Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Printer epson CX7450
There are white vertical lines in between the printed black words running down the entire page
    Problem Solver:
  • 37 Answers
Hi altashll,
Printers can be such a headache. Your problem could be one of two things.
Change the Ink
First, your printer may just be low on ink and the cartridge needs replaced.
Clean the Print Head
If you are having the same problems after replacing the cartridge, you may need to clean the Print Head. This is easier than it sounds. All you have to do is press and hold the Stop button for at least 3 seconds until the On light starts flashing. Then release. You will hear the printer making quite a racket, but the cleaning should only last 1 minute (do not turn off your printer during this process or you may damage it permanently)
Good luck.
-SHG
Posted on Jan 13, 2009
Print problem sir in 2420L
In the process used printer, will be inevitable printed page by your printer have the bad quality prints. For example: Toner specks, Light image, Vertical line, Dropouts, background, Toner smear, Vertical black line and band, Vertical white line, Background scatter, Black pages, Loose toner, Horizontal stripes, Ghost, Uneven Density, poor fusing.
Happy with us Dial Epson Printer tech support phone number 1-877-778-896 for technical support of customer executive regarding with the Epson printer, if your printer is not connected with your PC & Laptops, Don't worry, dial our Tollfree 1-877-778-8.9.6.9 and get better and feasible solution of your issues within a time in the USA.If you want more information regarding with Epson n printer visit us:http://printertechnicalhelp.com/epson-printer-technicalhelp.html
Nov 25, 2016 | Office Equipment & Supplies
I get a thick vertical black line/margin down the entire page when i scan on my SX115
Please make sure the scanner flatbed is clean.
You can also try to copy and see if it happens on copying.
If it does, then your printer needs servicing.
Dec 04, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Change black ink and now prints with white lines through the words on every other line
It is CLOGGED print-heads that cause the ink to _not_ be sprayed onto the paper, resulting in "white" horizontal lines.
Run a "print-head-cleaning-cycle", using the Epson software installed when you installed the printer.
Aug 28, 2010 | Epson Stylus NX100 InkJet Printer
My Epson cx7450 ran out of ink a while ago. I
Did you remove the cartridges when it went out of ink? If so, the printer head is clogged. Anyway, If you didn't remove the cartridges and the "a while ago" means "Long time ago", is more likely the printer head is clogged. You may need to run the "cleaning printer head" feature from the printer or replace the printer head.
Inkjet printers should be used frequently to avoid this issue.
Sep 06, 2009 | Epson Stylus cx7450 All-In-One InkJet...
Printer keeps printing lines across the page of 1
Width of head sprayer (head output) of black is about 1". Check nozzle. It might be some point of head spayer distort. See check nozzle ouput. There are tranversal and vertical lines that represent same point of head sprayer. Is the output perfectly straight and no clog at all? Do head cleaning procedure.
Aug 21, 2009 | Epson Stylus C84 InkJet Printer
MY PRINTER IS NOT PRINTING CORRECTLY
you need to use the head cleaning tool in the printer properties, youll need to keep running it untill it runs clear and it uses alot of your ink while it does it.
youll find the cleaning option if you go to your
start/settings/printers and faxes, right click on your printer and go to printer preferences then maintinence
Apr 16, 2009 | Epson Stylus cx7450 All-In-One InkJet...
How to use only black cartridge on cx7450 epson !
Hi, this is not a solution because I don't think there is one apart from buying new inks. You need to consider 2 things, firstly the official line: Epson (and all other inkjet manufacturers) do this to prevent the coloured print head nozzles from getting blocked. If they are not used for a long time the ink dries up and blocks the nozzles. Epson recommends printing at least once a month with all colours to prevent this. Whenever the printer is turned on it performs a head clean, this is why the coloured inks get used over time even though they are not used for printing. It is also why the "print in Black only" option (available on some printers) only works when the coloured inks are OK.
The 2nd unofficial line is that it is a win-win situation for manufacturers. Firstly they get to cut down on costly warranty call outs for blocked heads (replacement printers, technician manhours, etc) and secondly they get to sell lots more inks (Ka-ching!). If you really want to print black text only (and save cash on price per-print) then a mono-laser printer is the best way as they can now be bought at inkjet prices.
Apr 06, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Vertical lines
1. Took out the ink carts and cleaned the copper contacts of both the ink carts.
2. Clean the copper contacts on the ink carts slot in the printer and then insert the ink carts in the printer and then print out the page.
Dec 11, 2007 | Epson Stylus C60 InkJet Printer
Printer ignores white space at beginning of document
by dragging the black bar on the left with your mouse when
the cursor changes for resize
Nov 30, 2007 | Office Equipment & Supplies
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
488 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
