I try to install the network driver but it says this device cannot start code 10
  • 2 more comments
  • micloscrib Jan 13, 2009
    alright i do that and it said that the device cannot start code 10
    well its a network adapter that came installed on the motherboard
    thats for cd drives though
  • micloscrib Jan 14, 2009
    original yea it didnt work after i reinstalled xp
    Master:
  • 413 Answers
Most of the time, you can resolve this error by updating the device driver for the faulty device. To update the driver, select the system option from the Control Panel. In the System Properties dialog box, select the hardware tab, and then select the device manager button. Scroll through the Device Manager window and identify the faulty hardware device. Right-click on this device and then select the update driver command. Next, follow the screen instructions to update the driver of the selected device.
And make sure you download the driver from the manufacturers website
Posted on Jan 13, 2009
  • 4 more comments
  • Dan rogers
    Dan rogers Jan 13, 2009
    ok hold on let me look up some things it may take a while to get back to you
  • Dan rogers
    it sounds like you got a bad device. if the drivers installed with no errors i would return the device and try another one.
    What is the device? USB or Daughtercard?
  • Dan rogers
    Or if you are running windows xp you can try this fix. But it is messing with the registry so be careful. Scroll down to advanced troubleshooting and follow the directions carefully
    http://support.microsoft.com/kb/314060
  • Dan rogers
    Try going to the motherboard manufacturer site and see if there are any updates available for the motherboard controllers or anything. I am leaving the office now but will look this up more at home
  • Dan rogers
    Dan rogers Jan 14, 2009
    is this a new motherboard? did it work before? What made you install the driver?
  • Dan rogers
    where are you trying to download the driver from? I honestly think you are just downloading a bad driver.
Device cannot start code 10
Device cannot start code 10 means that you are using the wrong drivers for the device or the device has a problem try using system information for windows to find out what drivers it needs if that is the problem but if not the device might need replacing
Aug 03, 2013 | ASUS Computers & Internet
F5d7010 network card error code 10 how to fix manually
Make sure you have the correct drivers installed for the correct hardware version.
NOTE: Older hardware version may not be compatible with current Windows.
Ref: http://www.belkin.com/us/support-article?rnId=302
Also follow: http://windows.microsoft.com/en-US/windows7/What-to-do-when-a-device-isnt-installed-properly
Dec 18, 2012 | Belkin (F5D7010) 802.11a, 802.11g/b...
My dell inspirion all the sudden wont find wired networks and in the device manager it says "this devise cannot start (code 10)
Code 10 means that the drivers are not installed properly. May be that the drivers need to reinstalled or rolled back
Try rolling back the drivers first, that should resolve the issue for you. this can be done from the device manager itself. right click on the device, then click on properties and then on drivers and then click on rollback.
Else you may uninstall the drivers and then reinstall the drivers from Drivers & Utility disk.
If you need any further help then you may call us at 859 309 7078 (US) or reply over here.
If you want me to take the remote access of your computer and help you out then log on to HNetworking.com
Feb 05, 2011 | Dell Ethernet Card Network Adapter
CODE ERROR 10
Code 10
If the device has a FailReasonString value in its hardware key, that string is displayed as the error message. The driver or enumerator puts this registry string value there. If there is no FailReasonString in the hardware key, you receive the following error message: This device cannot start. (Code 10)Recommended resolutions
Here are some things that you can try to resolve this problem.
Update the driver
In the device Properties dialog box, click the Driver tab, and then click Update Driver to start the Hardware Update Wizard. Follow the instructions to update the driver.
You may be prompted to provide the path of the driver. Windows may have the driver built-in, or may still have the driver files installed from the last time that you set up the device. If you are asked for the driver and you do not have it, you can try to download the latest driver from the hardware vendor’s Web site.
Feb 26, 2010 | Broadcom BCM5721 NetXtreme Ethernet...
Error 10 Am trying to install on refurb desktop Have installed and uninstalled and installed again
Error code 10 in device manager means that the device cannot start. This is due to either the drivers are not updated, or the drivers are not recognized by the Device Manager.
Try the following:
- Uninstall and then reinstall the drivers.
- Make sure you have the updated drivers and the drivers are compatible with the operating system of the computer.
- Try to install the adapter to another computer, just to isolate the issue if this is a problem with the drivers or if it is a compatibility issue with the PC.
Please note: WUSB54GSC v1 drivers can also work with Win 7 using the Win Vista drivers.
Nov 12, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Intel(R) 82566DC-2 Gigabit Network code 10
1. Try updating the driver from the Device Manager.
Open the Device Manager by clicking the Start button, clicking Control Panel, clicking System and Maintenance, and then clicking Device Manager. Right Click on the Device and select the option Update Driver.
2. Uninstall the Driver from the Device Manager, restart the Computer and then reinstall it.
Good Luck!!!!!!!!!
Oct 11, 2009 | Microsoft Windows Vista Ultimate Edition
Network Adapter cannot start
i think your network adapter has have a damage
i hope i can solve your problem
Aug 25, 2009 | D-Link AirPlus G DWL-G122 802.11g/b...
Broadcom network adapter has code 10
Try to update its drivers. Go to the Device Manager. In the device Properties dialog box, click the Driver tab, and then click Update Driver to start the Hardware Update Wizard. Follow the instructions to update the driver.
How to go to Device Manager:
1. Right-click on My Computer on the desktop and then click on Properties. Then click on the Hardware tab and then Device Manager button.
2. Double-click on Network Adapter. Double-click on your network adapter to view its properties.
3. Look for the Device Status or any error message. If it says "This device is working properly" then the adapter is properly installed.
Jul 17, 2009 | Broadcom BCM5721 NetXtreme Ethernet...
Intel PRO/Wireless 3945ABG
If its saying code 10 you just need to update the driver for the device and that error code will be gone....
May 07, 2008 | Intel PRO/Wireless 3945ABG Network...
Device will not start code 10 message
Code 10 means DRIVERS COULD NOT BE INSTALLED. Try installing the drivers manually.
Do this if pc is XP.
1.Keep the wireless adapter connected to the pc
2:Go to control panel, add/remove programs. Remove the wireless adapter software
3:Restart the computer, when the found new hardware wizard shows up click on it, click NO NOT THIS TIME, then select install from a list of specific location. On the next page Click on DON'T SEARCH, I WILL CHOOSE THE DRIVERS TO INSTALL.
4.HIGHLIGHT NETWORK ADAPTERS on the hardware type, the CLICK HAVE DISC
5.Click BROWSE to set the location of your drivers
6.Open the driver folder, then the pc should copy the files.
Good Luck
Feb 24, 2008 | D-Link DWL-520 Wireless PCI Wi-Fi...
Computers & Internet Logo
53 people viewed this question
David Payne
David Payne
