Question about HP Officejet Pro L7580 All-In-One InkJet Printer
Online it worked fine but now it wont go online im usen 2 computers and 1 printer how do i turn the printer online
    Novelist:
  • 159 Answers
My printer won't print from computer to printer
hi there,
1- go to your printers folder and make sure the printer is online and your P4350 is set as default (checked).
2- If offline, right click on the printer icon and try to switch it back to online. The same to make it default in case it's not.
2- Once online, then right click on the printer icon again , go to properties and then try printing a test page from windows (I am assuming you are running Windows)
3- In case you were not able to bring it back online, turn off the printer, turn off your PC, reseat the printer cable connection between the printer and the computer (both ends), then turn the printer and the computer back on.
Jun 26, 2011 | Lexmark P4350 All-In-One InkJet Printer
Printer stoped printing says offline
follow following steps
1) check if your prnter is getting power properly
2) if you are using network printer(printer at some other computer) check if computer with which printer is attached is working fine.
3) if all above things are fine power off printer and power it on.
4) right click on printer in control pannel printer, you will see online click on online and it will be done.
if you find any issue let me know
Sep 30, 2009 | HP Photosmart C7280 Laser Printer
My printer flashes an E and 5 can't get it back online says something about my color cartridge when I press print on the computer
1. Went to "Properties" on my printer,
2. "Maintanance" tab
3. Selected "Bottom Plate Cleaning"
4. Got the "pop-up" telling me about the problem with the ink tanks
5. I then opened the printer, and re-seated both ink tanks"
6. Clicked the "Enter" button to Cancel Printing, and that seemed to turn off the E5 errors.
7. Then I printed a full page of pictures, and everything works fine.
Jul 13, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
HP photosmart C5280 document stuck in print que
Delete document manually from the path mentioned below:
1) Press windows + R an then type spool
2) Go to PRINTERS folder.
3) Delete the files present in there.
If not able to delete then
1) Open command prompt.
2) type "net stop spooler" and then delete the files
3)Again type "net start spooler"
Your stuck document is now cleaned. You can start printing your document again.
Mar 30, 2009 | HP Office Equipment & Supplies
Printer wont switch on
hi im josh in cebu phils. may i help you friend? Friend such problem occurs when there is a shorted parts inside.it doesn't turn on for now because built I.C. of printer and pc has an auto shut off lever that automatically shuts of every-time time the board has an unusual problem especial short circuit. Friend  1.try to check the connections of the power chord be sure it is not shorted. 2.Check the power switch button of the printer maybe there's something stuck on it that makes the connection shorted or faulty. Good lcuk friend hope i helped you.
Mar 14, 2009 | Canon PIXMA MP760 All-In-One InkJet...
Can't get printer online
1)uninstall driver software.
2)conect the machine to pc and turn it on.
3)find the machine is detected by pc.
4) if detected by pc ,install driver.
5)if it is not detected try another cable,another port.
Dec 22, 2008 | Office Equipment & Supplies
Epson r 285
Greetings,
Try this SSC Service Utility.
Also try changing the affected ink cartridge.
All else fails, your printer will require service.
Keep us posted and thank you for using our service.
FixYa for all your troubleshooting needs.
Jul 05, 2008 | Office Equipment & Supplies
Printer
Try this:
1. From Control Panel > Printers... delete all printers.
2. Unplug the usb cable.
3. Re-boot
4. Install software
5. Plug in usb cable.
Hope that works for ya...
Geno
Feb 27, 2008 | Lexmark Z645 InkJet Photo Printer
Must Reinstall to Print
Most USB printers need to have the printer driver installed before you connect the printer to the computer, did you install the printer this way?
Also, check and see if it is the default printer.
If those do not work:
1) Turn off the Terminate and Stay Resident programs MSCONFIG in VISTA.
2) Disable HP device discovery service.
3) Uninstall the All-In-One software.
4) Turn off firewall and antivirus.
5) Reinstall the latest software for the All-In-One.
Hope this helps.
Please let me know how this works for you.
Jan 30, 2008 | HP DeskJet F380 All-In-One Printer
Paper wont load
Please check the following items:
Check item 1:
The cable may not be securely connected between a printer and a computer, or be about to be unconnected.
Check that the cable is securely inserted into the ports of the printer and the computer respectively.
If a USB hub is used, connect the printer and the computer directly.
Check item 2:
Print jobs may be queued.
Delete the print jobs queued in the computer. How to delete the accumulated and queued documents in the computer (Windows)
Check item 3:
The computer settings may not be corrected.
Check the computer settings. How to confirm the computer settings (Windows)
Jan 14, 2008 | Canon PIXMA iP90 Mobile Printer
HP Officejet Pro L7580 All-In-One InkJet Printer Logo
54 people viewed this question
Seeker5211
Seeker5211
