Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Stopping the door before its closed
We have an OLD Craftsman (at least 20 years old). We used to be able to stop the door short of its being fully closed by pushing the button on the wall or remote. Now, it closes all the way. The motor sounds like its laboring but it does open and close the door. Any suggestions?
    Champion:
  • 244 Answers
Buy new unit with saftey beams.
Posted on Jan 15, 2009
I see moisture between the glass panels of the door.
Hello roderick234 - From what you have described it sounds like the beverage center has a poor door seal. When cold air and warm air outside is entering it causes condensation. Try checking and see if the door seal is bad; place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing it. If nothing is stopping the door from closing then I suggest contacting your manufacturer and see who they recommend to repair the unit.
Nov 10, 2012 | Electrolux 6.0 Cu. Ft. Beverage Center -...
Subject: Sears Craftsman 1/2 HP Garage Door Opener (Logic Board # 45308W) Hello, My unit has been working well for 20 years and has now started to “click” on and off by itself. The unit works the door...
Cold solder joints are common on these logic boards.
Using a magnifying glass, inspect the solder joints on and around the transformer. A trained eye will see the crack right away.
Resolder the solder connections and retest..
Nov 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 1/2hp garage door opener does not go down to floor
I'm no expert, but on a previous door opener I had (don't know the brand), the side adjusting screw basically adjusted a limit switch, which was located inside the plastic housing (where the motor is). I was able to remove the housing, figure out which limit switch was actually being contacted "too soon" on the way down and adjusted it while watching it.
Just a suggestion, you might take a look.
just keep your hands out of the way of the chain and sprocket if you do take the housing off. .
Mar 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
My craftsman garage door is about 8 years old. It
Make a slight adjustment to the Upward force on the side of the machine. Turn the screw a 1/4 turn each time and test, see if that helps. Also, make sure there are no obstructions or friction when the door opens and closes. Try it manually first.
Feb 18, 2009 | Sears Craftsman LiftMaster Chamberlain...
Door opens about 18" and stops
Check the drive belt for tightness. Check for a bent or obstructed track. Overhead door openers have a safety clutch built in in case something or someone gets into the path.
Jan 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
42 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
