Question about JVC GR-D270 Mini DV Digital Camcorder
Unable to export video from camcorder to PC
When I connect usb cable to pc from video recorder pc is unable to detect a device being connected to import video to pc to burn dvd
  • Anonymous Apr 27, 2009
    I used the IEEE 1394, the 5 pin, and the 8 pin that I have that will hook into the camera fine, however, it is a universal cord.
    but all I have is the USB on my vista, not a firewire, and I can't find software that will get my computer to notice me trying to upload videos.
Get a 4-pin Firewire cable. Plugs in just below power plug slot. What plug you need on the other end depends on your computer. You can get Firewires in 4 to 4 pin; 4 to 6 pin, and 4 pin to USB. My laptop is configured to take a 4 or 6 pin Firewire but my desktop only has USB. I transfered using 4 to 4 pin and it worked great. No drivers, no discs needed...at least with Vista. As soon as I plugged in the camera, I was asked to whether I wanted to transfer from biginning of tape or at currenty location. I chose from the beginning and the camera automatically rewound and strated to transfer to the PC. I don't know if it would work same way with 4-wire Firewire to USB but assume it would. Cables around $35 but I purchased at Circuit City for the going out of business discount. I also bought some SD cards so I can take snapshots and transfer them too for print.
Get a firewire and you should be fine.
C
Posted on Jan 25, 2009
Can't connect my JVC camcorder to my PC
You need to install the drivers BEFORE connecting pc to camcorder
Jun 22, 2008 | JVC GR-D350 Mini DV Digital Camcorder
How to import files from camcorder to my pc
If you have data cable given to the camcorder connect it with the camcorder and the other end to the usb of pc.Then computer can detect the device ,import files to the computer.Install your camcorder driver before plugging data cable
Sep 06, 2010 | Panasonic VDR-D100 DVD Camcorder
Importing Video to PC with Panasonic SDR-H80
There should be an extra cable that plugs into the battery charger and then into the camcorder to supply power to the camcorder.
Dec 27, 2009 | Panasonic SDR-H80 Hard Drive Camcorder
UNABLE TO DETECT VIDEO CAMERA
You need to use firewire cable. USB wont work.
Get a 4 pin firewire cable and connect to the PC.
Switch on the Cam.
Open Windows Movie Maker and import video from device.
4 pin firewire would look like this:
http://www.pcab.co.uk/ebay/firewire%204%20to%204.jpg
Nov 14, 2008 | Sony DCR-HC30E MiniDV Camcorder
Camcorder as source for video software not found
if you have a nv-gs35 i am pretty sure that ths camera can not do video transfer via usb, the port is not usb2. it can transfer video via the dv port only. please check the operating instructions.
Mar 16, 2008 | Panasonic PV-GS35 Mini DV Digital...
JVC Everio GZ-MG37u Cant Connect to Pc
how to export video from camcorder to windows movie maker because power producer sucks!!!!!!!!!!
Feb 24, 2008 | JVC Everio GZ-MG37 Camcorder
Camera detection by windows xp
Hi, You need to connect the cam and PC using 4 pin to 4 pin firewire cable.  After connecting,
Switch on the cam.  Open Windows Movie Maker and import the video from device.
Aug 25, 2006 | JVC GR-D370 High-Band Digital Video Camera...
Connecting analong camcorder to computer
The only Analog camcorder that has a USB Connection for transferring pictures or video is the SC-L770. The SC-L770 can transfer video (live or recorded) and still photos through the USB connection. You can also transfer audio using the audio cable provided. After installing the driver and software, you can begin transferring data using the software provided. Connecting to a PC 1. Connect a USB cable to the USB port on the PC. 2. Connect the other end of the USB cable into the proper terminal on the camcorder. (USB jack) 3. Connect the audio cable to the Line input jack of the PC. If the PC has no Line input jack, connect the audio cable to the MIC input jack. In this case, however, a noise may be produced depending on the PC. Notes: * If you disconnect the USB cable from the PC or the camcorder while transferring, the data transmission will stop and the data may be damaged. * If you connect the USB cable to a PC via a USB HUB or simultaneously connect the USB cable along with other USB devices, the camcorder may not work properly. * In this case, remove the other USB devices from the PC and reconnect the camcorder. Some other Analog Camcorders have a snapshot mode which allows you to take a still photo with your camcorder. However, you cannot transfer these to a computer unless you purchase additional hardware such as a capture card. Some capture cards have analog a/v inputs which will allow you to use the a/v outputs on the camcorder to connect to your pc and transfer images and video. You can purchase a capture card at most computer and electronics stores. Samsung does not support capture cards.
Sep 06, 2005 | Samsung DouCam VP-D5000i Mini DV Digital...
JVC GR-D270 Mini DV Digital Camcorder Logo
922 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
