Question about Maytag Neptune MDE5500AY Electric Dryer
Lint is collecting inside the housing not exiting via vent.
I need to be able to get inside the dryer in the back so I can re-attach the connecting vent tubes /hoses (the parts which when connected carry the lint and moisture out and away to the exhaust flap on the outside of the house. When I took off the hose where it connects to the dryer, I found the other that the hose has to be connected to just laying inside loose, and handful after handful of lint.
There doesn't appear to be an obvious panel or door to gain access to the interior of the housing so I can see what I and where to re- attach the parts correctly.
  • repo4u Feb 08, 2009
    i have same problem and along with the lint mess it gets hot and shuts off
    President:
  • Maytag Master
  • 2,651 Answers
You would need to remove screws holding on the door as well as the opposing screws , after remove th edoor the front "u shaped" panel will pull foward and off, yo may be able to acess the venting from this point
Posted on Jan 14, 2009
Theres a problem with the drier as dof theres never any water in the tray anymore , and the drier is filling with fluff, takes ages too dry anything , what do you recommend plerase angela
Check your exhaust line and lint filter. Go outside and locate on the wall where the dryer exits the house. If you can, feel around the inside and clear the exhaust of any lint or debris. Next, check the lint filter. If it's packed, remove all lint from it and clean with mild soap and water. Put the filter back in it's place. Turn on dryer's normal setting that you most commmonly use and star dryer. Go back outside to where the dryer vent exits the house. Place your hand over the vent. You should feel hot air coming out at a pretty decent rate.
Jul 09, 2011 | Hotpoint Dryers
Dryer rotates but doesn't heat. Does it need a new heating element and if so is it easy to replace.
Our laundry room is in the center of the house and the dryer vent runs underneath the house and every 6 months or so we have to run a plumbing snake all the way through the vent pipe. Once it all the way through the house we then tie a rope to the end of it with a huge knot tied into it, we then snake the rope through the pipe and it pulls out all the lint that has collected inside, someone at each end of the rope (make sure it's long enough) and run it back and forth until no more lint is collected. I hope this might help you
Apr 14, 2011 | Dryers
GE Profile Prodigy DPR483GAOWW takes 2-3 cyles to dry. Have cleaned lint trap still no success
Our laundry room is in the center of the house and the dryer vent runs underneath the house and every 6 months or so we have to run a plumbing snake all the way through the vent pipe. Once it all the way through the house we then tie a rope to the end of it with a huge knot tied into it, we then snake the rope through the pipe and it pulls out all the lint that has collected inside, someone at each end of the rope (make sure it's long enough) and run it back and forth until no more lint is collected. I hope this might help you.
Mar 19, 2011 | GE Profile Prodigy DPSR513GA Dryer
Dryer is taking too long to dry
Dryer needs to be cleaned. Unplug, take off back and vacuum all lint out of dryer, also take off vent and vacuum inside of vent area. Then clean dryer vent from inside of house to where it exits. Make sure all lint removed. Lint holds moisture and causes dryer not to be able to release steam caused by heating wet clothes, thus clothes don't dry.
Jun 09, 2010 | Kenmore 66972 Dryer
Why is lint collecting inside my Duet dryer? It is outside the drum and between the housing. The lint collector has little or no lint after drying. I have checked and cleaned the hose from the dryer to the...
take the lint filter out and put your hand in it,turn the dryer on,you should feel a stoung air flow sucking in,if not your still have a clogg somewhere
Feb 05, 2010 | Dryers
Why won't my Dryer "start"? Could it be the "start" button? It flashes "lint filter" even after I have cleened the lint filter, the hose in the back and used my leaf blower to blow out any lint in the vent...
HELLO THERE
Here is the most common things that will make a dryer not work and will need to be checked
Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Jan 09, 2010 | Bosch Nexxt WTMC 3300 Electric Dryer
I have constant lint buildup in the exhaust pipe. Why isn't the lint trap catching it?
No lint trap catches ALL the dryer lint. Some small particles of lint are always exhausted through the dryer exhaust along with warm moist air as your clothes dry. In a perfect world, this lint makes it all the way to the end of the dryer exhaust and exits your home. However, if you have any kinks, excessive bends, sags, or excessively long ducting runs, the can create choke points for lint to accumulate. This creates resistance and makes and condensation forms inside the dryer vent. With condensation, comes areas where lint can accumulate. Once the lint accumulates, it begins to collect moisture. As it collects enough moisture, it will act as a sponge and collect more lint until the dryer becomes completely clogged. Left in a clogged state, the dryer begins to overheat and dries less efficiently. You may notice longer dry times or an excessively hot dryer. Eventually the dryer heating circuits will fail. This can also become a fire hazard if the lint becomes so backed up that it begins to collect on, or near, the heating element.
If you have not checked the dryer ventilation any time recently, now may be a good time to do so. I recommend checking it about once per season to ensure it is not obstructed. Make sure you are also using the semi-rigid metal type ducting. It resists crushing, kinking, resists heat better, and resists rodent infestation.
NOTE: Mice are notorious for building nests inside dryers. Give them a warm place with bedding material and they will make it a home.
Make sure the exhaust vent is at least 12 inches off the ground. This will deter mice and others pests (like snakes or birds) from entering the dryer exhaust from the outside. If you place a cover on the vent, make sure it is of the louvered variety. Do not use screens. They will collect lint and clog easily.
An easy test to determine if you have an exhaust problem is to remove the dryer vent hose from the back of the dryer. Turn the dryer on and allow it to run. The air leaving the back of the dryer should be forceful and warm. If the air flow is weak, you need to check the dryer interior. If the air flow is normal, reattach hose and run the dryer again. This time, check the exhaust vent where it exits your home. Again, the air flow should be forceful and warm. If not, you have a clog somewhere in the ventilation ducting which will require cleaning.
NOTE: If you are using plactic ducting, get rid of it. It collapses easy, rips and mice will chew right through it.
In addtion, many home owners unknowingly will push the dryer against the wall and crush the hose behind it. This will also clog the vent and make the dryer inefficient. Leave about a 1 foot space behind the dryer for proper ventilation and ensure the vent hose does not get crushed. Semi-rigid hose will prevent this from happening.
If you have any questions, please let me know. I have seen this problem many times. Let me know what you find and if I can be of further assistance. I hope this helps you.
Nov 30, 2009 | Dishwashers
Moisture inside dryer door when clothes are drying. Model number DBXR463ED2WW
If you are experiencing moisture inside the dryer drum, then you have a clog somewhere. A dryer needs proper air flow in order to dry efficiently. If you have not had your dryer exhaust vent ducting checked anytime recently, now might be a good time to do so.
HOW TO DETERMINE IF YOU HAVE A DRYER CLOG:
Remove the dryer exhaust vent hose from the back of the dryer and attempt to dry a load of clothes as you normally would. The air escaping the back of the dryer should be forceful and warm (about 140 degrees F).
If the air flow is normal and the clothes dry properly, you need to check the ventilation from the point where it leaves the dryer, to where it exits your home. Check for kinks, sags or significant bends in the vent ducting that may be causing choke points where lint can accumulate. In addition, it is strongl;y recommended that you use the semi-rigid aluminum ducting as it resists crushing and is heat resistant.
If the air flow is weak, then you have a clog INTERNAL to the dryer. The lint screens do not catch everything. Some lint, along with moist air from your clothes gets exhausted through the blower fan housing and out through the ducting. This is normal. Lint can accumulate over time, however. If allowed to restrict the air flow, the moist air cannot escape and tends to permiate the lint with moisture. Once the lint becomes moist, it sticks inside the ducting and collects more lint to the point where it starts to restrict air flow and reduce the dryer efficiency. It is highly recommended that you check your dryer blower fan housing and internal ducting about once per season to prevent this.
If gone unchecked, the dryer will actually overheat to the point of failure. Accumulations of lint is also a major fire hazard. The majority of the dryer failures I have repaired were caused by poorly installed, kinked, or clogged dryer ventilation.
If you have any questions, please let me know. I hope you find this information helpful.
Jul 28, 2009 | Dryers
WILL NOT DRY
Check that the dryer duct at the back where it connects the dryer to the wall has not collapsed to restrict air movement to the house vent duct.
Check that the vent duct all the way to the outside of the house is not fully or partially restricted in any way.
Make sure the lint screen is clean.
Make sure there is no buildup of lint inside the dryer where the heat enter the drum.
You should be able to walk outside with the dryer running, and feel a blast of air exiting the dryer vent. If not, find the restriction.
A dryer warming up, and then shutting down is normally a sign of a restricted vent duct at some point in the system. Particularly if nothing is done, and the dryer heats up momentarily when the cycle is tried again.
Reply back your findings for further instruction or information.
Jan 29, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
75 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
