Hope this helped. Let me know and if yes please rate me:)
Feb 15, 2009 | Adobe Computers & Internet
BAR CODE FONTS FOR LITTLE LABELS
Depends on what software you are using, but you can use any True Type Font for the human readable, and any propritry barcode font available as downlaods.
However these barcode fonts tend not to print very small, it is a matter of trial and error.
www.lancerlabels.co.uk
Feb 10, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Need larger font size for e-mail
don't know comcast is this your service provider? why not use outlook?
Jan 04, 2009 | HP PSC 750 All-In-One InkJet Printer
My HP laserjet 1300 printer Problems
You could be set in draft mode in your printers properties, or, you could be using ECONO Mode.
Sometimes People use PCL Fonts for their printers, and other use PS Fonts. PCL is the typical font type. PS is post script, which Adobe type fonts are used.
If you are set to PS Fonts using MS Word, you might try PCL Font types instead.
Jul 02, 2008 | HP LaserJet 1300 Printer
154 people viewed this question
old marine
old marine
