I saw a 5 inch radio type antenna that pluged into a audio outlet
The computer was now capable and recieved 10 wireless sites including internet explorer,I heard a cheap unit was available can you send information to blueoceanwv@gmail.com
signed Troy David Lindquist
SOURCE: Cannot access secure sites using Internet Explorer on HP Jornada 720 running HPC 2000
Download and install HPCTweaks2k2v06.exe then apply the "identify PIE as IE 6.0"
Posted on Aug 01, 2008
bunnydawg
  • 5158 Answers
SOURCE: problems signing in
almost sounds like your browswer is being hijacked tho i don't use the site. i would suggest running a spyware program.
Robert
Posted on Sep 19, 2008
yourpc
  • 190 Answers
SOURCE: Wireless internet connection problem
You may be having a problem with the settings in internet explorer. If you open your internet explorer and then click tools then internet properties you will have a window pop up with several tabs. Click the tab that says connections. Down towards the bottom right is a button that says LAN SETTINGS click that and make sure that there is a check in the box that says Automatically Detect Settings. Click OK Click APPLY Click OK. Restart Internet Explorer and see if it connects.
If that doesnt work reset your wifi adapter. Step by step instructions here:
http://www.icompute.info/fix_wifi.htm
If that doesnt work then open the command prompt by clicking Start then run (vIf you have Vista click in the search menu above the start button) Type CMD and hit enter. You should see a black and white screen that looks like old DOS. Dont worry about what the prompt says. Type IPCONFIG and hit enter. You should see your networking adapters. You should see one with a 192.168.-.- (Linksys routers normally make the first computer 192.168.1.100)
If you see a 196.254.-.- or media not connected then your device is not connected. This will at least tell you if windows is getting a proper IP address.
Some people might say your WinSock files need to be repaired If everything still does not work then you may have a WinSock file or files that are missing or corrupt. This is probably not the case since you can connect hard wired but if you want to try repairing your winsock files then with XP you can use a program from the internet called winsockfix. If you have Vista then when the no connection error comes up you should see a link that asks about trying to fix the problem. If you see this click it and let Vista fix Itself.
If none of this works then try a different adapter. Hope this helps...
Posted on Apr 11, 2009
SOURCE: i cannot turn on my wireless capability
To the satellite E105 S1402 with WiFi problems. The solution is:
1. Make sure that your router is operational.
2. Make sure that the WiFi switch is on.
3. If your Wifi used to work out of the box, then you need to buy a Flash Drive (if you don't already own one), then you need to do a Backup of all your users documents on the Laptop.
4. Use the CD's that came in the box to re-install Vista 64.
Don't waste time with Toshiba support, you will end up in Phillipines and quite honestly, I am shocked that Toshiba does not have a better support process.
I had the same problem and I had to re-install the OS. It is not that painfull to do and should take about 1/2 hour.
Cons: You have to re-install additional software that you installed after purchasing your laptop.
Posted on Jul 24, 2009
rentpal
  • 80 Answers
SOURCE: For some reason I can't log in to gmail one specific computer
perform a browser reset by going into: tools - internet options - advanced - reset.
2. remove all the tool bars from add or remove programs.( like google , yahoo tool bars)
Posted on Sep 26, 2009
Ranger superstar 33 no recieve
If you're still getting loud squelch noise but do not receive on any channel, you must check the RF from the antenna to the audio stage(not included). There must be more than just one RF stage in this radio. Let me know what you find.
May 08, 2013 | Radio Communications
English user manual samsung gt-s6352
Detailed Technical Datasheet of Samsung GT-S6352 Galaxy Ace Duos
Brand:
Samsung
Browse Samsung devices
Manufacturer:
Samsung Electronics
Browse all devices manufactured by Samsung Electronics
Hardware_Designer:
Samsung Electronics
Release:Date:
May, 2012
Physical:Attributes
Dimensions
(width x height x depth):
61.5 x 112.8 x 11.37 millimetres
2.4 x 4.4 x 0.4 inches
Bounding_Volume:
78.9 cubecentimetres
Mass:
122 grams (battery included)
Software_Environment
Embedded:Operating_System:
Google Android 2.3.6 Chinese
Browse devices running this OS
Operating+System-Kernel:
Linux 2.6.35.7
Microprocessor,:Chipset
CPU-Clock:
832 MHz
CPU:
Broadcom BCM21553
Browse devices based on BCM21553
Width;of;Machine_Word:
32 bit
CPU+Core:
ARM1136
Instruction:Set:
ARMv6
Memory,;Storage;capacity
RAM+type:
Supported
RAM;capacity:
512 MiB
ROM_type:
Flash EEPROM
ROM_capacity:
3814 MiB, including 3000MiB user-accessible non-volatile storage
ROM;capacity-in_bytes:
4 GB (billion bytes)
Graphical-subsystem
Display_Type:
Supported
Display+Color_Depth:
18 bit/pixel (262144 scales)
Display:Diagonal:
3.5 " (89 millimetres)
Display-Resolution:
320 x 480 (153600 pixels)
Viewable;Display:Size:
1.94 " x 2.92 " (49.37 x 74.05 millimetres)
Pixel-density:(dot_pitch):
164.6 pixel/inch (0.15428 millimetre/pixel)
Graphical_Controller:
Broadcom BCM21553
Audio+Subsystem
Audio_Channel(s):
stereo sound
Microphone(s):
mono sound
Loudspeaker(s):
mono sound
Audio;Output:
3.5mm plug
Cellular+Phone
Cellular:Networks:
GSM850, GSM900, GSM1800, GSM1900, UMTS900 (B8), UMTS2100 (B1)
Cellular-Data;Links:
GPRS, EDGE, UMTS, HSDPA, HSUPA
Cellular_Antenna:
Internal antenna
Call;Alert:
64 -chord melody (polyphonic)
Vibrating-Alert:
Supported
Speakerphone::
Supported
Phone_Controller:
Broadcom BCM21553
Secondary;Cellular;Phone
Dual;Cellular:Network-Operation:
Parallel operation
Secondary+Cellular_Networks:
Secondary+Cellular-Data_Links:
GPRS, EDGE
Secondary_Cellular-Antenna:
Internal antenna
Control:Peripherals
Positioning:Device:
Multi-touch screen
Primary_Keyboard:
Not supported
Directional_Pad:
Not supported
Scroll:Wheel:
Not supported
Interfaces
Expansion;Interfaces:
microSD, microSDHC, TransFlash
Supports High Capacity (SD 2.0/HC) memory cards with capacity of up to 32GB
USB:
USB 2.0 client, Hi-Speed (480Mbit/s)
USB Series Micro-B (Micro-USB) connector
Bluetooth;(802.15):
Bluetooth 3.0, Internal antenna
Wireless+LAN/Wi-Fi:(802.11):
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Internal antenna
Infrared-Gate:
Not supported
Multimedia+Broadcast
Analog:Radio:
FM radio (87.5-108MHz) with RDS radio reciever
Proprietary headset as antenna
Digital+Media;Broadcast:
Not supported
Satellite_Navigation
Built-in;GPS_module:
Supported
GPS+Protocol:
NMEA 0183
GPS+Antenna:
Internal antenna
Complementary+GPS:Services:
Assisted GPS, QuickGPS, Geotagging
Built-in;Digital:Camera
Sensor_Type:
CMOS sensor
Resolution:
2592 x1944 pixels (5.04MP)
Autofocus:(AF):
Supported
Optical+Zoom:
1 x
Macro_Mode:
Supported
Built-in_Flash:
Not supported
Camcorder:
640x480 pixels
Recordable-Image;Formats:
JPG
Recordable;Video-Formats:
3GP, MPEG4
Power;Supply
Battery:Technology:
Lithium-ion battery
Battery;Build:
removable
Battery-Capacity:
1300 mAh
Additional-Details
Built-in-accelerometer:
Supported
Additional;Features:
  • capacitive touchscreen
  • digital compass
  • GPRS Class 10
  • EDGE Class 10
  • HSDPA 7.2
  • HSUPA 5.76
  • Samsung TouchWiz UX
  • Bluetooth stereo audio profile (A2DP
  • AVCRP)
  • Wi-Fi Mobile Hotspot
Related-Page:
http://www.chinaunicom.com.hk
Datasheet:State:
Final specifications
Datasheet;Views:
7614 times
Datasheet-Added:
Jul 22, 12 17:55:27
REGARDS,
TARIQ KHAN
Jan 15, 2013 | RIM Computers & Internet
I get no internet on computer while connected to internet while router is pluged in. but do get wireless
WIRELESS SECURITY ISSUES
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Step 15 : IF NO CONNECTION SHOWS UP ON THE LIST ... THEN PLEASE MAKE SURE THAT THE WIRELESS SWITCH ON YOUR COMPUTER IS ON
Let me know if it works
Dec 01, 2010 | Belkin Wireless G Plus MIMO (F5D9230-4)...
I have a 4watt UHF/5watt VHF 2way radio which transmitts at 410-480Mhz, with an FM radio. i am looking for an antenna which will recieve the radio and also send and recieve messages from another radio. i...
You would need to get the antenna specifically designed for your handheld. Sometimes these will come in different band splits such as 450-470 MHz and 436-460 MHz. You would choose the band split closest to the frequency you commonly operate on. Using an antenna not designed for your radio can cause problems with the radio, such as you mentioned, including beating up the internal power amp. (Same problem exist if someone presses the PTT when there is no antenna on the radio.) Contact a radio dealer who offers your type of radio for more info and to find out what types of antennas are designed for your radio.
If you are talking about a mobile vehicle radio. There are a wide variety of antenna types and the antenna is cut to suite your frequency.
Sep 24, 2010 | Radio Communications
Does the 2005 GX470 Lexus play mp3 files?
Audio & Entertainment Audio System Lexus Premium Sound System with Automatic Sound Levelizer (ASL) and in-dash, six-disc CD auto-changer Speakers 11 Audio System Mark Levinson® [3] Premium Audio System with Automatic Sound Levelizer (ASL) and six-disc DVD/CD auto-changer Optional
Speakers 14 Optional
Watts 240 @ 0.01% THD, 20-20,000Hz [21] Optional
MP3 Audio Input Plug MP3 audio input plug Rear Audio Rear-Seat Audio System (RSAS) Optional
Antenna In-glass antenna with FM-diversity system Satellite Radio XM® Satellite Radio capability [22] Optional
DVD Entertainment System Lexus DVD Rear-Seat Entertainment System (RSES) Optional
Wireless Headphones Included with DVD Rear-Seat Entertainment System (RSES) [23] Optional
http://www.lexus.com/cpo/model_library/GX/2007.html Wheen you click this link scroll to the bottom of the page. It will be under Audio & Entertainment.
Mar 14, 2010 | Sony MHC-GX470 Shelf System
I have a NETGEAR wire/wireless router MBR624GU. My internet provider is Comcast using a high speed internet modem by Ambit model U10C018. I connected the Comcast modem to Router LAN port using a Ethernet...
If you connect the computer directly to the modem, does it work?
If that works then the modem is working.
Now connect the computer to the router and the modem to the router.
You will need to open the set up page of the router to check the settings of the router.
You can set up the router without the CD also.
It is very easy.
Click Here for step by step instructions about how to set up the router
Dec 10, 2009 | NetGear MBR624GU Wireless Router
Sirius satellite radio constantly shows "acquiring signal"
it could be the connection on the back of the reciever that could be bad. I would call sirius and see if your reciever is under warranty still, if not i can almost garauntee that your tuner antenna input is bad, if your antenna is brand new.
Apr 15, 2009 | Sirius Audio Players & Recorders
Hands free
You do not mention what type of radio you are using. However, it is possible
1) you are plugging in the audio device with the radio turned on. If so, the result will be as you describe. Simply turn off the radio and replug the device with the radio turned off. In most cases this will solve the problem. Or a simple press of the PTT while it is locked in transmit, will return the radio to Push-to-Talk mode.
2) You are using an audio device which is not designed for the radio. OR
3) Your radio is stuck in Transmit.
If all else fails, shut off the VOX capability of the radio.
Oct 21, 2008 | Motorola Walkie Talkie 2-Way Radio
Fm Radio signal?
There was a black wire included (with a metal "cap" to insert in the FM center connector) that served as the FM antenna, but in a pinch any wire can do, preferably about 33" long and with the insulation stripped from the last inch or so (or get creative and sand the last inch of varnish off a properly sized untwisted clothes hanger and gently bend to suit). Bare stranded wire should be twisted or folded until it's thick enough to firmly fit the middle "hole" of the FM antenna connector. Be careful that no strands of wire short to the metal ground "ring" surrounding the hole or the antenna won't work (although it won't burn out your amp like shorting the speaker wires would, it just won't work). Orient the wire horizontally or vertically for best reception. This unit also doesn't pick up FM very well if you're in a steel-framed building or away from windows in the general direction of the local transmitters, so moving the unit closer to a window may help dramatically. In bad reception areas you can get an external FM "rabbit ears" type antenna but you'll need the "European" style of 300 ohm to 75 ohm transformer to plug it into the unit's FM connector (one that has a bigger central connector "plug" than the usual US units). Some cable systems also still support FM, if yours does, a VHF/UHF/FM signal splitter and either the above mentioned transformer attached to flat 300 ohm cable or a plain  "European" style connector attached to the end of the 75 ohm round black cable will do the trick. Some Radio Shacks have them. Good luck!
Jul 23, 2008 | JVC FS-5000 CD Shelf System
How far can that midland 1001z radio transmit.And recieve.
Running most any regular cb, including this one barefoot (with no kicker), having a good antenna, set up with a good ground plane or a no-goundplane antenna, good coax; basically everything in good working order, you can usually bank on about 4 to 5 miles crisp and clear, and at least 6 to 10 miles fairly clear. Of course the further out you get it will start to fade out.
Some radios do better than others, but those are the general numbers I have seen in my years of experience.
Dean Pitts
Rollin CBs
Mt. Vernon, TX
Apr 27, 2008 | Midland 1001Z 40-Channels Base CB Radio
Computers & Internet Logo
David Payne
David Payne
