Question about Philips CDR600 CD Recorder
My CD Recorder is not reading my blank discs. What can be the pro
Pleas ecan you help as my philips cdr 600 used to record blanl audio cdr but now it will not..the player always says insert disk after the disk is already in....what should i do ? do i need the players laser need realigning ?if so how do i do that ? please inform asap as iam going crazy !!!!
thanks
Hi not sure if this helps but some disc ,s ive used on my 500s won,t work either so i changed the type of disc and it seems to do the trick i think some disc,s just aren,t good enough ie cheap ones .
Posted on Jan 13, 2009
When u put a blank CD in it will say blank disc when you push REC. it will say Data disc and with a different CD it will say -79.59 e-mail me at j.smedley@moreheadstate.edu
I think your problem is that you are using a blank CDROM type disc in a CD Audio recorder. If you "burn" cds on a computer, it does not matter what type of cdr you use, but if it's for a stand alone CD Recorder (that you ise with hifi/dj stuff) you MUST use CDR AUDIO discs (sometinmes it will even say FOR MUSIC)
Sep 07, 2010 | Sony RCD-W500C 5-Disc CD Recorder
My cd recorder wont read blank cds help me please
Do as it asks, insert blank CD-Audio or CD-Music media.
Discs for recording
For recording, make sure to use special audio discs only.
These discs are marked with “Digital Audio” and the logos shown below.
There are two different types of audio discs for the use on this CD recorder:
– CD-Audio Recordable (CDR) discs
These discs can be recorded on once and
play in all standard CD players and CD
recorders, when they are finalized.
– CD-Audio ReWritable (CDRW) discs
These discs can be recorded on, erased and
re-recorded many times and play in CDRW
compatible CD players and CD recorders,
– All Philips CD players and CD recorders
with the sticker shown here are CDRW
compatible.
To ensure proper working of the set we recommend the use of Philips audio CDR and audio CDRW discs only.
Note: Do not use a computer CDR or CDRW as recording will not work!
Go here and download the manual. You'll need it.
http://www.p4c.philips.com/files/c/cdr602_00s/cdr602_00s_dfu_eng.pdf
Mar 04, 2010 | Philips CDR602 CD Recorder
When i put a balank cdr the recorer says wrong
Listen to it. Go out and buy "CD-R for AUDIO" or "CD-Music" blank CD's and it will cooperate. Home CD recorders are designed to reject data CD-R media for recording.
Jan 22, 2010 | Philips CDR775 2-Disc CD Recorder
My philips cd recorder is not recording
the recorder philips cdr-778 put my 80 min sony cd-r audio in it start recording 20 second on track 1 go to track 2 for 20 second then stops goes to update some times it reads no disc when installing the disc we have been recording at the Church for the past 2 years
from clyde
Mar 02, 2009 | Philips CDR778 2-Disc CD Recorder
Not reading blank cdr audio disks to record onto..
Will it read audio cd's? Sounds like you need a new laser unless you have access to a philips COMPair system to diagnose / realign it.
Dec 12, 2007 | Philips CDR600 CD Recorder
Won't record
I've just spoken to a friend who also has one of these older Philips recorders & he has the same problem.
As per my previous post, he fixed his problem by locating old stocks of blanks. New audio discs seem to have been manufactured & optimised for fast writing speeds (up to 32x speed) & this is causing the problem (you can't write at x1 or x2 speed to these new speedy discs).
Trying a few different brands of discs to try out is a whole lot cheaper than a repair. I suggest when you find a brand that works, you stock up on these discs as it seems they will become ever rarer.
Dec 11, 2007 | Philips CDR785 3-Disc CD Recorder
RECORD DROP OUT
Just bought this CDR 570 and not use yet.
Reading the instruction manual - yes, life experience has taught me some really useful stuff! -
Under 'Discs for recording' on page 7 it says at end of section
IMPORTANT:
To ensure proper working of the set we recommend the use of PHILIPS audio CDR and audio CDRW discs only'
Roughly translated I read this to me - 'don't blame us if the set don't work using other (non-compatible) discs' !!
Oct 02, 2007 | Philips CDR570 CD Recorder
Open Questions:
Philips CDR600 CD Recorder Logo
363 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
