Question about Linksys Wireless-N WRT150N Router
Can't connect a laptop wireless to WRT150N
Hello!i'm having a problem with WRT150N router.i have a desktop connected to the same router and it works fine.when i connected my laptop wireless it shows that it is connected and it has a very good signal but i can't go online.meanwhile when i connected the same laptop to another router(my neighbour's router) it has less signal but i can go online.can you give me some advice?Thank you!!
  • dhess62 Feb 06, 2009
    works great when directly connected. Also noticed that if I power cycle the router it will show up briefly in the list of available wireless netowrks then if I refresh the list it's gone.
  • 1,269 Answers
What you can do is remove the wireless connection profile that is saved and create a new one. Go to wireless connection properties and create a new wireless profile. If that doesn't work, what you can try is change the wireless channel of your router to Standard Mode using channel 11 the power cycle the router.
Posted on Jan 13, 2009
  • 104 Answers
Hello... a couple of ideas for you to try:
1. Can you move your laptop closer to your router - as close as possible - and if so, can you connect to your network then?
2. If you can, it's possible your neighbour's wireless signal is interfering with your own.
Try logging into your router via the desktop (assuming this is a wired connection), and experiment with different wireless channels (see this link on the Linksys site for help with this).
See if a different channel strengthens your signal.Channel 1, 6 or 11 are good choices to experiment with.
3. If this is not the problem, try re-entering your Network key. Disconnect from your network, wait about 20 seconds, then re-connect. Re-enter your Network Key. (Sometimes Windows says you are connected when you are not.)
Hope this helps you make a start.
Try turning off the power wait for 30 secs and reconnect the power and check if the LEDs light up again.
To reset the Linksys back to the default settings - Press and hold the pinhole RESET button at the back of therouter with the power ON for 20 secs. then release the RESET button.
To connect to your wireless router, the router's wireless settings needs to beconfigured with the SSID, encryption etc. and also the wireless cards in allthe laptops/computers needs to be configured with these router's wirelesssettings. Then the laptops/desktop computers can communicate with your wirelessrouter.
Connect a LAN cable from the Linksys to the LAN port on your computer.
Open a browser and enter the Linksys configuration URL
The default login = admin
The default PW = admin
You can protect your router by changing the default admin PW (write it down andput it in a safe place)
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-
Sep 06, 2011 | Linksys Wireless-N WRT150N Router
How do I establish complete security of my wireless setup so no one else can access another computer/or see what is on mine. I have a desktop computer with a Linksys Wireless N WRT150N to my laptop in...
In order for you to have a security enable wireless network you can follow the step by step procedure from my TIP on how to secured your wireless network, after doing those procedure your network will be secured and no one can connect to it unless they have the security key for it.
Just go to this link and follow the step by step procedure on how to enable wireless security on your router, just click HERE.
Apr 21, 2011 | Linksys Wireless-N WRT150N Router
I am installing my new wrt150n router and no internet
Turn off modem and router. Connect router to computer. Turn router on. Connect router to modem. Power up modem. When it discovers the modem it will assign to it the new IP address.
Hope it helps.
Sep 25, 2009 | Linksys Wireless-N WRT150N Router
Where do I find the network key for my linksyswrt150N?
This is located under the wireless settings on your linksys. This is something you would have set up when installing the router. If you don't remember or it is confusing.. Change it. I usually use the KTIP security because you can use a normal passphrase that is easy to remember. Hope this helps
Sep 12, 2009 | Linksys Wireless-N WRT150N Router
No wireless connections between WRT150N and Vista Laptop
On the vista laptop, make certain that the firewall is not blocking the wireless connection. Try to turn off the firewall and see if that helps.
Aug 10, 2009 | Linksys Wireless-N WRT150N Router
Wireless network using usb modem
First thing that you have to do is to check if the wireless light on your linksys wrt150N is lit. If it is, then that means that it is emitting wireless signal so you can connect wirelessly.
Then, install your verizon usb mobile broadband card on your desktop. When you plug it to the usb port, a pop up balloon would show on your page which would say FOUND NEW HARDWARE. you could click on it and choose the CD-drive to install OR you can run the cd and have it install on itself.
After installing the usb, try to connect to your wireless network. Start > Connect to > and then click on the name of your wireless network.
Apr 08, 2009 | Linksys Wireless-N WRT150N Router
Cannot access internet with a linksys router
Make sure DHCP is turned off on the modem or else you will get ip conflicts. Also make sure it is plugged into the wan port on the router
Jan 15, 2009 | Linksys Wireless-N WRT150N Router
Can't connect wireless to WRT150N.
Your hardware might not be compatible with eachother.
Mar 17, 2008 | Linksys Wireless-N WRT150N Router
Linksys Wireless-N WRT150N Router Logo
202 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
