Question about Procom (177653) Utility Heater
Gas smell from Procom 28000 btu infared heater
I PURCHASED A NEw PROCOM HEATER AND I HAVE A SMALL GAS SMELL WHEN THE PILOT AN D HEATER IS -ON. I CHECKED ALL CONNECTIONS AND THEY ARE TIGHT.I TURNED GAS OFF AT VALVE AND NO GAS SMELL,i CAN NOT FIND MY PAERWORK AND THE HEATER IS ONLY 2 MONTHS OLD.ANYONE WITH A SOLUTION OR AN EMAIL ADDRESS OR PHONE NUMBER FAR PROCOM?
THANKS
JAY CALK
  • ivanstolte Feb 03, 2009
    My pro com heater was fine for the first month. After I turned the heat down for a day the heater smells like lighter fluid when I turn it up.
  • Procom Master
  • 3,092 Answers
Check the connections with some washing up liquied and water in a bowel and try the connections with this , it should help find your leak use a paint brush to put on
Posted on Jan 13, 2009
Pilot light wont light will spark, but no propane
verify the inlet pressure to the heater. those pezioelectric spark lighters are garbage. make sure all manual shut off valves to the heater are open. Pilot tubing may also be blocked
Nov 25, 2013 | Glo-warm 503284 30000 BTU Propane Gas Vent...
Have a vent free lp wall mounted heater.40 lp tank with regulater. pilot light will light but only the tip of pilot light is flame.there is a space between pilot light and tube where lp comes out. does not...
Too much gas pressure. Are you sure that this is a LP heater and not a Natural gas heater? Is the regulator you have rated under 1/2 pound pressure? Try to throttle down the shutoff on the tank to see if pilot gets better. If so, you have a pressure issue. Gas you adjust the pilot gas valve?
Jan 22, 2010 | Procom 10K BTU, Vent Free, 2 Plaque...
Pilot goes out!!
My manual shows three possibilities:  1) Insufficient fresh air available for combustion, so ODS kicks off gas flow 2) Low gas line pressure (should be between 11 and 14") or 3) ODS/Pilot is partially clogged.  Toll free number for ProCom is 877-886-5989.
Mar 09, 2008 | Procom ML300TBA Heater
Pilot won't ignite
For SBP12,
It will take some time for the gas to get to the unit, just turn it on and wait. It might take 5 to 10 minutes to fill the line with gas.
Oct 20, 2007 | Procom ML300EBC Heater
Procom ML200TBA
Propane appliances usually run on 10-11 inches of water column, this is about 1/2 pound of pressure. If the regulator you have is not rated for delivering gas at that rate, you will need to find one that does. If your regulator is rated for more than the 11 inches, most likely you could have damaged the appliance regulator that came with the heater. Check the propane pressure specified by the heater manufacture against the rated supply of your regulator and see if they match. Make sure the heater is rated for Propane and NOT Natural Gas. Check to see if the gas valve on the appliance is in the operate position and all valves are open. Bleed off the air in the gas line by holding down the pilot switch and keep attempting to light the pilot. It could take you a few minutes. If you hear and smell gas but the unit will still not light, don't chance at getting hurt, call a technician. Look to make sure there are no safety switch that may have triggered off not allowing the gas valve to operate. And make sure there is no obstruction in the heater?s gas valve blocking off the supply of gas. Always exercise caution when it comes to gas and if you are uncomfortable, call a qualified gas technician.
Dec 15, 2006 | Procom ML300TBA Heater
Procom (177653) Utility Heater Logo
432 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
