Question about Microsoft Office Professional 2007 Full Version for PC
I want to uninstall MS Office 2007 it will not do it with the install/uninstall programs on the settings window. I have tried using the safe mode as well, no luck
  • todd1716 Jan 14, 2009
    I never had an installation disk. I downloaded the program on a trial basis from their website. I have even tried their alternative fix and that did not uninstall it either. I originally had MS Office 2003 on my machine and had no problem removing that. Any further suggestions? If not how do I contact Micro Soft?
  • MSOphobic Mar 10, 2009
    I have unistalled MSO 2007, but it still appears in my registry. I have tried to uninstall MSO 2007 using the controll pannell, add/ remove programs, but it does not show up there. Any other uninstall programme I've used so far does not show it either. What do I do to get it completely removed?
    Genius:
  • 1,605 Answers
You need the Office 2007 installation CD to un-install.
Posted on Jan 13, 2009
Gentlemen: I have downloaded MS 2007 for free from Brothersoft website. After installation, i can't use all the programs, such as excel and word. Every time i attempt to encode, this statement flashes...
Microsoft Products including Office 2007 are licensed software and cannot be used without the product key. You can only download the trial version.
Instead you can use OpenOffice, which is an absolutely FREE and open source office and productivity suite. Refer here to my earlier solution regarding Office Suite. OR. If you wish to use Office 2003, you have to uninstall Office 2007.
To uninstall you can use any uninstaller or uninstall the program using "Add Remove Programs" from the control pannel. As stated by you, if you are having problems uninstalling MS Office 2007, as a work around, manually delete the MS Office 2007 folder from the 'C:\Program Files' and Start Menu. After that you can use the following software to fix the registry entries left by Office 2007 and the remaining files etc.
-You can use Registry fixing software/utility. I have come across a Registry Tool, which is effective to fix common Registry issues. Its Free, small size, easy to use and completely safe. Click here to download CCleaner. Install CCleaner, Click 'ISSUES' and 'SCAN FOR ISSUES' and then click 'FIX SELECTED ISSUES'. Also, Run cleaner from the main interface of CCleaner.
Make a backup of the registry and proceed. You may proceed without registry back, if you like.
Hope it helps! Good Luck!
CreativeTECH
Apr 12, 2011 | Computers & Internet
Problem installing office 2007.
You need to uninstall any pre-release version of the Microsoft Office 2007 system .
it seems that if you have a version of the 2007 Microsoft Office Add-in or Microsoft Save as PDF or XPS installed, this may be the culprit. In both cases, by performing an uninstall on this add-in via the Control Panel, and then installing Expression Web, everything works okay. You can even re-install the Office 2007 add-in when you're done.
Goodluck,
Please don't forget to rate the solution
May 06, 2008 | Microsoft Office Professional 2007 Full...
I have Microsoft Office 2010 Home and Student (Trial Version) installed on my laptop. The OS is Windows Vista Home Premium. I am unable to open any Excel files. I cannot uninstall the Office 2010 from my...
couple of things to try:
1. try to start your windows in safe mode and attempt to uninstall from there. 2. use the following info to attempt to uninstallation as per ms recommendation. 3. there was a nice little tool from ms called the Windows Installer Cleanup utility but was discontinued, I have used that tool to uninstall some programs on xp that I was having problems uninstalling and worked perfectly when other uninstallers failed. you can try to google it and use it as there are some sites that may still host the file for download although, keep in mind that the solution 2 is what ms is currently recommending so it may not work in vista if you get it.
hope this helps!
Dec 21, 2010 | Computers & Internet
I need to install microsoft word but it is already in my comp but
You need to first uninstall the program (ms office)[if it's ms office 2003, as soon as you start installing the new ms-office 2007, it'll automatically upgrade to ms-office 2007].
I don't know whether you know how to uninstall programs or not, but let me give you the hints..
Click "Start" > "Control Panel" > "Programs" [add/remove programs on windows xp] now highlight the "Microsoft Office..." and click "Uninstall" button and follow the onscreen instructions. Restart your computer and again install the Microsoft Office 2007 using the set up file. If in case, you can't uninstall the program due to faulty/error/missing files, download this program ccleaner install it and run. Now click "Tools" and from the uninstall lists select/highlight the "microsoft office..." and cick "uninstall". If you still have the same problem, please let me know.
Good luck
Thanks for using FixYa.
Jun 28, 2010 | Microsoft Office Word 2007 Full Version...
How to remove the free trial from my computer I have tried to uninstall but it wont let me
Hey, try to go to your control panel then look for the add and remove. Look for the software you want to uninstall then click change. if these doesnt work try to enter to safe mode by rebooting your pc. While your pc reboot press several time the F8 key. A message will pop out then select the safe mode. When your pc load up to your windows try to go the your control panel and look again for the add and remove and look for the program you want to uninstall
Mar 28, 2010 | Microsoft Office Professional 2007 Full...
Error 25004.config.xml when installing MS Project 2007
Please follow the instructions in this article and see if you can uninstall MS Office 2007. After you completely uninstalled Office 2007, you can reinstall it if you wish.
http://support.microsoft.com/kb/928218/en-us
Oct 28, 2009 | Microsoft Office Project Professional 2007...
MS Word 2007 will only open in SAFE mode
I had the same problem. Ran the updater, reinstalled, and still had the problem. Searching for and deleting Normal.dot fixed it immediately. YAAAAAAAAY!
Jan 30, 2009 | Microsoft Office Professional 2007 Full...
MS Office 2007 Enterprise installation setup error
Hi, this may not help you because I do not have the exact error you described. But here is some text from the MS website:The installation of the 2007 Microsoft Office suite Service Pack 1 (SP1) fails with error 1935 or with error 78F. This failure occurs when the Windows Installer encounters a reference either to a drive that no longer exists or to a removable media device that contains no readable media. For example, this failure may occur when the Windows Installer encounters a reference to an empty DVD drive or to an empty CD drive. The issue is not caused by the update design of the 2007 Microsoft Office suite Service Pack 1 (SP1). RESOLUTION loadTOCNode(1, 'resolution'); This issue is resolved by update 946691 for the 2007 Office system. Update 946691 is provided to resolve the problem that you may experience when you install the 2007 Microsoft Office suite Service Pack 1. You must install update 946691 on you computer before you install 2007 Microsoft Office suite SP1.
The following file is available for download from the Microsoft Download Center:
download.gifDownload the Office2007-kb946691-fullfile-x86-glb.exe package now. (http://www.microsoft.com/downloads/details.aspx?FamilyId=697BA2AA-0757-42C8-A530-5BD5566A54AD&displaylang=en)
So, here is what they say to do:
Remove the 2007 Office suite loadTOCNode(3, 'workaround');
  1. Exit all programs.
  2. Click Start, and then click Control Panel.
  3. Double-click Add or Remove Programs.
    Note In Windows Vista, click Uninstall a Program or Programs and Features.
  4. In the Programs list, click Microsoft Office Edition 2007, and then click Remove. In this item, Edition is a placeholder for the edition of Office that you installed.
    Note In Windows Vista, click Uninstall.
  5. Click Yes when you receive the following message: Are you sure you want to remove Microsoft Office Edition 2007?
  6. When the removal operation is complete, click Close.
Reinstall the 2007 Office suite loadTOCNode(3, 'workaround');
  1. Insert a 2007 Office installation CD into the drive.
    Note If your version of the 2007 Office suite is a preinstalled version, the installation CD is packaged in the white box that was included with your computer.
    Collapse this imageExpand this imagesecurityshield.jpg If you are prompted for an administrator password or for confirmation in the User Account Control dialog box, click OK, or click Continue.
  2. Enter the product key.
    Note If your version of the 2007 Office suite is a preinstalled version, the product key is located on the back of the CD case.
  3. Read the Microsoft Software License Terms, click to select the I accept the terms of this agreement check box, and then click Next.
  4. Select the type of installation that you want, and then start the installation process.
  5. When the installation process is complete, click Finish.
Jan 21, 2009 | Microsoft Office 2007 Basic for PC
Adobe Acrobat 8 does not integrate with MS Office 2007 programs
Then do a search for 'all files and folders' - search for both Acrobat 6.0 and then Acrobat 7.0, with the options "Search system folders", "Search hidden files and folders" and "Search subfolders" checked. Delete all of those related files found.
You should do this search and delete whenever you uninstall any programs. It will remove lots and lots of leftover junk files and corrupted files taking up room on your hard drive. It will also give you a "clean install" when you reinstall or install an updated program. (Do this ESPECIALLY when updating to a NEW anti-virus programs and “Internet Security Suite” programs such as McAfee or Norton etc.)
Download and install "Registry Mechanic" then do the updates prior to running it and removing anything for the first time. This will get rid of all your current Registry errors, prior to installing or reinstalling.
Dec 06, 2007 | Microsoft Office Standard for PC
Microsoft Office Professional 2007 Full Version for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
