Question about Olympus FE-270 Digital Camera
Olympus FE-270 - battery issues
I have an Olympus FE-270 and currently use rechargable Ni-MH batteries. Regardless of whether i use those ones rechharged or new AA batteries the camera continually tells me the battery is flat. I am lucky to get 4 photos out of the batteries some times. Can you pls assist?
Someone mentioned it could be the memory card but that is an XD as recommended.
  • 1 more comment
  • katiemuzz Jan 13, 2009
    If that is the case is it fixable?
    Other people have reported the same problem and the recommendations were to change the batteries to the type i'm using. Is it possible its the batteries - or is it definitely the camera?
    If so, who can fix this issue?
    Do i need to try and diable it to test it? If I was able to diable those functions doesn't that defeat the purpose of having a camera with those functions?
    Is it worth taking it to a camera shop or just buying a new one? It seems strange that Olympus haven't recalled these cameras if its such a prominent issue.
    Are internal problems in cameras fixable?
    Brand new batteries and fully recharged batteries do not work - and have never worked. Do i need to buy higher voltage batteries? They are 2000 MAh.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Other than cleaning the battery connectors/terminals inside the camera's battery compartment, may I suggest that you try:
  • scrape the connectors/terminals. The idea is to expose fresh metal in the possibility of corrosion;
  • slightly bend or stretch the contacts/terminals. The idea is to ensure more pressure connecting to the batteries.
Pls post back result(s). Good luck and Thank you for using FixYa.
Posted on Jan 19, 2009
    Genius:
  • 1,011 Answers
Sir,
Many peoples have the same problem. Check this link. It is the problem of bad sensor. Check replacement if you have warranty. Also try with 2500 mAh Energizer Batteries. Energizer is best in market.
Posted on Jan 15, 2009
  • 10,515 Answers
Have the metal contacts on both the battery & charger been cleaned? Use a pencil eraser and clean both sets of contacts. (Also check that the power cord is inserted correctly into the back of the charger. It is easy to come loose and stop the charging.)
You should consider buying a new battery. Not only to help analyse the problem, but to use as a spare. I love my FE-270, but realized a long time ago that it's best to have a spare battery when you are out shooting all day.
Good luck,
    Problem Solver:
  • 37 Answers
Hello katiemuzz,
My experience with batteries and cameras have varied, but there are two things for certain. Features and temperature.
Features
Using the "advanced or manual" features on your camera such lengthening exposure time can quickly deplete batteries so make sure the camera is set to Auto.
Temperature
If you are shooting in extreme temperatures (especially if it's really cold) batteries don't seem to cope well and sometimes won't work at all.
If these two factors don't apply (and the other solutions didn't work), then I would venture to say it definitely in need of repairs. To price a repair through Olympus you can call (800) 622-6372, Monday - Friday, 8:30am - 7:00pm Eastern Time. Their Customer Service and Repair page has more information that may help you.
Regards,
Jordan
    Scholar:
  • 89 Answers
Im thinking it might be the charge detector.  it detects the milliamp charge from the battery and gives the camera a formula as to how many pics it can take.  but honestly i haven't the foggiest on how to fix it other than to take it to a camera shop.
good luck
    Sergeant:
  • 221 Answers
As if cleaning the connectors does not helps.as you have tried replacing the battery it does same.so it clearly indicates of a error in camera itself.as if the device is too old.replacing is the best option.but if its new just get it replaced oir repaired at a repair center.sometimes there is just a silly single soldering issue and the device starts working.so its woth taking a chance to take it to the repair center.if the repair estimate is very high.going for new is advisable
Posted on Jan 14, 2009
    Scholar:
  • 160 Answers
Yes that can be easily fixed.and is worth getting it repaired.
also local repair center near your area will be helpful for this issue but if you does not find any relaible then
here is the link below just click it.
http://www.advancecamera.com/repair
the link will help you to get the device repaired and serviced
· Free estimates.
· Reasonable rates.
· Fast, friendly, and personal service.
· Top quality repairs.
· Advance Camera 1 Year Warranty
Posted on Jan 13, 2009
    President:
  • 1,990 Answers
Welcome to Fixya! Have you Tried Cleaning the Connectors? Where the Batteries go in, Get a Q-Tip and Put some Alcohol on it and Clean the Connectors for the Balleries. Pencil Erasers Work also.
  • 1 more comment
  • Travis Humphries
    Travis Humphries Jan 13, 2009
    If this does not work, You probably should Get it Replaced. I have looked in the Archives for this Problem and Not one person has been able to get this Fixed without taking it back or Replacing the Camera.
  • Travis Humphries
    Travis Humphries Jan 15, 2009
    I would Definately have it Repaired at an Authorized Service Center If you wnt to keep it.
  • Travis Humphries
    I did some further research on this after the First post and that seems to be the Resolution for 99% of Consumers with this Problem. Different Batteries will do Nothing.
  • 818 Answers
Fuji xD Picture Card - 1GB (Type M)for your memory
Uniross 2700mAh AA Rechargeable Battery - FOUR PACK
Ansmann AA 2700 mAh Rechargeable Battery - FOUR PACk
Hama AA 2700 mAh Rechargeable Battery - FOUR PACK
Seems that this can work for you.
Sergio
    Genius:
  • 1,269 Answers
There's a problem with the camera itself. It drains the battery too much. You can try to disable the Screen Display and Flash first to check if the battery lasts long.
    Sergeant:
  • 378 Answers
It is quite possible that the internal connections are lose and not able to carry reqiure power to device.that why it show battery flat.
    Top Expert:
  • Olympus Master
  • 77,499 Answers
There is a battery level/charge sensor circuit, if it senses the voltage is below a certain level, about 2.75 volts it will tell u the batteries are in need of charge or replacement, there must be a problem in this sensor. Have u checked the voltage of the batteries it says are flat? they should be over 1.5 volts for a new battery
Type of battery
The Ni-MH batteries are recommended for the active photographer. The NI-MH batteries are rechargeable, economical and work well in low temperatures. The CR-V3 Lithium Batteries are recommended for the less active photographer. They are lightweight, non-rechargeable batteries that provide hours of shooting.
Sep 04, 2005 | Olympus Camedia C-770 Digital Camera
Ni-MH Batteries
The Olympus Ni-MH batteries will provide approximately 200 shots with typical usage (half of the images shot with flash/half without flash and minimal use of the LCD monitor). These batteries are also rechargeable.
Type of battery
Sep 04, 2005 | Olympus Camedia C-765 Digital Camera
Batteries
Type of battery
The Ni-MH batteries are recommended for the active photographer. The NI-MH batteries are rechargeable, economical and work well in low temperatures. The LB-01 CR-V3 Lithium Batteries are recommended for the less active photographer. They are lightweight, non-rechargeable batteries that provide hours of shooting.
Sep 04, 2005 | Olympus Camedia C-740 Ultra Zoom Digital...
Rechargeable batteries
Yes, there are two rechargeable sets, the B-80SU Ni-Mh Overnight Charger and Battery Set and the B-90SU Quick Charger and Battery Set. Each comes with four rechargeable Ni-Mh AA batteries.
Sep 04, 2005 | Olympus Camedia C-5500/C-55 Sports Zoom...
Battery life expectancy
Olympus Ni-MH batteries will last approximately 60 to 80 images and can be recharged about 500 times. The Olympus CR-V3 long-life lithium batteries provide power up to 2 times that of Ni-MH batteries. The CR-V3 long-life lithium batteries are NOT rechargeable.
Aug 31, 2005 | Olympus D-460 Zoom Digital Camera
The battery life on alkaline batteries vary according to manufacturer and power rating. Alkaline Batteries can provide up to 100 shots with typical usage. The Olympus Ni-MH batteries (B-01 4PE) would provide approximately 250 shots per charge and they can be recharged 300 to 500 times. Olympus recommends the use of CR-3V litium battery packs or NiMH rechargeable batteries. Do not use alkaline batteries unless it is absolutely necessary.
Aug 31, 2005 | Olympus Camedia D-425 / C-170 Digital...
Battery
Aug 31, 2005 | Olympus D-400 Zoom Digital Camera
Olympus FE-270 Digital Camera Logo
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
