Question about Brother IntelliFAX 2800 Laser Fax
Light fax Our Brother ItelliFax 2800 is having troubles. The faxes are printing out really light. We have changed the toner and it still is light. I have tried changing the setting in the menu as per this website and still it is getting lighter. Is there anything else that can help?
  • serenatappe Jan 14, 2009
    The drum and toner were recently replaced and last week I turned off the toner save function last week and it didn't make much of a difference. There is a vertical section that is lighter than the others. Any other suggestions?
  • 80 Answers
This could be a couple of different things. The first is that you are running out of ink or toner. Or you could have your toner save turned on. You can conserve toner using this feature.
When you set Toner Save to On, print
appears lighter. The default setting is Off.
1 Press Menu/Set, 1, 6, 1.
2 Press ▲ or ▼ to select On (or Off).
Press Menu/Set.
3 Press Stop/Exit.
Posted on Jan 14, 2009
Unreadable recieved faxes
No, not worth it. A very slow, old, fax machine
Apr 19, 2010 | Brother IntelliFAX 2800 Laser Fax
Fax prints to dark
have you replaced the drum??? are you using brother oem toner???? generic toner will give you all kinds of problems
Oct 29, 2008 | Brother IntelliFAX 2800 Laser Fax
Toner prints to dark
try to re-install the driver of your printer!!!
or try to figureout the settings of your printer
Print in light
1. Check TONER SAVE setting. If this setting is programmed "ON", all
printed documents will be light.
a. Press MENU/SET, 1 (General Setup), then 6 (Toner Save).
b. Press the top or bottom navigation key (keys located above and below
the MENU/SET key) until the display reads "Toner Save: OFF".
c. Press MENU/SET.
d. Press STOP/EXIT.
2. Check the PRINT DENSITY setting. This setting allows you to adjust
the print density from light to dark.
a. Press MENU/SET, 2 (Fax), 1 (Setup Receive), then 6 (Print Density).
b. Press the up navigation key (key above MENU/SET) to make print
darkeror the down navigation key (key below MENU/SET) to make print
c. Press MENU/SET.
d. Press STOP/EXIT.
Oct 15, 2008 | Brother IntelliFAX 2800 Laser Fax
Light printing
we cannot figure out why the fax/copyer always prints things out very light you cant see any thing that gets printed out on it
Jul 09, 2008 | Brother IntelliFAX 2800 Laser Fax
Brother Intellifax 2800 replace drum message
the unit that you install the toner cartridge into is actually the drum on this machine.
Jun 24, 2008 | Brother IntelliFAX 2800 Laser Fax
Light copies
You may have your machine set to print in "toner save" mode. Check your machine settings by printing a list. Also, some generic toner cartridges have too much polymer in the mix and will print light copies. If you change back to OEM toner, you may have to change the drum too, as the extra polymer stays in the drum unit and weakens the mix.
Jun 04, 2008 | Brother IntelliFAX 2800 Laser Fax
Poor quality fax to fax, copy great, computor fax great.
beware of generic toner!
you may need to change out your drum unit
the drum unit may have been contaminated by the staples toner.
also clean laser window under drum cartridge.
Mar 17, 2008 | Brother IntelliFAX 2800 Laser Fax
Incoming fax quality
Are you using genuine Brother supplies? Generic supplies are the main reason for print quality issues. Have you ever changed thr drum unit ? Expensive! You can buy a new machine and get a new drum and toner for a little bit more.
Oct 22, 2006 | Brother IntelliFAX 2800 Laser Fax
Brother IntelliFAX 2800 Laser Fax Logo
119 people viewed this question
James Cagle
James Cagle
Jim Keysor
