Question about Acer Aspire 5100 Notebook
Sound is not in sync with action on screen, or is slowed and dist
Can I reload the sound driver to fix the issue.
  • djpatterson7 Jan 13, 2009
    It happens on everything she listens to
    Genius:
  • 1,269 Answers
It could be the video itself. First, try to watch different movies and check if the same problem occurs. You can reload the sound driver if that is the same problem persists.
Posted on Jan 13, 2009
My netflix is running slow..the sound and picture don't sync up what causes this?
The problem is that your internet speed is not fast enough from your provider. Call the provider and see if you can move up to faster speed and that will help your problem
Apr 23, 2014 | Netflix
Sound distortion
All you need is to re-install sound drivers.
Download and install the latest sound drivers.
If issue still exists then try these steps:
Scan PC with an Anti-Virus
Fix registry errors
For an instant fix use system optimizer like Reginout.
Apr 21, 2013 | HEWLETT-PACKARD 620 XT964UT Notebook PC
How can i fix my audio suon
Method 1: Restart the computer Restart the computer at least one time after you install a Windows Vista service pack to verify that all processes related to the installation are complete.
After you restart the computer, determine whether you can hear sound. If you can hear sound, the issue is resolved. If you cannot hear sound, try Method 2. uparrow.gifBack to the top Method 2: Try another sound deviceIf it is possible, try plugging a different sound device into the computer. For example, if you were using speakers, try a different pair of speakers or a set of headphones to make sure that the problem is not related to the sound device.
Determine whether you can hear sound. If you can hear sound, there is a problem with the original sound device and the issue is resolved. If you cannot hear sound, plug the original sound device back into the computer, and then go to Method 3. uparrow.gifBack to the top Method 3: Unplug the computer speakersUnplug the computer speakers or other sound devices that you may be using, such as headphones, from the computer and then plug them back in to the same port. Most sound cards that are compatible with Windows Vista include a feature that detects sound devices plugged into the audio jack. This procedure may prompt the audio detection feature to detect and configure the sound device to make sound.
Determine whether you can now hear sound. If you can hear sound, the issue is resolved. If you cannot hear sound, try Method 4. uparrow.gifBack to the top Method 4: Verify that the default sound device is set correctlyAfter you install a Windows Vista service pack, you may find that the default sound device, also known as the playback device, was changed. You may also find that the sound quality has changed. Make sure that the default sound device is set correctly for the sound device that you are using. To set the default device, follow these steps:
  1. Click Start vistastartbutton.jpg, type Sound in the Start Search box.
  2. Click Sound in the search results at the top of the Start menu.
  3. Click the Playback tab. Notice the check mark next to the default device. For most users, the default device is Speakers. Make sure that your audio settings are configured as expected. Follow these steps:
    1. On the Playback tab, select the playback device, click Properties, click the Advanced tab, and make sure that the Default Format is set to the value that you expect. When you finish, close this window to return to the previous window.
    2. On the Playback tab, select the playback device, click Configure, and then make sure the configurations are set correctly.
    If the sound settings are set correctly, you are using speakers as the sound device, and your speakers are already set as the default device, go to method 5 now.
  4. Select the sound device that you want as the default sound device, and then click Set Default.
  5. Click OK to save your settings and to close the Sound dialog box.
Determine whether you can now hear sound. If you can hear sound, the issue is resolved. If you cannot hear sound, try method 5. uparrow.gifBack to the top Method 5: Verify that a sound driver is installedWithout a sound driver, you will not hear sound. Make sure that a sound driver is installed. To do this, follow these steps:
  1. Click Start vistastartbutton.jpg, type Device Manager in the Start Search box, and then press ENTER.
  2. In the Device Manager dialog box, expand Sound, video, and game controllers.
    If there is a speaker icon next to the sound driver, the driver is installed. If there is a yellow question mark next to the sound driver, the driver is not present or will not load.
Go to method 6 to reload the current sound driver and test for sound. uparrow.gifBack to the top Method 6: Reload the current sound driver If you discovered in method 5 that the sound driver was not installed, or if you discovered that the sound driver was installed but is not working, try to reload the sound driver. To do this, follow these steps:
  3. Locate the audio device that was included with the computer.
  4. Right-click the device, and then click Properties.
  5. Click the Driver tab, and then click Uninstall.
  6. Make sure that the Delete the Driver Software for this device check box is cleared, and then click OK.
  7. In the Device Manager dialog box, click the Action menu, and then click Scan for hardware changes.
    You receive a message that states that a hardware device is being installed, and then the uninstalled audio device appears in Device Manager.
  8. Close the Device Manager dialog box.
Determine whether you can now hear sound. If you can hear sound, the issue is resolved. If the current sound driver did not reload or if it did reload, but you cannot hear sound, try method 7. uparrow.gifBack to the top Method 7: Update the current sound driver If the current sound driver does not seem to be working, see whether there is an updated sound driver that you can install. To request an updated sound driver, contact the manufacturer of the sound driver.
For information about how to contact hardware and software vendors, visit the following Microsoft Web site: http://support.microsoft.com/gp/vendors/en-usNote In some cases, the manufacturer may instruct you to uninstall the current sound driver and to delete the driver files. To do this, follow the steps in method 5, but at step 6, click to select the Delete the Driver Software for this device check box.
Dec 12, 2010 | Toshiba Satellite M35X-S114 Notebook
Video and sound don't sync
Customer Service:
Phone: 800-968-9853
Its a Software issue need to upgrade the Firmware
Jan 06, 2010 | Sylvania SMPK2062 MP3 Player
My laptop has allways played music but tonight it will not
Sorry but is this a laptop or desktop? you have both in your listing!
One of a couple issues!
1) Sound card went bad.
2) Volume control is set too low?
3) lost the sound card driver -may need to reload the driver.
4) CD drive crashed! - does it
Blessings Always,
A/V Media Tech Guy
Dec 03, 2009 | Ultimate Sound COMPUTER ABS | Ultimate V1...
I have an audio configuration issue. WM player will not play files it recognizes. Neither will itunes. A .mid file will play. WMA's and MP3's will not. The whole operating system slows to a crawl until I...
Uninstalling these programs may have deleted something it needs in the program. The only thing that you can see if you saved a restore point. if not then you will have to reload
Sep 25, 2009 | Dell Inspiron 6000 Notebook
Slow screen and no sound
Could you please specify some things like how big is your hdd & how much memory do you have. These 2 things are very important when installing a new operating system like xp & up.
Sounds like you may need another one of the sound drivers. Do you have the Realtek97 Audio driver?
And is your standby option greyed out when you click start & turn off computer? This will be a video driver issue I'm pretty sure. When you drag a window quickly across the screen do you see it like streaks or what exactly do you mean by "slow screen"?
Jul 17, 2008 | Computers & Internet
Sync issue
SanDisk Sansa View - Reset - Use the slide switch on the side and hold it tward the Mic hole for 10 sec. Then try to reload the drivers onto your computer, and use the disconnect button in the software, then re-connect the USB plug.
Dec 24, 2007 | SanDisk Sansa View 8GB MP3 Player - Black
Acer Aspire 5100 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
