Question about GE GSH25JFR Side by Side Refrigerator
Freezer "Defrosts" on its own
Freezer continues to shut off every few days. Also Ice-maker does not work nor does water come out at all. I turn the freezer knob off then to 5 and it will usually freeze but doesn't last but 2 or three days then it begins to "defrost" again. Help please
  • 878 Answers
SOURCE: Freezer defrosts too long.
Outside of HVACRH20 excellent advice, here a few stats about this model. The main control board will monitor the resistance of the evaporator thermistor. This is located near the top of the evaporator. This thermistor determines when the unit goes into and out of defrost. The bi-metal is redundant to the operation. It will terminate the defrost only if the thermistor fails. Check the values of the thermistor with the attached chart. back
Posted on Jan 28, 2007
  • 1226 Answers
SOURCE: Ge Ice Maker Gs25sgmcbs
There is a problem in the water dispenser outlet of the freezer, in this case i will suggest call service tech of the freezer and the ice maker so that the system will be personally diagnosed thoroughly to resolved the existing problems.
Service center in your area maybe available and not then the vendor is the right person to contact.
best reagards, melnavz
Posted on Mar 04, 2008
  • 54 Answers
SOURCE: Freezer
If the freezer is in defrost then the freezer fan should be off. Only on the electronic will the freezer fan come on in defrost but the freezer door has to be held open for 3 min before the fan comes on
Posted on Jul 03, 2008
  • 149 Answers
SOURCE: defrost timer
this uses a adaptive defrost board its located in the fridge compartment in the back left side remove the cover and you'll see the adaptive defrost board if you have any questions don't hesitate to e-mail me @
here's an URL of the diagram (copy paste link to your browser)
Posted on Aug 02, 2008
  • 2651 Answers
SOURCE: Admiral HMG 62163 water leaking internally & freezing in lower basket
good attempt, its actually a clogged drain thats backing up and your drain water is not able to leave refrig so it falls to bottom of freezer floor and eventually out the door. romve the items from the freezer and take the lower back wall off form inside, directly under the evaporator under all that ice there is a drain hole, youll need to clear that hole of iec( pouring boiling water down until you get a free flow of water then you can reassemble uint problem solved
Posted on Oct 26, 2008
  • 1142 Answers
SOURCE: fan runs constantly, freezer ice melting, bottom drawer in refrig
  • If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
  • If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
  • If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
  • Posted on Mar 24, 2009
    0 characters
    1 Points
    I can freeze water in the freezer but food stuff defrosts. The fridge is not cooling the food. The interior light is on and working but the power indicator light is not.
    Many times cleaning the coils with a vacuum is over looked Bud. Please take a look. Let us know your progress. Thank you and leave me some feedback. The fridge and freezer will continue to run if these are not real clean.
    Jul 12, 2016 | Refrigerators
    I have a Westinghouse side by side refridgerater with water and ice dispenser. The other day I arrived home to find water pouring through the back of the freezer section into the ice maker,and into ice...
    Your water control has two sides. One side is for the ice maker and other is the water disapenser. If the ice maker valve becomes mechanically defective the water valve can allow water to continue to flow or not flow at all. Replace the water control valve and I believe this will solve this porblem, Thanks Sea Breeze
    Dec 11, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
    Ice maker is not working. doesn't appear that it's
    There are many things that can go wrong with a Kenmore refrigerator ice maker. Your ice maker may be leaking. It may not make any ice at all, or the ice that comes out smells or has an odd appearance. The problem may have an easy solution, or it may require a technician's expertise. The troubleshooting tips in this article will minimally make you aware of what is likely the source of the problem. You may be able to fix the problem yourself and save a bundle.
    When it Won't Make Ice
    1 Get a thermometer and see how cold it is in there. If your freezer is fewer than 17 degrees F, it won't make ice. The freezer temperature setting may be too high or the thermometer is broken and not calibrated correctly. If adjusting the temperature fails to work, call a Kenmore technician.
    2 Determine if your water fill spout in the freezer is plugged with ice. If so, no new ice can be made. Try clearing it out or melting the ice by running a hair dryer on it for a few minutes.
    3 Turn your refrigerator around to look at the back side to see if water is getting to the water inlet valve behind the fridge. If the water is not properly connected, there's no water to make ice.
    4 Use an ohm meter to test for coil continuity. If the ohm meter shows there is no continuity, then you will need to replace the water inlet valve.
    Have a good day : )
    Sep 03, 2011 | Kenmore Side by Side Refrigerator
    Our jenn-air side by side refrigerator with ice-maker has a problem. Quite often it makes a buzzing sound which seems to be more frequent than is normal. There is water inside the freezer which solidifies...
    Good day,
    You'll need to isolate the problem. Shut the water off to the machine to eliminate the ice maker as an issue. Clean up any mess left over and restart the machine with the ice maker set to the off position.
    Run for a few days to test the quality of the cooling capacity of the machine. If it tests O.K. then the ice maker situation can be addressed.
    May 10, 2010 | Refrigerators
    My subzero 650 ice maker drips water w/o making ice. Makes a mess with ice build up. I had to turn off water lined to stop the ice maker from dripping. Turning off the ice maker switch did not stop the ice...
    Good day,
    No, a new water valve should solve that problem. The diaphram in the valve is not completely closing.
    Very common problem.
    Thank you for using FixYa
    Dec 24, 2009 | Sub-Zero 650 / O Bottom Freezer...
    Amana Refrigerator Model # ARB 2214 CC with leaking ice maker
    Good day,
    If the fill pipe that fills the ice maker is in it's proper position, then it is a defective water fill valve located in the bottom rear of the machine.
    After harvesting the cubes the ice maker mechanism continues to rotate and turns the water valve on for 7 seconds. If it does not shut off smartly then it can cause the well to overfill, and flow water into the bucket.
    Do not let this go. A small leak could turn into a major overflow, even overnight causing serious problems to the machine and as I have seen the entire house.
    Dec 21, 2009 | Refrigerators
    My kenmore electronic fridge keeps building frost on the back wall i cleaned out the reservoir in the fridge part where the water drains and ran some hot water through and it worked ok for a couple of...
    check defrost timmer or defrost heater if the timer is working find the timer and turn the knob tell it clicks if it defrosts in a few min then you need a new timer or turn it manualy every few days
    Oct 19, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
    There is a burnt smell emanating from my freezer. The ice maker isn't making more ice. My freezer had been left ajar and there was freezer burn on several items. We shut the freezer and after two days I...
    Pour about 1/2 cup of water into icemaker . If it dumps the cubes , then replace the water valve . If it doesn't , replace the icemaker . Also make sure the refrig coils are clean and free of dust , lint , pet hair , etc....
    Aug 18, 2009 | Frigidaire FSC23R5D Side by Side...
    I have the exact same problem, curious if you have any answer...
    If the ice melts in the ice maker I think something strange is going on with the heating element below the ice maker. It comes on only for a few seconds before the ice drops. And is used to loosen the ice. But if water continues to flow from the water control valve while the ice maker is full it has no where to go but into the freezer and refreeze. Sometimes the water control valves have trash buildup inside the valve and will not shut and allows the water to continue to flow. About the only way to solve that is replace the water control valve and place a pre-filter in the line before the water reaches the valve. Thanks, Sea Breeze
    Aug 18, 2009 | GE Profile PSW26P Stainless Steel Side by...
    Ice Maker water keeps running
    Bad I/M, won't shut off after harvest and continues to restart cycle. Heater in I/M should warm up thermostat after first harvest and stop unit from recycling.
    Jul 13, 2008 | Frigidaire PLHS237ZD Stainless Steel Side...
    GE GSH25JFR Side by Side Refrigerator Logo
    56 people viewed this question
    Top Refrigerators Experts
    Vish Iyer
    Vish Iyer
    Todd Marr
    Todd Marr
    John Tripp
    John Tripp
