Question about Sony MDS-JE470 Mini Disc Player
Won't record...says din lock
The JE470 plays but won't record from analog CD player. Message on screen first said din lock, now says din unlock, but won't record. How do I fix this?
  • dave Feb 08, 2009
    sharp s707 wont play or record just flashes din lock and wont do anything even tried stereo and anilog anyone got any ideas thanks
    Sniper:
  • 87 Answers
I'd say you have the digital input selected. The player does not see a digital signal and gives such message.
Select the analog input and you should be able to record.
Hope this helps.
Posted on Jan 13, 2009
  • Sony Master
  • 1,267 Answers
Take the unit off of Digital input or use a compatible digital input source. DIN means Digital in and has to do with the word clock frequency that is recognized. I have had this in the Radio business a lot when people press buttons they don't know about. It is easy to fix.
Posted on Apr 05, 2013
Need to unlock din lock
By 'Unlock din', do you mean unlock the region the recorder uses, unlock the din input or unlock the tray or what?
When recording and you see 'unlocked', it means the DIGITAL signal you are trying to record is unclear or missing.
If you are trying to record a signal from another region disc, it will not copy. Add a little detail.
Feb 21, 2012 | Pioneer PD-R609 CD Recorder
Getting error message "Din Unlock
That means you don't have a good DIgital INput (get it?) signal or bitstream. Correct the source's playback or connection.
It's on page 37 of the manual.
May 03, 2011 | Sony RCD-W500C 5-Disc CD Recorder
Why i am seeing DIN UNLOCK
If you are recording from a DIGITAL input like the OPTICAL or DIGITAL COAXIAL and their is no signal, or if it is a 'non-copyable' copy of a digital copy (from a mini-disc or protected audio CD-R) you will see this. You need to record using ANALOG inputs, then you won't have this DIN UNLOCK problem using analog. Double check your digital connections and make sure your digital source is set to 'play' and see if the DIN Unlock goes off. Otherwise, use analog reocrding only.
Jan 18, 2011 | HHB BurnIt CDR830 CD Recorder
C71/DIN UNLOCK
The definiton in the manual suggests you are trying to record a digital bitstream that is either dead or incompatible with the recorder. Go analog.
What happens if you skip the receiver? Be advised that anything coming in digitally through a cable/satellite box may be muliti-channel and convertible by the player to its native 44.1 khz sampling rate.
Mar 31, 2010 | Sony RCD-W500C 5-Disc CD Recorder
Din Unlock - Unable to record
You must have the unit switched to "DIGITAL" input - switch it to "ANALOG" and record that way. The "DIN UNLOCK" is when you have the lack of a proper digital signal, or a digital signal with copy protection, like you cannot make a digital copy of a digital Minidisc, etc...Does that make sense? Let me know if the "Analog" setting works for you. Good luck.
Nov 07, 2009 | Sony MDS-JE330 Mini Disc Player
SONY MDS-JE480 "C71 - DIN Unlock" persistent problem
I get the DIN UNLOCK with you try to make a copy of a digital copy.
Jun 29, 2009 | Sony MDS-JE470 Mini Disc Player
I have a minidisc model mds e10
it seems your MD unit is expecting a digital signal on the digital input causing this message to appear.
You need to connect a signal source to the digital input
or
connect an analog signal to an analog input and select the analog input as signal source.
In both cases the DIN UNLOCK message will then disappear.
Cheers
May 14, 2009 | Sony MDS-E10 Mini Disc Player
Din Unlock C71
your deck is expecting a digital signal provided by optical cable.
Hence the error message you see. If you want to record using RCA cables, you will have to set your MD recoder so to use analog input.
Press the INPUT key repeatedly to select the Analog input, then connect your RCA cable to the Analog input and start recording.
You may have to adjust the recoding level (or volume if you will).
OR you get an optical cable and then use the Digital Input 1 or 2.
See page 11 of your user manual for detailed instructions.
Cheers
Feb 21, 2009 | Sony MDS-JE470 Mini Disc Player
Error message
Din unlock means 'digital input is unlocked' meaning it is not receiving a signal on the **digita**l input you have selected. ( eg optical or single co-axial digital from another cd player etc) Check your connections and re-select the source using the front panel until you select the one you want. What are you recording from?
Apr 16, 2007 | Teac CD-RW880 CD Player / Recorder
Sony MDS-JE470 Mini Disc Player Logo
631 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
