Question about Durabrand CD-203 Boombox
DURABRAND CD-1095:cd player spins, but won't play
The whole unit functions fine except for the cd player. It was working properly, then suddenly stopped. I get two flashing horizontal lines in the display window. I have lost the manual. Please help.
  • 1 more comment
  • Anonymous Mar 26, 2009
  • Nat9790721 May 04, 2009
    same exact thing is going on with mine too
  • taffy811 May 11, 2010
    is the mute button pressed by accident?
4 Suggested Answers
  • 416 Answers
SOURCE: Dura brand Mp3 Boombox
If there is sound in radio mode, but no audio in CD mode (for any CD/MP3 disc of course) , there is a lens problem. Try to clean the lens with cleaning disk. If it wont help you need lense replacement.
Good luck
Posted on Dec 07, 2008
  • 11800 Answers
SOURCE: Where to buy a new antenna
They aren't sold to retail customers. Try at repair shops or use one from another radio, they are pretty much generic parts.
Posted on Mar 09, 2010
kehalim
  • 55 Answers
SOURCE: Durabrand 3-Piece CD Boom Box w/ Radio Cassette Recorder,
Does it happen when playing cassette or radio? might have a problem with the speaker wires.
Posted on Oct 23, 2007
SOURCE: power cord Cd player mod. #CD-1095
Answer below from:
http://wiki.answers.com/Q/How_do_you_get_a_cord_for_a_Durabrand_CD_player_model_cd_1095
You can purchase a generic power cord at Radio Shack. I had the same exact model and found that their catalog number 61-2875 was a perfect fit. It lists for $7.99. To be sure, take your radio in for an exact match. Good luck! :o)
Posted on Oct 25, 2008
Cd player won't work on my CFD-560
Hello
Insert a lens cleaning disc into the system, and play it at least three times, by eject it out and reinsert in each time. If it does not help you, the laser pickup unit of your Cd player should be replaced with same type and number. OK.
Feb 03, 2012 | Audio Players & Recorders
Cd player volume problems
Hello
Just clean the CD lens unit, by inserting a cleaning disc into the CD drive and play it at least three times. If this does not help you, the laser pickup assmebley needs replacement. The lesns cleaning disc an be bought from most of the electronic spare part selling shops at your town, and won't cost more. OK.
Jan 22, 2012 | Aiwa Audio Players & Recorders
Cd player won't play disc it says
Hello
Clean the laser pickup lens by insert a lens cleaning disc into the set, and play it at least three times. If it does not help you. replace the laser pickup unit, with same type and number. OK.
Jan 19, 2012 | Panasonic Audio Players & Recorders
Cd player only shows
You will need to check the swith that change from Tape to CD to other functions. If the switch is good. Then the next thing is to check for tape function. Can you try to fast forward, reverse. If these functions are working properly then the pinch roller ( the little wheel that is pulling the tape need to be replaced). If nothing moves then you need to replace the belt and the wheel and possible the motor at the same time
Nov 17, 2011 | Lenoxx Electronics CD-102 Cassette/CD...
Where to buy a new antenna for a Durabrand CD-1095
Mar 09, 2010 | Durabrand CD-203 Boombox
Durabrand Tape/CD Player twists up all cassettes inserted
We have two of these with the same problem. The belt that drives the pick up reels is broken. We are trying to find a place to purchase new ones.
Mar 26, 2009 | Durabrand CD Player with Cassette...
Power cord Cd player mod. #CD-1095
Answer below from:
Nov 19, 2007 | Durabrand CD-203 Boombox
Oct 23, 2007 | Durabrand CD Player with Cassette...
Durabrand CD-203 Boombox Logo
658 people viewed this question
Top Durabrand Audio Players & Recorders Experts
Rod
Rod
Geoff
Brian Sullivan
Brian Sullivan
Are you a Durabrand Audio Player and Recorder Expert? Answer questions, earn points and help others
