My iSymphony will not turn on
When I press the 'on' button, the off/stanby light turns off, indicating it should be on. But the display and lights don't come on, and I don't hear any sound.
    New Friend:
  • 111 Answers
POWER SUPPLY OR POWER AMLIFIRE PROBLEM,
are you technicaly sound to do the repair?
nuwan.
Posted on Jan 16, 2009
Zanussi dishwasher ZDF601M 1 in 3 red light comes on and programme doesn't work through
26269906-aipk5px1bmfkdpsmrgevaqwn-3-0.jpg "3 in 1" function
This appliance is equipped with the "3 in 1" function, that
allows the use of the "3 in 1" combi detergent tablets.
This function can be selected with all washing programmes.
With the selection of this function the inflow of rinse aid and
salt from each respective supply container is automatically
deactivated and also the indicator lights for salt and rinse aid
are deactivated.
Select the "3 in 1" function before the set of a washing
programme.
Once this option is selected (indicator light illuminated) it will
remain active also for the following washing programmes.
With the use of the "3 in 1" function, the cycle durations may
change. In this case, in the digital display, the indication of the
running time of the programme is automatically updated.
NOTE: Once the programme is running, the "3 in 1" function
can NO longer be changed. If you want to exclude the "3 in 1"
function you have to cancel the programme setting (see
chapter "Starting a washing programme" - "Cancel a washing
programme in progress") and then deactivate the "3 in 1"
function.
In this case you have to set a washing programme (and
options) again.
Activation/deactivation of the "3 in 1" function
(The dishwasher must be switched off)
1. Press the On/Off button. The On/Off indicator light
illuminates (setting mode).If a programme button indicator light is on, this means that a washing programme is set. The programme must be cancelled: press simultaneously function buttons 2 and 3
for about 2 seconds. All the indicator lights will turn off (except for the On/Off indicator light and eventually salt and rinse aid indicator lights) indicating that the set programme has been cancelled and the machine is now in setting mode.
2. Press simultaneously function buttons 2 and 3, until the
indicator lights of function buttons 1, 2, 3 and 4 start
flashing.
3. Press function button 4, the indicator lights of function
buttons 1, 2 and 3 turn off while the indicator light of function
button 4 goes on flashing.
4. Press function button 4 again, the "3 in 1" indicator light
illuminates, indicating that the "3 in 1" function is active.
To deactivate the function press function button 4 again, the
indicator light turns off.
5. To memorise the operation, switch off the dishwasher by
pressing the On/Off button or wait about 60 seconds after
which the dishwasher will automatically return to setting
mode.
Dado
Aug 29, 2016 | Zanussi Dishwashers
How do i play music from my phone on my philips micro music system btm2180
1. On the Philips music system, press FM repeatedly until [BT] (Bluetooth) is displayed on the display panel. The Bluetooth indicator flashes blue.
2. On your phone, go to Settings and turn on Bluetooth. Press Scan. Your phone will start searching for nearby Bluetooth-enabled devices.
3. Select 'PHILIPS_BTM2180' on your phone and, if necessary,
enter '0000' (no quotes, all zeros) as the pairing password/key.
After successful pairing and connection with the phone, the Bluetooth indicator on the Philips system will turn solid blue and you will hear two beeps coming from it.
4. Start playing music on your phone and enjoy hearing it from the speakers on your music system !.
Dec 20, 2014 | iSymphony M50 Micro Music System with...
I have a Bosch dishwasher with a rinse indicator light. When the light is on it's supposed to be indicating that the rinse aid is emptybut my rinse aid container is not empty even though the light is on....
Phone Bosch 08448 928 979 for a step by step solution. Program select at 12 o'clock. Press ON/OFF and Time Delay button together. Press time delay button, display should change from 1 to 0, indicating warning light is inactive.
Jun 25, 2010 | Dishwashers
Onkyo ht-r670 receiver is new and will not turn on. red standby light is on. but no display. also remote doesn't have any effect.
I would check any fuses first. The power transformer could also be open.There is a stanby supply that provides 5 volts that is always on . This is what supplys voltage for the standby light and the cpu. When you press the power button the cpu trips the power on relay that provides the 120v ac to the main transformer. If the transformer is open nothing happens. Onkyp part # is 2301798. Check the windings for continuity.
Dec 31, 2009 | Onkyo Audio Players & Recorders
Power light blinking
Send it for repair. The receiver has a problem with power supply or a bad channel.
Oct 05, 2009 | Denon AVR588 Receiver
Message waiting indicator light will not turn off keeps flashing
Slide the Nortel Grey Bar above the Hold & Rls buttons to reveal the setup button.
  1. Hit that button to show *Options List / # Setup list
  2. Press * to go into options.
  3. Use the arrow buttons or hit 3 to go into CLEAR MESSAGE WAITING
  4. Then hit 3 again to clear the message waiting
This should resolve the blinking light.
Nov 11, 2008 | Astra Meridian 9417 Corded Phone
Tire reset on in ford freestar
Reset without message center:
To reset turn the ignition to the ON position, depress and Trip/odometer
button (located in the instrument cluster) until “TIRE RESET” or
“CHECK TIRE AND RESET” is displayed in the odometer display window.
Once “TIRE RESET” or “CHECK TIRE AND RESET” is displayed,
press and hold the button for three seconds. The low tire warning indicator light will flash three times
as the low tire warning system begins to initialize.
Reset with message center:
To reset turn the ignition to the ON position, press the set up button on
the message center until “SYSTEM CHECK” is displayed. Press the
RESET button until “HOLD RESET TO RELEARN” is displayed, continue to hold the button for three
seconds. The low tire warning indicator light will flash three times as the low tire warning system begins to initialize.
Oct 13, 2008 | 2005 Ford Freestar
Sony FD Trinitron Vega 2004 Stanby Flashes TV will not turn on
This unit shouldb e flashing a repeated count on the standby light. That count will indicate the circuit in which a problem was detected causig the shutdown. Please post that count and we should be able to provide details on the repair.
Thanks,
Dan
Jul 07, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
198 people viewed this question
 Grubhead
Grubhead
