Question about AO Smith 2 Hp Spl 3450rpm M56 Frame 115/230 Volts Replacement Air Compressor Motor Electric Motor No.B381
Air compressor/ alot of air is coming out of the oil cap vent.
I have a 5.5hp 80 gallon Blackmax two stage air compressor. When the compressor is running , I am getting alot of air coming out of the vent hole in the oil filler cap. This in turn is blowing out oil and making a mess. Any ideas what is causing this. Thanks for your time.
  • Anonymous Mar 29, 2014
    what is the recommended oil for 3 stage vespa air compressor
  • 70 Answers
This could be blow back possibly bad piston rings you may need new rings oil chamber is usually at intake pressure unit may need rebuild
Posted on Jan 24, 2009
Hello...I have a blackmax 60 gallon 6 hp compressor. Model # BL6006016. Twin cylinder, single stage. What kind of oil do I use ? Thank you!
Compressor oil is less demanding then cars, but car oil works fine. Normal 1W-40 would probably work the best.
You would hardly ever have to change it either, because there is no water, soot, or acids produced in a compressor, as there are with a car.
Feb 26, 2011 | Coleman Powermate 60 Gallon Air Compressor
Oil in my air line
Oil in the air lines indicates you have air pump problems; either worn or broken piston rings or badly scored cylinder wall(s), usually both. You'll have to disassemble the air pump or take it to a service center to find out what's wrong inside pump.
Feb 01, 2011 | Ingersoll Rand TS4N5 Ir Electric...
Can't get it to come on when it's cold.
Warm it up with a heat lamp, hair dryer etc. Release all air pressure from the tank first. Check your oil and use only compressor oil.
Dec 22, 2010 | Ingersoll Rand TS4N5 Ir Electric...
Question is whether to get an Kobalt 80 gallon 14 CFM at 90 one stage or a 60 gallon IR 18CFM at 90 if the price is the same and CFM is not the issue, but the quality of the item?
your choice of an air compressor should be based on what you are going to be using it for first of all .single stage compressors are good for about 125 psi 2 stage up to 175.which whatever one you choose do not get a oilless they wont last .you want a cast iron pump which requires oil lubrication.pumps which are made of aluminum are throw a ways
Aug 04, 2010 | Air Tools & Compressors
Lubrication for piston in mini air compressor
I don't know of any small compressors that require lubrication.
I have 3 ranging from a 1 gallon to a 25 gallon and none of them need lubed
Only my 80 gallon 2 stage requires lube
Mar 05, 2010 | Air Tools & Compressors
Temperature rising
Make sure that your pully fan is blowing across ehe fins. Check and clean the air intake filter. Check the oil level.
Regards, --W/D--
Jul 16, 2009 | Ingersoll Rand Type 30 Fully Packaged Ir...
Compressor spewing Oil
hi your machine will discharge oil from the vent if your rings or bores are worn ,if the oil comes out with the air the your valves are broken or not sealing
hope this helps
ian
Mar 22, 2009 | Coleman 6.5hp - 80 Gallon Vertical ASME...
Compressor wired wrong from the factory and will not run.
I cannot find any diagram from this description. do you have a model # of motor?
Mar 08, 2009 | Ingersoll Rand Type 30 Electric Driven Two...
AO Smith 2 Hp Spl 3450rpm M56 Frame 115/230 Volts Replacement Air Compressor Motor Electric Motor No.B381 Logo
1,074 people viewed this question
Top AO Smith Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an AO Smith Air Tool and Compressor Expert? Answer questions, earn points and help others
