Question about IBM ThinkPad T23 2647 Notebook
When you power up the t23 2647 its vry very dark
When you power on , you can hardly see any thing till you shake the screen , and then it will light up properly
    Problem Solver:
  • 8 Answers
Your inverter circuit board or its connectors/cables to display are fault. You should better take your laptop for repair.
Posted on Jan 14, 2009
Samsung TV won't turn on after lightening storm. Surge protector "sparked once, but all the other things plugged in are operating.
Contact your insurance company and make a claim. Lightning damage to electronics like that is hard to repair.
Aug 07, 2014 | Samsung LN Televison & Video
On acer aspire laptop screen is grey at startup
1. When you press the power button to turn it on, do you see any thing on screen, It probably should show an ACER logo?
2. Can you see a faint image of your desktop (try to see it in dark place with flash light). If you do see a faint image it could mean your back light is broken.
3. When you press the power button do you get different LED's lighting up on the laptop? IE power LED, hard drive LED?
4. Does your computer give you any random beeps when it starts up?
Please answer these questions and I would be more than happy to work through this with your.
Thanks RCCT
Jan 16, 2014 | Acer Aspire Computers & Internet
Laptop cursor dark screen
can you tell me more about this situation, i build and troubleshoot computers all the time but this question needs more detail. you say laptop dark screen blinking cursor, the only thing i can get out of that is one thing. while booting up hit the f2 or delete key several times till you get into the bios, then find the tab that says default settings hit save and exit and reboot it, but more information would really help me to help you,
Nov 10, 2012 | Dell Latitude D620 Laptop (Latitude-C620)...
Every one says that pulsars engine is bad it has power perfomance but the won't last!
no nt at ol....pulsar engine are vry good.......if u drive ne bike vry hard it ll show problems.....
Dec 16, 2010 | 2007 Bajaj Pulsar 180
MY TOSHIBA LAPTOP SCREEN WONT STAY ON IT IS ON FOR A SEC THEN I CAN HEAR A HISSING SOUND THEN IT GOES BLACK, IF I LOOK AT IT HARD OR TILT IT I CAN SEE THE IMAGE, HOW CAN I FIX THIS PROBLEM?
either your lcd inverter is going out,,or your backlight,,being that u here a hissing noise I would think that sounds to be your backlight is going out though,,,thats the lights that brightin the lcd from the inside,,,can be fixed not vry hard to do,,
Nov 08, 2010 | Computers & Internet
Compaq V3424au that has a blank screen on startup with all lights
You could have a defective LCD screen, If the laptop appears to be booting up and running and the hard disk is spinning and the hard disk LED light is flashing but the screen is dark then, to determine if you have a LCD screen or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jun 23, 2009 | Compaq Computers & Internet
Screen dark,wont stay on. 52hm95
Here's the online manual for your TV:
http://www.tacp.toshiba.com/tacpassets-images/models/42HM95/docs/42HM95_om_e.pdf
Read the section about the red/green lights in front. It sounds like the lamp went out. Mine consistently goes out once every year to year and a half. If you plan on keeping the television, purchase two bulbs, so you have one on hand in case your new one goes out.
Good luck.
Apr 19, 2009 | Toshiba 52HM95 52" HDTV Projection...
Dark Screen
The back light is bad in your monitor. This is the light source that gives light to the image on your screen so that you can see it. This is a common thing to go wrong with a laptop. You can take it to someone to be repaired or if you are handy you can buy the part and replace it yourself.
Jan 18, 2009 | HP Compaq Presario 2200 Notebook
Toshiba satellite m40 booting problem.
Hi! It appears that possibly your hrad drive isn't set properly in the caddy? with the laptop powered down and disconnected locate the hard drive cover pop out the two locating screws and carefully move the caddy/hard drive BEWARE as the drive has fragile pins at the opposite end where you opened, hopefully little sliding pressure should remove. Check the retaining screws around the caddy (You'll need a small torx/philips screw driver for this) if all tight replace gently.
If you are uncertain I would recommend a technician check it for you.
Good Luck!
Paul 'W'
Onyer~EDson(:0)~[><
Dec 09, 2008 | Toshiba Satellite M40-S417TD Notebook
System on but screen dark
I had this problem with my Dell laptop as well. It may not be the solution, but if your laptop is older, the LCD power inverter may be burnt out. If that's the case, it's about a 50 dollar fix. See if you can take a flash light to the screen and if you can see what's on the screen, but it's very dark, this LCD inverter may be the problem.
Dec 09, 2008 | HP Pavilion dv1000 Notebook
IBM ThinkPad T23 2647 Notebook Logo
61 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
