Question about Samsung HP-T4254 42 in. Plasma Television
Samsung hp-t4254 plasma
Started turning on and off by itself one morning. got worse within minutes. after unplugging it for a few hours it doesn't power up at all. help?
thanks Rick
  • 1 more comment
  • moquinn Mar 09, 2009
    same problem.  Any luck?
  • sharon kennedy Apr 18, 2009
    same problem....started 2 weeks ago. Today is April 16, 2009
  • dslwill May 02, 2009
    All of the sudden my HPT4254 samsung plasma will shut off and then on, like i set it to sleep mode, but i didnt even touch slep mode, it has been doing it quite often.
    What is happeneing is that the capasitors are swelling because i have been running it alot, day and night. if a plasma runs all the tim, it gets hot and stays hot, so the capasitors work hard and it swells and bulges.
    Remember Folks, you have a 2 year in home warrenty with samsung plasma televisions. so i am just going to honer the warrenty and save up for another television. i think i will go with a Sony LCD. The Bravia 2 engin is Superb in fast movements. like a plasma, or a L.E.D, L.C.D.
    As for plasma, i dont recomend getting one if you are going to be running it almost 24 hours a day 7 days a week
    I hope this has been helpful
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 11 Answers
Hi Rickpo:
After installing the $11 kit and the additional $13 kit recommended by (http://preher-tv.blogspot.com/2010/01/samsung-hpt4254-no-power-repaired.html) mostly surface mount diodes (also available on Ebay), the Samsung HP-T4254 came back on, but would only play for 4 minutes. I found DX801 flowing both directions, replaced it with a diode from Fry's. Works great, $26 total repair costs :-)
Posted on Aug 15, 2014
  • 1039 Answers
SOURCE: Powers off after several minutes
Check and replace swollen capacitors in power board.
Posted on Apr 25, 2009
roety
  • 585 Answers
SOURCE: HP-T4254, 2years old, turns off and on by itself,
Hi my name is Roety,
I hope I can help you with your issue ,
Sounds like you need a new mainboard.
Make sure you match it with the correct model/version number
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Posted on Sep 30, 2009
  • 50 Answers
SOURCE: My samsung HP-T4254 shuts itself off and turns
check tv battery- remote.
Posted on Oct 13, 2009
  • 63 Answers
SOURCE: HP-T4254 samsung TV turns itself off and on
Try this step before purchasing power supply. I have serviced this tv before. Lay it flat plug it in and it should turn on,but once you sit it up straight it will turn off. I think there are faulty fairchild mosfet transistors or a firmware issue. I put a 1 inch thick book under the stand so it tilts up or down. I have not had a call from any customer since.
Posted on Jul 04, 2010
  • 26 Answers
SOURCE: can't get my samsung hp-t4254 42" plasma tv to
make shure that the computer is set up to display on the screen. To check and see right click on your desktop, click on the option that says screen resolution, and then change your settings from their. The tv will not register that you have a computer plugged into it if the computer is not sending the tv a signal.
Posted on Mar 05, 2011
I hace a samsung flatscreen that the screen flickers with no picture and turns itself on and off.
Hi this is a power supply issue. Your power supply is not strong enough to power your tv anymore.
You can get get parts for this tv at www.interliquidparts.com
Nov 19, 2011 | Samsung HP-T4254 42 in. Plasma Television
I have a hp t 4254. it randomly turns itself off
There can be several causes for this, few of which you can do anything about. However, a few things to try:
1) Replace the batteries on your remote control.
2) Try resetting the logic functions on your tv by unplugging it for a minute, then plugging it back in.
3) Try covering up the infra-red receptor on the front of your TV to see if you're getting unwanted signals from the receptor. taping a piece of foil over that area is perfect. If it doesn't stop after doing these two things you'll probably need to take it to a shop.
4) If this does stop it, then look for unexpected signal sources. Have you added a remote control extender? Added a new device to your audio-video system? Changed to a new remote?
I hope this helps. Joe
Dec 23, 2009 | Samsung HP-T4254 42 in. Plasma Television
Samsung plasma mode HP-T4254 turns off by
POWER SUPPLY BOARD IS FAILING, COMMON PROBLEM. CAN CALL 1-800-SAMSUNG FOR NEAREST SERVICE CENTER.
Dec 10, 2009 | LG 50PX1D 50 in. Plasma Television
Me too. Same ''clicking'' problem with Samsung Plasma HP-T4254.
Replace swollen capacitors on the power board.
Dec 04, 2009 | Televison & Video
HP-T4254, 2years old, turns off and on by itself, started occasionally doing and recovering by itself, now, have to keep it unplugged as it does it from the git-go.
I will reply asap
Thanks
Sep 30, 2009 | Samsung HP-T4254 42 in. Plasma Television
Apr 24, 2009 | Samsung HP-T4254 42 in. Plasma Television
Samsung 42" Plasma HPT4254
THE ONLY SOLUTION I FOUND WAS TO CHANGE THE POWER SUPPLY CARD INSIDE. WHICH IS NOT DIFICULT AT ALL
Oct 21, 2008 | Samsung HP-T4254 42 in. Plasma Television
Samsung HP-T4254 42 in. Plasma Television Logo
150 people viewed this question
Jerry Greenberg
Jerry Greenberg
