Question about Fisher and Paykel 24 in. DD-602 Built-in Dishwasher
How to take or remove drawers out of 2 drawer Fisher Pakel
How to remove the drawers from a Fisher Pakel dishwasher. Please explain in detail.
  • 145 Answers
Hi, welcome to FIx Ya...
1. Unplug machine.
2. Slide drawer open, remove two pegs that secure front panel to drawer (one on each side of drawer)
3. Slide front panel down and out, remove green ground wire.
4. Depress tabs that hold bottom plastic cover on bottom of drawer and remove entire cover, being careful not to break the tabs.
5. Disconnect tan water fill hose from rinse dispenser.
6. Disconnect two wire harnessess at control board.
7. DIsconnect drain hose from pump base. (might want to put a pan underneath to catch water)
8. Depress tabs on hose/harness coupler at bottom rear of drawer and dis-engage the coupler.
9. Lift drawer off slides.
Posted on Jan 15, 2009
  • sailjb Jan 07, 2011
    how do you get to the underside of the bottom drawer? I need to replace the drain hose, the original is split. I cannot get the drawer out far enough to work on it. JB
FISHER PAKEL DD605SS TOP DRAWER WILL OT RUN AND THERE IS NO ERROR CODE
If the power is connected and you are able to program the wash cycle, then it appears the drawer close sensor is failing. The controller is unable to detect drawer close and start the wash cycle. Need to replace the sensor or clean it. The location is shown on page 10 item 5 (tub home sensor) in this parts manual
http://data.manualslib.com/pdf/6/519/51826-fisher__paykel/dd603h.pdf?e53609423d7a330cba24becd37b5c6f1&take=binary
Mar 16, 2014 | Fisher and Paykel 24 in. DD603H W Built-in...
Dishdrawer stops beeps mid cycle
It could have fogged up because you had the drawer cover off in the first place.
The problem may be the alignment of the mirrors. If the control board has slipped down so that the mirrors do not line up to the photo cell and led---that can cause the problem you are having. Make sure the mirrors (light tubes) are properly lined up with the photo cell and led on the control board. You may have to move the control board to make this alignment. Once aligned secure the board in place and this should solve your problem. NOTE: MAKE SURE THE POWER IS TURNED OFF BEFORE YOU MAKE THIS REPAIR.
Aug 19, 2013 | Fisher and Paykel 24 in. DS-603 Built-in...
The time on now shows 107 instead of 127 min. drawer Fisher & Pakel double
your dishdrawer is in ECO mode. Press the ECO button on the program panel on top of drawer lid. This should restore the Heavy wash time to 127min.
Mar 29, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 has come up
This video explains how to repair this issue
Feb 21, 2011 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 showing
Hello here is a video that explains how to repair a Fisher Paykel dishwasher
http://www.appliancerepairlesson.com/
Dec 10, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Disherwasher double drawer has a F1 fault have turned off power and back on again and has stopped beeping but faultF1 and spanner logo still showing ,help please
I am assuming the F1 fault is showing on both the drawers.
This is normally due to flood switch at base of dishwasher housing getting set.
This is due to water leakage from the drawers into the base. To clear it you need to turn power off. Take out the bottom drawer and dry the base of housing with towels and hair dryer. The flood switch is mounted on power board at the base.
Put drawer back and turn the power on. The drawer removal is done by taking out 2 plastic plugs one on each side of drawer and taking front cover off. Then pull drawer out and unclamp from rails. Pull out carefully without damaging houses and wiring a the back. Put back in reverse.
Nov 22, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
How do you remove the drawers on a fisher & paykel 2 drawer dishwasher please
Open the drawer, on both sides, near the front there is a small circulat pin, with a slot in the middle, grab the middle with a pliers, and pull straight out, with this out, the square button in front of the hole will push in, and slide it slightly back, then the drawer will slide out, and you can lift it off the rails.
Nov 28, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
We have a fisher Pakel dd603 2 drawer , the top draw wont close so we r trying to remove it to see what is blocking it can't figure out how to take top draw out
Hi!
There are two small clips down in the front of each drawer, one on each side. You depress these clips/tabs which are attached to the drawer slides, and then the drawer can be lifted away from the rails. You need to be very careful not to damage the hose/wire harness guide behind the drawer.
What may have happened is one of the "spring clips" on the rear of the rails has popped up when the drawer was open so the drawer will not have that "snap shut" feel you are used to when the drawer is almost all the way closed.
If you require more assistance, please ask.
Jan 29, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher & pakel dd-603ss top drawer wont drain
Have you cleaned the drain filter ? If not, clean that ( it is beneath the rack where the utensil bin is normally positioned and accessible by lifting up the plastic door..If that is clogged up then your drain flow will be restricted. Also, check to make sure the drain line is not restricted ( pinced or clogged). .And yes , the drain is pumped out. If these tips do not get you going, please write back and let me know.. will help get your dw going ...
Regards
Oct 10, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 24 in. DD-602 Built-in Dishwasher Logo
1,938 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
