Question about Singer 1507
Threading i cant thread the machine
  • fotimoto Feb 04, 2009
    I can't thread the machine either.
  • hobiedog2 Feb 08, 2009
    I cant thread my 1507 either....I can't find the take up lever on the top of the machine, it seems to be missing...does anyone know if there is a trick to finding it?
I had the same problem. You will have to open the machine as if you are changing the bulb (there's a screw a the side). Then lift the lever. It looks like a small hook, then put the case back on.
Posted on May 16, 2009
How to thread a Empisal overlocker.. model 760C
Perhaps the manual would help:
Empisal Overlocker 760C Empisal Sewing Machines
On most machines, it is important to ALWAYS raise the presser foot when threading the machine (although the instruction manual says to raise the presser foot only to pull the thread tail under it). Be sure to give the thread an extra little tug when going through the tension disk to seat it properly. Be sure to thread in the order as specified (Upper looper, Lower looper, Right needle, Left Needle). If the machine messes up, it is usually a best policy to remove all the thread and rethread from the beginning. Threading out of order will almost guarantee failure!!!
Jul 20, 2016 | Sewing Machines
I cant feed the overlocker.. so it dont want to work
Best to refer to the owner's manual. You can search the internet for the Make + Model + the word "Manual" and you may find a free download.
ALWAYS raise the presser foot while threading the machine.
Be sure to thread each in the order specified in the manual (usually, Upper Looper, Lower Looper, then the needles). Threading in the incorrect order will guarantee failure!
If a thread breaks or the machine messes up, it's usually best to remove All the threads and rethread from the beginning.
To start out, it helps to use a combination of different color threads.
Set the tensions to the midway point (the standard for basic overlocking).
I cant get tension on the upper thread
Consult your owner's manual for the proper threading sequence--your machine could be threaded incorrectly..
Totally remove the upper thread. BEFORE re-threading, RAISE the presser foot so the thread will seat properly in the tension disk. Be sure to lower the presser foot before trying to sew.
Oct 29, 2015 | Sewing Machines
Thread jamming
try changing the needle-flat side goes to the back of the machine
rethread the machine top & bobbin--make sure to use every top thread guide
clean under the needle plater & in the bobbin area for lint or loose threads
make sure the thread doesn't come off the thread take up lever
Apr 03, 2012 | Brother XL-2600I
I cant get my needle to pick up the bobbin thread
You can download a copy of your manual for free on under customer support if you need to see the correct way to thread your machine. Hope this helps
Oct 01, 2010 | Singer 8280 Mechanical Sewing Machine
I cant set the tension on my PFAFF 7570 the thread keeps
First make sure your needle is in correctly. Then make sure you are threading the machine correctly especially make sure you thread the take-up lever. Make sure your tension dial is at a 4 to 5. if this does not work, let me know
Oct 19, 2009 | PfaFF Creative 7570
How do i thread this machine
thread this machine by taking a strain of thread from the spool pull it to the thread guide on top left side of machine criss cross the thread when you wrap it around the thread guide pull thread down and loop it under the needle thread tension control dial bring thread up and loop it on the thread take up lever, continue down to the needle looping it first around the metal piece above it then through the needle it self pull thread to back of sewing manchine with the bobbin thread
Feb 12, 2009 | Brother LS-1217 Mechanical Sewing Machine
Cant find a manual or thread machine properly.
Submit a new question providing details on manufacturer and exact model, click here to submit a new query.
Nov 15, 2008 | Sewing Machines
Have a look at this website on the threading page, if your machine is not listed look at some of the other Kenmore machines and you will get the idea of how to remove the bobbin case. Basically you will find a small latch across the front of the bobbin case, pull the latch away from the case and hey presto.
Apr 23, 2008 | Sewing Machines
Singer 1507 Logo
310 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
