Question about HP Compaq nc6000 Notebook
Hp nc 6000 wont power up
When you push power button lights come on fan runs then it shuts off
  • 4 more comments
  • goldfevermik Mar 23, 2009
    I turn it on and fan runs then shuts down within seconds. Any help for this?
  • Anonymous Mar 31, 2009
    same
  • darren_hee Apr 07, 2009
    if you Power on the NC6000, after a few seconds it shuts down.
    And plus the CAPS lock Lights on the top left do not flash on.
    I have tried 5 different Power supplies and same issue.
    But if I knock/Hit the top Panel above the Keyboard. It will start up.
    But the Same thing happens next time I power on the laptop.
    So maybe a motherboard issue or Power board issue.
    But i have seen this happen on 10 laptops, as this is a common Laptop model at the office.
  • lyndseymama Apr 09, 2009
    I tried getting a new battery since having many fails to the system, a downhill spiral of problems started and now I have a new battery, have had to reload the OS after my back port panel went unrecognized by the manager console, and now everything seems ok but this "booting" power issue. with two different batteries, it detects one and "charges" it with the indicator light while the other it does nothing. I thought maybe it was also the power plug but I tried it without having the adapter connected and the same problem arose. When I connect it back in, I have to have it in for a long time charging before it will actually turn on with no problems...any ideas what it might be? I do know:
    1)the cpu socket...if you push the warning symbol above the F10 key while booting up and it works...then it is the cpu socket.
    2) when the power plug is on and battery power is low...it no longer shows the "charging" icon by the time clock on the taskbar.
    3)When I take out the battery to retest it to "diagnose whether its a power issue... it takes forever before it will start back up after put back in.
    4) I've been able to isolate to the following items that it might be but don't know how to diagnose without having to take completely apart several times...heatsink, motherboard, acdc intake adapter, or the most simple the cord...
    Like many people I don't want to spend money unless I'm sure I know what the problem is...any suggestions on how to diagnose accurately???
  • ranel523 Apr 10, 2009
    i turn it on and fan runs then shuts down within seconds.pls help for this matter.
  • rezwan_radi Apr 21, 2009
    i tried so many times...but its not working...and the given solutionz are ****....
    Problem Solver:
  • 12 Answers
Friends,
Problem with HP Notebook Or Laptops? Follow the links.
For Software problems you can visit a link by just Click Here .
For Hardware problems with this Notebook you can Click Here
Posted on Jul 23, 2010
    Problem Solver:
  • 3 Answers
Mine did the same wouldnt power up when starting up hold down the fn andf4 key together this should start up your system
Posted on Oct 31, 2009
I've seen that in the most of cases is a wireless card problem. Please when you start the PC look at the blue led of the wireless network : if it is alwais on (until the pc turns off by itself) remove the wireless card located under the central cover ( 4x4cm with a cross screw). Remove and isolate the 2 antenna cable from the card. Everything will be allright ! Have fun.
Posted on Apr 16, 2009
    Genius:
  • HP Master
  • 1,102 Answers
Your power supply may be going
not getting enough power
Posted on Jan 18, 2009
Danby premiere dpac 12010h does not fully start, shuts off, repeats
Unlikely to be a capacitor but they aren't expensive to replace. More likely to be compressor failing to start, or controller faulty. Try powering up the compressor and fans to see if they run independently of the controller
Aug 07, 2012 | Danby Premiere Series DPAC12010H 12,000...
Gateway 5056 Media center doesn't boot everytime.
did you look on gateways website for a bios update. the firmware on your motherboard maybe corrupt. go here and check since I dont have your serial number... gateway has a java based scanner that might be able to repair it for you
http://support.gateway.com/support/drivers/dlcenter.asp
please rank me if you can
Jun 22, 2009 | Gateway GT5220 PC Desktop
No signal to monitor, fans run full speed
maybe your cpu is faulty or ... maybe power suply ??
Mar 31, 2009 | E-Machines W3107 (RBW3107) PC Desktop
Projector shuts off after about 45 minutes
Just a long shot, but...
I have an epson 9000i that did the same thing. Turns out that unit has a small fan (I think 60mm) right next to the power supply to keep it cool, in addition to the large fan that exhausts past the lamp. The fan runs non-stop as long as the unit is powered-up for two reasons I can think of - keep the power supply a little cooler, and the lamp a little warmer so there's not such a temp difference when it powers-up. Long story short, that fan had died. I replaced it with an aftermarket 60mm fan and it's been working fine ever since. Hope this helps.
Bob
Jun 03, 2008 | Epson PowerLite 5550C Multimedia Projector
Onkyo SV828THX Power on
There is or seems to be a bad or cold solder connection on that Printed circuit board that is going to need to be resoldered or it can cause more damage to the unit. And on this model, the fan will start at power up but shut down untill the output section heat sinks get hot.
Sep 28, 2006 | Onkyo TX-SV828DSP Receiver
HP Compaq nc6000 Notebook Logo
1,021 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
