Question about HP Photosmart 2575 All-In-One InkJet Printer
Re setup have packerd bell computer with windows xp tryed to install all in one and i get msg saying required section not found in inf it also says something about the usb port not fast enough i have a belkin 4 port usb connected
Be really awesome and have several printers
Posted on Jun 17, 2007
    President:
  • 2,961 Answers
Ok depending on how you have installed it, normally the software/installation cd has to be installed first, so remove the printer and start again, the .inf file it is looking for is the driver file, but the cdrom should firstly set this up when installed, only then the printer can be attached. If you have to connect the printer first, then you will have to force windows to look in the cdrom drive for the files to install the driver as it may be looking in 'C' where windows is installed instead. The usb hub you have will probably be a usb1.1, but your printer will prefer usb2, so try it in other usb ports, that you haven't got the hub connected into, remove any other hardware that is connected to your usb ports at rear of pc and connect them to the hub instead, as one of the used ports may be usb2. Having said that your printer does not have to have usb2.0 to function, using the usb1.1data rate is just slower than usb2.0
Posted on Jun 12, 2007
SOURCE:
INF error with crystal eye webcam on vista premium.
you're crazy installing vista on that netbook. acer doesn't have vista drivers for that model.
Apr 26, 2009 | Acer Aspire One PC Notebook
Logitech webcam p/n 861092-0020 file not found in INF
You can get logitech webcam drivers from
http://www.logitech.com/index.cfm/support_downloads/downloads/&cl=gb,en
the inf file must be for another camera or a windows version get the latest and correct driver from the page above -link
Mar 24, 2009 | Logitech Webcam
Need help downloading and installing driver for hp photosmart C3100 printer said required section usbstor.inf not found xpsp3
Search your computer for the USB inf file usbstor.inf. Is this the first USB device you have ever used? What is the operating system on your computer? It appears as though it is searching for the Microsoft Service Pack 3 for XP, and can't find the file within the service pack, or the service pack. Have you recently installed MS updates?
Nov 19, 2008 | HP Office Equipment & Supplies
System restore on server 2003
Before we begin, you'll need an XP CD. Doesn't matter if it's home or pro. It shouldn't matter if it has a service pack on it, since all the files will be the same source. In testing i used a slipstreamed cd that already had sp1 on it.
In XP, system restore is installed in syssetup.inf under the inf.always section. If you have XP installed, you can open up %windir%\inf\syssetup.inf and search for [Infs.Always], you'll see the section xp looks at for installing system components. You'll notice it has sr.inf, this is the inf for system restore. For server 2003, if you look at syssetup.inf you won't find sr.inf. This doesn't mean system restore won't work in server 2003, it just means they didn't install it.
So first what we're going to need to do is right click on sr.inf and select 'install', to install it on server 2003. If you have xp installed on another computer/partition you can just right click on it. If you don't, then extract \i386\sr.in_ from the XP cd to your desktop, then right click on it and select 'install'. It'll prompt you where the files are, point it to the XP CD. Once done, it'll prompt to restart, say yes.
That was easy, the next part is the tricky part. After restarting you'll get an error saying the service couldn't start. Specifically the error is error 1068. I searched google and found this link -
CODE
http://www.aerdyne.com/Kbase/article_000005.htm.
The error basically means it cannot run under the service it's on. In system restore's case, it runs under the network service. I know this because in services.msc, for path to executable, it says this: C:\WINDOWS\system32\svchost.exe -k netsvcs. This got me thinking so i opened up sr.inf, and found this line:
[SRSvc_delreg]
HKLM,"Software\Microsoft\Windows NT\CurrentVersion\SvcHost","SRGroup"
I opened up regedit, and this registry key didn't exist. So it seems the sr.inf doesn't register system restore to run under the network services group. Using the above registry key as an example, i opened regedit and went to:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\SvcHost
On the right hand side i saw netsvcs. I double clicked on it, but saw SRService no where (SRService is the name for system restore). On a hunch, at the bottom i added SRService, rebooted, and this time got no error on startup. I opened up rstrui.exe, and system restore opened fine. I also had a System restore tab in system properties now too. I was able to make a restore point fine, then restore the computer to it without any problems. So in the above key, you want to double click on netsvcs, and at the bottom of the list, you want to type in SRService (probably case sensitive).
If you're not good with the registry you can save the following as a whatever.reg file and import it, but because it's binary i can't say if it'll work. I recommend manually adding SRService to the netsvcs key.
---copy below to whatever.reg then double click on it -----
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\SvcHost]
"netsvcs"=hex(7):41,00,70,00,70,00,4d,00,67,00,6d,00,74,00,00,00,41,00,75,00,\
64,00,69,00,6f,00,53,00,72,00,76,00,00,00,42,00,72,00,6f,00,77,00,73,00,65,\
00,72,00,00,00,43,00,72,00,79,00,70,00,74,00,53,00,76,00,63,00,00,00,44,00,\
4d,00,53,00,65,00,72,00,76,00,65,00,72,00,00,00,45,00,76,00,65,00,6e,00,74,\
00,53,00,79,00,73,00,74,00,65,00,6d,00,00,00,48,00,69,00,64,00,53,00,65,00,\
72,00,76,00,00,00,49,00,61,00,73,00,00,00,49,00,70,00,72,00,69,00,70,00,00,\
00,49,00,72,00,6d,00,6f,00,6e,00,00,00,4c,00,61,00,6e,00,6d,00,61,00,6e,00,\
53,00,65,00,72,00,76,00,65,00,72,00,00,00,4c,00,61,00,6e,00,6d,00,61,00,6e,\
00,57,00,6f,00,72,00,6b,00,73,00,74,00,61,00,74,00,69,00,6f,00,6e,00,00,00,\
4d,00,65,00,73,00,73,00,65,00,6e,00,67,00,65,00,72,00,00,00,4e,00,65,00,74,\
00,6d,00,61,00,6e,00,00,00,4e,00,6c,00,61,00,00,00,4e,00,74,00,6d,00,73,00,\
73,00,76,00,63,00,00,00,4e,00,57,00,43,00,57,00,6f,00,72,00,6b,00,73,00,74,\
00,61,00,74,00,69,00,6f,00,6e,00,00,00,4e,00,77,00,73,00,61,00,70,00,61,00,\
67,00,65,00,6e,00,74,00,00,00,52,00,61,00,73,00,61,00,75,00,74,00,6f,00,00,\
00,52,00,61,00,73,00,6d,00,61,00,6e,00,00,00,52,00,65,00,6d,00,6f,00,74,00,\
65,00,61,00,63,00,63,00,65,00,73,00,73,00,00,00,53,00,61,00,63,00,73,00,76,\
00,72,00,00,00,53,00,63,00,68,00,65,00,64,00,75,00,6c,00,65,00,00,00,53,00,\
65,00,63,00,6c,00,6f,00,67,00,6f,00,6e,00,00,00,53,00,45,00,4e,00,53,00,00,\
00,53,00,68,00,61,00,72,00,65,00,64,00,61,00,63,00,63,00,65,00,73,00,73,00,\
00,00,54,00,68,00,65,00,6d,00,65,00,73,00,00,00,54,00,72,00,6b,00,57,00,6b,\
00,73,00,00,00,54,00,72,00,6b,00,53,00,76,00,72,00,00,00,57,00,33,00,32,00,\
54,00,69,00,6d,00,65,00,00,00,57,00,5a,00,43,00,53,00,56,00,43,00,00,00,57,\
00,6d,00,69,00,00,00,57,00,6d,00,64,00,6d,00,50,00,6d,00,53,00,70,00,00,00,\
77,00,69,00,6e,00,6d,00,67,00,6d,00,74,00,00,00,77,00,75,00,61,00,75,00,73,\
00,65,00,72,00,76,00,00,00,42,00,49,00,54,00,53,00,00,00,53,00,68,00,65,00,\
6c,00,6c,00,48,00,57,00,44,00,65,00,74,00,65,00,63,00,74,00,69,00,6f,00,6e,\
00,00,00,68,00,65,00,6c,00,70,00,73,00,76,00,63,00,00,00,75,00,70,00,6c,00,\
6f,00,61,00,64,00,6d,00,67,00,72,00,00,00,57,00,6d,00,64,00,6d,00,50,00,6d,\
00,53,00,4e,00,00,00,53,00,52,00,53,00,65,00,72,00,76,00,69,00,63,00,65,00,\
00,00,00,00
--- copy above --------------------------------------------------------
That's it! Remember to restart both times.
Oct 20, 2008 | Computers & Internet
Drivers for windows vista
This is the translation;
"windows found driver software for the device, but an error occurred while trying to install it, the required section is not in the INF."
Vista Drivers are here
http://www.driverscape.com/download/genius-videocam-smart300-v2
Dec 19, 2017 | Computers & Internet
Cant get vista off my pakardbell i media x2414 i would like to put xp on it
Dear Sir.
In order to get xp on your computer.
You need to install windows xp by formating your computer by using the windows xp operating system cd.
If your computer comes vista installed on that you need to get xp cd from your packerd bell support.
http://www.packardbell.com/support.htm
Regards
MOhammed.
Jul 18, 2008 | Packard Bell Computers & Internet
Editing text
Windows
» HP Scanjet Scanners Supported and not Supported in Microsoft(R) Windows XP s.gif » Resolving 'Missing MSIEXEC.EXE File is Linked to Missing Export: MSI.DLL.222' Error Message During Installation of the HP Director Software s.gif » Resolving 'Scanner not supported' or 'Unsupported operating system' Error Messages s.gif » Resolving Image Zone Install Error 1402, 1406, 1714, 1904, 1935, 2203, or Unknown Error s.gif » Error 'The System Cannot Find the File Specified' While Attempting to Install the HP Photo & Imaging Software in Windows 98, 98se, or Me s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Error Install Failure' Message for the hpznfx01.exe Software Module Displays on the Computer When Installing HP Image Zone s.gif » The message 'Fatal error during installation' or 'Error Install Failure' Occurs When Installing HP Image Zone s.gif » A 'Fatal Error' or 'Error_Install_Failure' Error Message Displays on the Computer When Installing the Image Zone Software s.gif » The Error Message 'Error_Install_Failure' or 'Fatal Error' Occurs when Installing Image Zone Software s.gif s.gif
Macintosh
» Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif » 'Cannot Install This Hardware - The Required Section Was Not Found in the INF' Error Message in Windows XP s.gif » 'Scanner could not be initialized' Message Displays in Mac OS X when the All-in-One Software is Installed s.gif » Mac OS: Software Driver Install Causes Error, "Interface Lib Get Component Resource Could not be Found" s.gif s.gifs.gif
Jun 13, 2008 | HP 4570C Flatbed Scanner
HP Photosmart 2575 All-In-One InkJet Printer Logo
210 people viewed this question
Clive
Clive
Thomas F. Schneider
