Question about Microsoft Xbox 360 Console
Xbox360 HDMI hi there can you help me I have a hd tv with a hdmi socket at the back of it.is there a cable that I can bey for my xbox360 that will fit it?
  • Anonymous Dec 11, 2007
    when connecting my component leads for hd the xbx is replying no componnent connected help please my son wants to play in hd my tv is a samsung hdtv 1080i where am I going wrong
    President:
  • 2,961 Answers
There, as yet is only hdmi cable which comes with latest xbox 360, there are non that you can buy, but if your tv has hdmi, it may have component connection also which consists of 5 different coloured connections, this also allows 1080i the same as hdmi, the type of cable can be seen at the link below:- http://www.xbox.com/en-US/hardware/catalog.aspx?st=xbox+360+cable&g=0&s=0&p=1&c=10
Posted on Jun 12, 2007
I can't get my xbox one to setup so I can play on my tv!
Hi Oreanna Corder, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
did you plug the hdmi cable into the left hand slot on back of x box one labelled hdmi out as there is also a HDMI in port . Please check and advise us
http://support.xbox.com/en-US/xbox-one/console/console-setup
Feb 12, 2016 | JVC HD-61Z456 Television
How should I connect a Sony Wega KF-50WE620 to an XBox360 ?
Since the TV accepts HD signals only via DVI and component inputs, the only logical way is to use the "Xbox 360 Component HD AV Cable" as show in the link below:
How to hook up your Xbox 360 or Xbox 360 to TV
The TV will not accept a VGA input. A cable converting HDMI to DVI would also require that you break out the L + R audio channels, too. The one I mentioned above does this all for you with no degradation in video signals.
Mar 26, 2015 | Sony Grand WEGA KF-50WE620 Television
For my 50v500 tv built in 2004 is there an HDMI cable or adaptor to connect for signal?
If there is a socket at its back marked as HDMI, the set should have capability to receive HDMI signals, provided the HDMI firmware has been installed to it successfully. You can connect it with an HDMI cable, with any other external equipment having HDMI output, and select the TVs' input to HDMI.
Electro help
Jul 03, 2014 | Hitachi 50V500 50 in. HD-Ready LCD...
How to set up to using hdmi
#1 your tv would need to be hdmi compatable (have the appropriate plug on the back where all the inputs are located). For example I have a 60" Lcd HDTV and an xbox360 I attached the standard a/v (audio/video) red,white,yellow wires to tv and turned on the game console went into system settings and turned on the hd setting to 1080i for hi def resolution. Another alternative would be to connect console to your dvd player (most new dvd players will up convert signal from 480i or 720i to 1080i hd) and attach your hdmi cable between the dvd player and the tv to support the hd interface. Something I highly recommend is the jvc th c50 home theater surround sound when I play call of duty it has enough to knock stuff of our bookshelves and ******** the neighbors. Happy gaming
Dec 09, 2010 | Video Game Consoles & Games
Could you please tell me if my LC-32GA5E tv can work with sky HD.The manual tells about switching to hd mode,but there seems to be no where to connect hd to the set.The tv is about 5 years old. thanks...
This is an HD ready TV and can definitely be used with Sky HD, but ONLY if the Sky box is connected to the TV with an HDMI cable. It will not work if connected with a scart cable.
So you need 2 things. Firstly, you need to buy an HDMI cable (see picture) if you haven't already got one. Secondly you need to locate the HDMI sockets on your TV and Sky box. The sockets will have the HDMI logo (see picture) next to them.
Oct 16, 2010 | Sharp LC-32GA5U/LC-32GA5E 32 in. HD-Ready...
How do i connect a xbox 360 to a philips hts 3555 and hd tv?
Connect audio out cables (L and R) from HDTV to far left audio input at back of hts 3555. Then connect HDMI output from XBOX360 to HDMI input slot on TV. Setup XBOX 360 for audio through HDMI turn TV off and then on and all should be good. It worked for me.
May 25, 2010 | Philips HTS-3555 System
Connecting to HD TV
This TV has no HDMI input socket. It Has a DVI input socket. Therefore you will require an HDMI to DVI converter adapter or an HDMI to DVI cable. The DVI is video only so you will require audio cables from your Sky box (Audio L and R ) which will connect to the back left of your TV (Audio L/R sockets next to the s-video and component video connectors)
Nov 02, 2009 | LG RZ32LZ55 32 in. HD-Ready LCD Television
Connect tv to cable box with hdmi lead
You will need an HDMI to DVI cable which are available in the shops, even ASDA has one but I don't know how good it is. Or you can buy an adapter that will plug into one of the ends of the HDMI cable and then plug into the DVI socket at the back of the TV. The DVI input is video only so you will need audio leads for sound. These will connect from the output of your source, say, blue ray or sky HD (Left and right audio sockets ) to the audio L/R at the back left of the TV (on the block next to the three component video connections and s-video connections)
Oct 03, 2009 | LG RZ32LZ55 32 in. HD-Ready LCD Television
Toshiba 37x3030d
if it is an new 360 arcade, pro or elite with an hdmi output on the back, buy a hdmi cable. if there is no hdmi output on the back like most original 360's, buy the official 360 vga cable and conneect it to your pc input. this will ensure best quality, last resort is YcPcb
Apr 25, 2008 | Toshiba 37HL67 37 in. LCD HDTV
HD DVI HDMI problems.
As long as the phono socket is red or white. That represents Audio
Feb 13, 2008 | Televison & Video
Microsoft Xbox 360 Console Logo
135 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
