Question about Vacuums
I have a Kenmore canister serial number DB12027279, model 116-2234590. The problem is that the power cord plug gets very hot. Please advise what to do. Thank you.
  • rocasan Jan 14, 2009
    I followed your instructions but I still have the problem.
    Thanks anyway.
  • 4 Answers
Just a suggestion, as the debris enters the machine, it has to pass the motor. The motor has vents around it. Enough "debris" gets in that motor, the motor starves for power, which inturns make the media, the cord, work harder.
Or check your house wiring.
Posted on Jan 14, 2009
I need a model number for the kenmore durapower vacuum. Don't have the manual can't find on vacuum
Hi There,
The model number will either be located on the bottom or the back of the machine on a sticker that also contains the serial number. All vacuums have to have this sticker, and serial number information on the machine somewhere. On uprights it's usually on the back of the machine towards the bottom, or on the very bottom of the floor nozzle part. On canister vacuums the model number will either be found on the bottom of the canister, or on the bottom of the power nozzle.
Hope this helped!
Chris
Apr 20, 2010 | Kenmore Vacuums
Cord rewind nonoperational
sounds like the spring is either over stretched or broken. you may have to have the spring replaced
May 11, 2009 | Bosch BSG71360UC Bagged Canister Vacuum
Canister motor not on - power to power mate is on
if its a long plastic tube with snaps on it that is where the fuse is.open it up and you will find the fuse
Apr 28, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Open power cord housing on kenmore 116 vac
You can go to the Sears Parts Direct website and type in your Model number. It will return both an exploded view and parts list, with pricing for replacement parts. You can also order from them, and they can tell you stock status as well.
Jan 15, 2009 | Kenmore 25512/ 25513 Progressive Canister...
Hot cord
likely after all these years that the motor is starting to go bad and draw more amps thasn it should. a new motor at a vac dealer is your best bet. it was likely made by panasonic, so a new panasonic is your best bet, and less $$$than the kenmore for the same vacuum. sears parts are extremely expensive
Sep 06, 2008 | Kenmore 23313 Whispertone Bagged Canister...
4.3 amp Kenmore canister vacuum power switch has failed
You did not give the complete model number, but you can go to sears.com, click on parts and put in you model number. You will get links to click on, click on the cannister one and you get a picture breakdown and a parts list, you can also order after choosing the part you need.
Aug 09, 2008 | Kenmore 22812 Bagged Canister Vacuum
Kenmore vacum wand power cord
http://www.vacsew.com/vacuum-cleaners/kenmore-vacuum-parts.html/
Try here
Jul 16, 2008 | Vacuums
Need to replace power cord and can't find how to open canister to replace
I had the same problem and could not find the other screws. You need to pry off the power cord retraction button, you will find two more screws under there. It's pretty easy after that!!!!
Jun 02, 2008 | Kenmore 22612 Bagged Canister Vacuum
Losing power to stick/floor vacuum
if you have an extension wand, the replacement will cost about $100.00. there is a way to repair both the pwr-cord on the brush assemble and the wand, but it depends on how much damage there is. also you need to check the contacts where the wand connects with the handle,and the prongs on the handle.
let me know if you still need help
Jan 11, 2008 | Kenmore 25614 / 25615 Progressive Bagged...
Vacuums Logo
147 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
