Question about Frigidaire PLEF398AC Electric Kitchen Range
Convection cooking Bought our first convection oven. Frigidaire stove. Not sure at what temps to cook roasts. Only used to conventional ovens. Please advise.
Convection ovens are great for roasting!
I cooked a 15 lb  stuffed turkey in 2 hours in mine. And it was juicy and fab!
My auto degree set for convection  is 325.
I have a Jenn Air wall oven, so I don't know, it might be different for different brand.
Roast or bird should be in the middle of the oven. THe air has to circulate well to get best results.
I believe rule of thumb is a convection oven takes 1/2 LESS time than conventional.
Hope this helps.
Posted on Jan 13, 2009
I've been cooking a 3lb Chuck roast in a conventional oven at 350 for 2 hrs and it's still tough, although vegetables are well done. IS there a way to fix it, making
the temp is about right and the time is 2 3/4 hours for medium rare
in your browser bar type in ---cooking times for 3lb chuck roast--and there are recipe pages for all cuts of beef , temperatures and times
Jan 13, 2018 | In Microwave Ovens
Tip
Difference between a convection oven and a conventional oven
<span>A convection oven is equipped with a fan to speed the circulation of heat around the food, thus cooking it faster and more evenly than conventional ovens. <br /><br />Conventional ovens rely on radiant heat that rises from the bottom up to the top of the oven. Convection ovens cook foods approximately 25% faster than conventional ovens, and the oven temperature can be reduced by 25&deg;F for most foods. <br /><br />No special cookware is required. Just like conventional ovens, convection ovens can be gas- or electrically-heated. As with any major appliance, it is always best to carefully read the manufacturer's guidelines and instructions for operating the oven.</span>
on Apr 04, 2011 | Microwave Ovens
What does convection cooking mean?
A convection oven cooks food with heat; much like a conventional oven. It is faster, though, as it circulates the air around inside the cavity.
So, it's faster than a conventional oven, but slower than a microwave oven.
Conventional ovens which also microwaved at the same time, have also been manufactured.
They were also faster than a conventional oven, but slower than a microwave. But they were not the same as a convection oven as they did not circulate the air.
May 28, 2016 | Microwave Ovens
Convection fan runs from start up , but when temp ia achieved , fan stops working and shows con on the display
Search Results
    Frustrated with new Samsung stove! - Forums - CNET
    www.cnet.com > Forums > Samsung
    CNETWe purchased a smooth top, convection Samsung range , with delivery on ... I seem to have the same problem with my new samsung range FER700WX. ... That ovenwould not reach temperature and if it did, it would not keep the temperature. ..... 3) as the oven restart the convection fan or fans blow such hot air the food in ...
    Convection 101: A Guide to Cooking With Fans - Oven ...
    ovens.reviewed.com/.../convection-cooking-101-a-guide-to-cooking-ba...
    Apr 4, 2015 - Problem is, it uses a ton of water. 6.2 ..... Convection ovens use a fanand an extra heating element to correct ... it's best to reduce oven temperature first, before adjusting cook time. ... range or wall oven, there's simply no reason not to ponyup. ... From futuristic to freaky, these fixtures run the entire spectrum.
    New Bosch range convection fan not moving? - Home Forums
    ths.gardenweb.com > Home Forums > Appliances
    Oct 8, 2007 - On my range (the slide-in version) the cooling fan runs even when in ... I was the one with the Bosch fan problem and if there is a problem with ... Mine does stop turning when I open the door and starts again when I ... convection roast feature, and once the oven reached temperature, ... Sign Up to Comment.
    Troubleshooting Gas Range and Oven Problems ' Back ...
    blog.etundra.com > Tundra's Tech Talk
Jan 17, 2016 | Kitchen Ranges
Will a plain fan convection/microwave ROAST/BAKE as well as a "true" convection that has an extra heating element and fan convection/microwave
Most likely the Kenmore is actually made by Sharp. Most of the combination microwave/convection ovens are. I have one with a "Wolf" name on it, and it roasts/bakes very well.
Apr 07, 2015 | Kenmore Kitchen Ranges
Cooking with convection oven
You do not have to remove the turn table, but I use the metal rack when cooking with convention.
Apr 15, 2014 | GE Profile PEB1590 1.5 Cu. Ft., 1000W,...
I just bought this oven & my daughter lost the manual that goes with it. I need to know how to use the rotisserie feature. Also need to know if the rotisserie can be used for a roast. Thank you. =)
You might not want to use it again after your first experience. Make sure you get your food balanced as the motor on this thing is very weak. I cooked 2 chickens and a loin roast when I first got it and they were no better than pan roasted and a lot more trouble.
I have posted the complete manual (3 language edition) here:
http://216.92.50.93/Manual.pdf
Dec 30, 2010 | Hamilton Beach 31197 120 Watts Toaster...
Not cooking completely
replace the oven temp sensor. it looks like a probe that is in the oven, at the top
Jan 25, 2008 | Frigidaire FEF366DC Electric Kitchen Range
This is an electric convection oven
I am by no means an expert, but I believe the only thing differenty in a convection oven vs a regular oven is that there is a fan to conduct the heat quicker and more evenly. It has to do with heat tranfer rate. I can't imagine why aluminum foil would cause any problem.
Aug 21, 2007 | GE Profile JT915 Electric Single Oven
Frigidaire PLEF398AC Electric Kitchen Range Logo
505 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
