Question about Sony One-Point ECM-MS907 Consumer Microphone
Problem recording in stereo
My ECM-MS907 microphone only records in mono. I'm using it with a Sony MZM10 minidisc recorder. It works fine with the ECM-DS70P mic that came with the recorder so I think the ECM-MS907 might be broken. Does anybody have experience with the same problem or any other idea what the problem might be? I've tried chancing the batteries.
    President:
  • 3,130 Answers
Most likely you have a problem with the MIC. Has this ever worked with this unit? If not maybe the un it is not compadable with this Mic. The instuctions and specs are available for download Here http://esupport.sony.com/US/perl/model-documents.pl?mdl=ECMDS70P&LOC=3 Good luck
Posted on Jun 13, 2007
I have a Sony JA3ES it want record in analog inputs.everything else works what would make this quit working.
I'll give you my best guess since I sold my JA3ES and am doing this from memory. Check your analog connector cables are good, be certain you have the input switch set to analog input.
Be certain you are not setting your inputs for the microphone jacks. If you are getting the error message din unlock the recorder is not getting the signal from the analog source.
It is possible to have damaged analog inputs on a used machine, but you have micorphone jacks and might get adaptor cables to hook your analog inputs in through the microphone jacks. Note this machine is old enough the microphones are 2 mono microphones left and right. If you want to use a modern stereo microphone you need an adaptor cable for that too.
If you try the above be careful as the mike jacks are really for mikes not what I mention, but it is a probable go around if your rear analog jacks are damaged for some reason.
Jan 11, 2012 | Sony Audio Players & Recorders
When I record vocals with stereo setting it always records left more in favour of the right. Is there a way to fix this?
Your microphone is a mono input (one), therefore recording in stereo is not practical. Stereo inputs are left and right (two inputs). Whatever your recording setup or audio workstation, the track you record to from your microphone needs to mono.
Jun 29, 2011 | Samson C03U Professional Microphone
AKG Perception Microphone ony recording in mono but want stereo.
I have similar problems with inputing stereo sound. How do you know your mic port on the PC is set for stereo? What kind of a cable are you using? If it is an XLR, the connection is pure mono. Maybe you need a TRS cable, which looks like a 1/4 inch jack but is really stereo. Maybe you need a stereo mini. Usually a cable mismatch is the problem. Is your phantom power supply passing stereo? All the ones I have seen are mono. You may need two. Is your sound capture set for stereo? Are the input level controls set correctly for equal volume on left or right channel? I would try the mic with a regular amplifier to insure both channels are working. Then trace the signal from mic to power supply and power supply to computer.
Dec 03, 2008 | AKG Perception 100 Microphone
Unable to record with external microphone
You may have ruined the phantom power source in your minidisc recorder. XLR microphones use a 48 v power supply.
Sep 25, 2008 | Sony Walkman MZ-B3 Personal MiniDisc...
Left channel only
If you take it to a store then you can probably have it sent to sony who will give you an estimate before fixing it. This mic offers one of the best cost performance ratios so you will probably end up buying another one. Upon that assumption, ifthe repair quote is less than about 70% of the retail price then it may be worth getting it repaired. I have found sony repairs (to a digital camera) to be reasonably priced.
Sep 03, 2008 | Sony ECM-MS907 Professional Microphone
IT DOES NOT WORK ECM-MS907 Professional...
Just in case you have having the same problem as me....
The reason why my microphone was giving mixed results was because I was using the wrong setting. The microphone slider says "90 degrees" and "120 degrees." I assumed that these angles refered to the area that the microphone picked up. So for a single narrow sound source, like my voice, the narrower, 90 degrees setting seemed appropriate.
Now that I have looked at the manual I see it is the reverse (weird but true. Perhaps the angles refer to the angles that the microphone ignores completely under each setting?).
I have been recording my voice. I noticed that sometimes the sound was good and other times the sound level was too low. I think that the reason is because sometimes I inadvertantly set the microphone to the 120 degree setting, which picks up my voice well, while at other times I set the mic to the 90 degree setting which attempts to pick up sound from a wider area, giving the central source less prominence.Setting the microphone to the 120 degree setting cured my problem. I hope it cures your problem too.
The manual is here:
http://www.docs.sony.com/release/ECMMS907.pdf
Aug 24, 2008 | Sony ECM-MS907 Professional Microphone
Playback only on left speaker
The quick, easy solution is to change your microphone to mono recording. In the attached YouTube clip, I'll show you how to do that.
The short and simple is to go to your Mac HD -> Applications -> Utilities -> Audio MIDI Setup. Select your C01U USB device, and set it to 1ch 16bit. This will set the microphone to record in mono, equally over both speakers.
Nov 26, 2007 | Samson C01U Consumer Microphone
Recording issues
My first guess would be that the minidisc player does not provide enough power for the mic. I believe Sony makes an external battery pack to compensate for these problems. Hope this helps!
Sep 08, 2007 | Sony ECM-DM5P Consumer Microphone
Problem recording when connected to computer
In the volume control panel look for mic boost and tick the box to boost the microphone volume. It's under options properties/Advanced controls etc.
Apr 13, 2007 | Sony One-Point ECM-MS907 Consumer...
Sony One-Point ECM-MS907 Consumer Microphone Logo
140 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
