Question about Belkin OmniView E Series 2-port KVM Switch
Switching between PC's makes the mouse run wild
Hi there, I have this issue with the Belkin KVM E-Series. When I switch between PC's the mouse seems to be in a mode where the left button is pressed (or auto clicked). When one moves the mouse all kinds of clicks and drags are issued to the OS, messing up the desktop and sometimes closing windows. This effect goes way after about a second on a Windows machine, but takes longer (3-5 seconds) on a Linux box. If I just sit and wait it persists. I need to move a mouse a little bit and typically click the right button to make it go away faster. Why does this happen? Is there any fix for this behavior? Thanks K
    Scholar:
  • 41 Answers
Sadly, this is a known issue with this series of KVM switches (3 out of 5 on Amazon) and I have not seen or heard of any fix. I have heard of older mice operating correctly but even that seems to be hit-or-miss.
Posted on Aug 23, 2007
SOURCE:
Microsoft 6000 wireless keyboard / Mouse & KVM
Hi any KVM switch will work with these products
Belkin normally make very good KVM switches but they are pricey, cheaper ones can be picked up on Ebay, but not too sure of the quality
Feb 11, 2010 | Computers & Internet
Repeated IOGear KVM switch failures
As a wild guess, it sounds like a static discharge MIGHT be affecting the switcher causing it to crash.
Try increasing your humidity to 40% and grounding yourself before touching the keyboard... This is the season for these static electricity problems... get nipped all the time and you MAY not even feel it to be enough to zap the switch.
Jan 11, 2010 | IOGear MiniView GCS62 2-port KVM Switch
Components not recognised automatically with Belkin Switch2
This is not quite a solution, but a workaround. Take a USB cable extender and intercept the 5V supply wire in it (normally red) with a push to break switch. When you have powered up the PC, push the switch and the KVM will then work (same as your unplugging but much easier to do ). Switch bought on Ebay for 0.99GBP. Belkin tried to insist that I had my laptop plugged in and working if I wanted to use my desktop.
Feb 08, 2009 | Belkin F1DF102PEA 2-port KVM Switch
Windows XP using Wireless Intelimouse with KVM switch exhibits erratic behavior
Hi
What type of mouse do you have plugged into the KVM ?? PS2 or USB and what type of KVM switch are you using.
Respond back and I will look into it for you.
/SPH
May 19, 2008 | Computers & Internet
Belkin (F1DK102P) 2-port KVM Switch freezes
We have the same model and the same problem. The scroll lock combo did not work for us. You need to press Ctrl, Ctrl then up or down arrow.
The manual was a load of old Tom *** as it did not mention this.
Chard101.
Dec 14, 2007 | Belkin F1DK102P 2-port KVM Switch
Two port kvm belkin
Switch to the First PC [Scroll Lock] [Scroll Lock] [1]
Switch to the Second PC [Scroll Lock] [Scroll Lock] [2]
Previous Active Port [Scroll Lock] [Scroll Lock] [Up Arrow]
Next Active Port [Scroll Lock] [Scroll Lock] [Down Arrow]
Switch Audio to the First PC [Scroll Lock] [Scroll Lock] [F1]
Switch Audio to the Second PC [Scroll Lock] [Scroll Lock] [F2]
AutoScan Mode [Scroll Lock] [Scroll Lock] [0]
Change All to the First PC [Scroll Lock] [Scroll Lock] [A] [1]
Change All to the Second PC [Scroll Lock] [Scroll Lock] [A] [2]
Other information:
In AutoScan mode, the switch remains on one port for 10 seconds before switching to the next. This time interval cannot be changed. To exit autoscan mode press [Spacebar].
When in AutoScan mode, no mouse or keyboard controls. If the user moves the mouse or uses the keyboard while switching the connection between computer and the switch might be interrupted and cause erratic mouse movement and errant display when using the keyboard.
Maximum resolution supported is 2048 x 1536 @ 75Hz.
If mouse movement is erratic:
make sure you do not have more than one mosue driver installed. Make sure that the driver is either for a standar PS/2 mouse or a Microsoft compatible PS/2 mouse. Make sure you do not have any mouse drivers loaded in your CONFIG.SYS or AUTOEXEC.BAT files. Avoid moving the mouse or pressing the mouse button when switching ports on the switch. You can reset the mouse and resume porper mouse movement simply by unplugging the mouse from the switch and allowing 2-3 seconds before plugging it back in.
Company information:
www.kaiweitech.com
Nov 03, 2007 | Computers & Internet
Can's switch without it switching back to first PC
Sadly, it is probably the KVM as this particular model has a string of failures and is only rated 2 out of 5 stars on Amazon due to poor performance. :( http://www.amazon.com/Belkin-F1DK102U-2-Port-Switch-Cables/dp/B0001JXAQ6/ref=sr_1_1/105-6999807-3936431?ie=UTF8&s=electronics&qid=1187826004&sr=8-1 What I would do first is plug in Computer 2 directly to the monitor, keyboard and mouse with no KVM. If those work fine, it is probably not a computer issue; if you don't get video here, then it is a seperate issue with that PC. If Computer 2 is working, plug both computers into the KVM but switch the cables (plug Computer 1 into the KVM using Computer 2's cables). If Computer 2 shows up and can't switch to Computer 1, then it is the KVM messing up.
Aug 21, 2007 | Belkin F1DK102U 2-port KVM Switch
KVM switch mouse trouble
Does a mouse work if plugged directly into the laptop? Sometimes you have to change a laptop in the BIOS to allow a PS2 mouse in addition or instead of the touchpad. It may not be recognizing the KVM as a mouse. Try plugging the mouse right into the laptop and see if that works.
Mar 24, 2007 | Belkin F1DK102P 2-port KVM Switch
Problem with laptop connection
KVM's work best when you are using the same or similar type of hardware however there might be an issue with your video card interfacing with the KVM. I would switch the Video cables and see if the problem moved or disappeared. If the problem moves, then I would suspect the video card is the culprit. Since many problems can be traced to software compatibility issues, I would check to see if there is an updated driver for your video card and or your monitor first. If the problem disappears it could possible be a loose cable connection on the destop PC or the KVM itself. I would also try a different set of cables.
Jan 30, 2007 | Belkin F1DK102P 2-port KVM Switch
Problem with Belkin OmniView KVM F1DS102P
Is the LED for position 1 and 2 always on? If the switch doesn't detect power on the PS2 keyboard connector it won't let you switch to to that position. If you are using a USB mouse with an adaptor or a wireless mouse try a conventional PS2. I have a MS wireless mouse one of my switches does not like and have to resort to that sometimes. Another issue could be excessive cable length or PS2 extension cables. Let us know if you have any more questions on this topic and please don?t forget to rate the post.
Aug 31, 2006 | Belkin OmniView¿ SOHO Series 2-Port...
Belkin OmniView E Series 2-port KVM Switch Logo
106 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Pamela Bates
Pamela Bates
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
