Question about Conia DVD8500 DVD Player
Conia CCD4501 cloths dryer not blowing hot air anymore
I have a Conia CCD4501 cloths dryer which has stopped blowing hot air . It blows cold air only on the hot air cycle. The dryer still operates fine, but doesnt have hot cycle anymore. The cold cycle light is operating ok when switching between cold and hot ,so I thought the turn switch is Ok.
  • 1 more comment
  • brendan h Jan 14, 2009
    Thanks this will help me.
  • candice82 Feb 11, 2009
    I have the saem Dryer and today its doing the same. Towels for on for hours and nothing, still as wet as when i first put them in.
  • shanza Apr 03, 2009
    i have the same problem with my dryer Conia CCD4501 - where is the element located on this machine
    Sergeant:
  • 227 Answers
If you can turn it on and have the door open, hold the door switch in and see if you have a glow from the heating element. If not, your element is broken. That is if it is an electric dryer. If it is a gas dryer you need to check the pilot light or the thermo sensor.
Posted on Jan 13, 2009
I have a Conia CCD4501 dryer and I bought it second hand and I am happy with it except I don't understand why there is so much lint stuck to the dry clothes. The lint catcher has lint in it but there is a lot of lint around the door opening.
Posted on Apr 06, 2010
Remote for the Conia M250 has stopped working. Can we get replacement remotes?
Follow this to order a new one
http://www.conia.com.au/service.html
Jun 07, 2011 | Conia Televison & Video
Slow to read then says incorrect disk
These get full of dust and then the laser light inside or the light detector does not work well. Try blowing into it just to move the dust around a bit - maybe it will start working.
If you have a can of compressed air (e.g. airDuster), blow that in. Make sure you do not tip the can upsidedown (or even sideways) or you will blow out the liquid in the bottom of the can.
Unplug your equipment before you start - some brands are flamable. The others are greenhouse gases and not too good either.
In any case, if you blow liquid into the unit, the liquid will get very cold when it evaporates and leave a wet residue from the frozen humidity in the air. Just leave the unit alone for a few hours and let the cold liquid evaporate, the moisture dry and warm back to room temperature. Then try it again.
You can also try vacuum or simply shaking it gently while holding it disc loading side down (with drawer open).
Good luck getting rid of the dust.
Mar 15, 2010 | Toshiba SD-V394 DVD Player/VCR
After i insert DVD it reads then say HO2 then STOP= how do i fix this
You will need to get a can of the compressed air or use an air compressor if you have one. Then remove the housing cover if you can and use the compressed air to blow out any dust and debris inside the unit. Also blow air into the inside of the dvd tray. This has been the common fix for the HO2 error on your DVD player. You could also use a DVD lens cleaning kit.
Nov 02, 2009 | Panasonic DVD-RV31 DVD Player
I just bought a Philips DVP3982 about 3 months ago and it has quit working. It does not recognize any of the DVD's that I insert. I have made certain that DVD's are inserted correctly, tried to repower a...
Since it's a fairly recent model and it's very close to the original factory warranty i will recommend contacting the customer service dept. at philips to get it replaced or repaired. The problem might be in the optical unit or circuit related to it. you might want to make sure of the obvious, before, like checking that you did not activate the parental block,or moisture on the optical unit, the factory recommends leaving the unit powered on for an hour, but if you you have a hair dryer set it to cold dry and blow air inside the disc drawer, a coupple of minutes should do it.
Sep 01, 2009 | Philips Televison & Video
Govideo player dv-2140
Ususlly "sticking and "stopping" is caused by only a few of things. (1) make sure the dvd/cd is free of smudges and scratches. (2) Make sure the laser eye is clean of dust or smudges. Turn player OFF, blow across eye, if need use soft dry Qtip and carefully wipe eye, blow away any loose fibers left from Qtip. Do Not try to clean with any cloth material. (3) OR your laser assembly may be sticking and not travelling smoothly. Do Not try to repair this yourself, find an electronics qualified person to check and clean this assembly.
Dec 28, 2008 | GoVideo Televison & Video
DVD player and CD player stop reading discs.
try opening the Drive Trays, and hold a hot air dryer about 2-3 feet away for about 15-20 Minutes, Aim the dryer towards the opened trays. close the trays reboot the computer.
If still not working, i,d suggest putting a laser head cleaner in, and getting some more heat for your House.
Computers do usually tend to function much better at Room Temprature.
Hope this solves your problem.
Mike @ Compurepair.
Feb 22, 2008 | Televison & Video
Firmware for conia 160gb dvd recorder
sir try this link! http://www.dtvforum.info/index.php?showtopic=32172&pid=632554&st=40&#entry632554
Apr 06, 2007 | Conia DVD8500 DVD Player
Panasonic LA95
You bought it on Ebay ! ! Why did the seller move it on...
I suspect that the decoder is getting 'hot' - same principle as the processor on your PC.
If you are able - I would suggest opeing the unit up (so that the main board is visible) but still able to power up.
Obtain a hair dryer that has a 'cool' blow on it. Start your unit up, while blowing with cool air - this will identify if this is thermal related...
Sep 07, 2006 | Panasonic DVD-LA95 Portable DVD Player
Televison & Video Logo
530 people viewed this question
Top Conia Televison & Video Experts
Tom Chichester
Are you a Conia Televison and Video Expert? Answer questions, earn points and help others
