Question about MSI MS-6368 Motherboard
Secondary Video How do I turn off the Primary Video on the MS-6368 Ver2 mainboard so it will go to the secondary video?
  • 3 Answers
You have to go into the CMOS to turn off the motherboard Video
Posted on Jan 14, 2009
Monitor turned pink
Video-cards generate "primary" colours (red, green, blue), and "mix" those colours to produce millions of "secondary" colours.
First, try replacing the "data' cable between the LCD and the video-card.
Second, if your LCD works correctly when connected to some other desktop or laptop computer, then the video-card in your computer is not working properly -- not sending one of the "primary" colours to the LCD. Replace the video-card.
Jul 17, 2010 | Samsung SyncMaster 931B 19" LCD Monitor
I AM SIGNING UP 4 XBOX LIVE AND MY INTERNET CONNECTION FAILED IN RESULT OF AN INCORRECT SECONDARY DNS SERVER IM WONDERING WHERE DO U GO 2 FIND THAT
Have you tried dns settings in automatic? I take it from your post that you have the primary dns server, my primary and my secondary has only one number difference,
primary 194.168.4.100
secondary 194.168.8.100
you only have 9 numbers to try so its worth a go, I hope this helps because I know from experience what a frustrating pain in arse this can be.
Remember thumbs up if this helps.
Feb 03, 2010 | Microsoft Xbox 360 Console
The monitor led is green but it gives white flash and still blank
Check the volatage regulator in the mainboard resolder all you found dried unsolder parts inside mainboard. Voltage test the regulator IC if have a voltage flow 2.5 to 5v DC. check ribbon cable connector from mainboard to controller board if properly connected. In the controller board find the small fuse test it for open.
Reminder:
When you voltage test in the power board
in the primary section of power supply
use hot ground. Do not use the hot ground
when you voltage testing the secondary
power supply, mainboard and controller
because it will cause of damage
semiconductor. For safety use cold ground
for secondary, mainboard and controller
board.
Aug 29, 2009 | ViewSonic VA712 17" LCD Monitor
Upgrade for NEC COMPUTERS INTERNATIONAL MS-7168 1.0 mobo
There is no limit to what you can upgrade your CPU too, although your mainboard has socket 939, so your CPU should be the same.
I cannot advise you wether or not it would make your PC faster, for that I need to have more specs and the kind of thing you use th PC for. (video-editing/games/casual)
I hope this helps,
Yannick.
Apr 15, 2009 | Computers & Internet
My sx-315 pioneer receiver overheated and shut down.
Probably the thermal fuse in the main power transformer. Check for ac on both the primary and secondary of the transformer. If you have 120v ac on the primary when the standby light is off and nothing on the secondary you need a new transformer.
Feb 08, 2009 | Pioneer SX-315
Evo N600c Battery Discharge Order Wrong
Try this,
Click start/control panel/power options.
(In control panel,you may have to change to classic view to see power options)
You should see the batteries listed.
You should now be able to click on each one and adjust the settings and advance settings to whatever you like.
Dec 20, 2008 | Compaq Evo N610C Notebook
I have bought two hitachi 160 GB hard drives and need jumper setting explained please
The usual jumper settings for a hard drive are:
  • Cable Select
  • Primary
  • Secondary
Cable select means that the mainboard will choose whether to make the drive primary or secondary. Most mainboards today support cable select. And, most drives will have their jumpers already set to cable select. You can just have all your drives set to cable select, and the mainboard will take care of the rest.
“Primary” means first and most important. Think of the primary as the one that usually takes control of the cable and gets its way. The secondary is like a little brother who must usually wait.
You usually want your main hard drive set as primary, or set it as cable select and have the mainboard set it as primary
Sep 16, 2008 | Hitachi Computers & Internet
Dual monitors
Reduce the display settings on the secondary monitor, set them low or to the natives of the external monitor.
Mar 24, 2008 | Computers & Internet
Can't transfer dubbed audio (secondary sound) using firewire.
Audio Dubbing on DV: Here's how you do this: Play your tape on the TRV-9 and feed the signal into the TRV-900, using the Firewire connector. Set the TRV-900's audio option to record in the 12-bit mode. When this is done, you will have the video re-recorded on the TRV-900 and the audio laid down on the primary 12-bit audio channel. Then, you can run the tape back through for a 2nd pass in the TRV-900, with the recorder set to the audio-dubbing mode. The audio you put into the TRV-900 this time, will be recorded on the secondary 12-bit channel. You can select either 12-bit channel when you play the edited tape back or you can mix both stereo channels into the output. Once you record on the 16-bit channel, you can't dub audio back onto that recording, without erasing the original channel, as the recording space for both 12-bit channels is occupied. You can't selectively re-record just audio onto the 16-bit channel either, without the video being re-recorded along with it. Both video and audio are sent over the same Firewire connector, so you can't input them from mixed sources, as you can with analog recordings. Only the secondary 12-bit audio channel can be used in the audio-dubbing mode. You can't dub onto the 16-bit channel or onto the primary 12-bit channel. The primary 12-bit channel can be used only when you're recording video along with it.
Sep 05, 2005 | JVC Cybercam GR-D200US Mini DV Digital...
MSI MS-6368 Motherboard Logo
181 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
