Question about Acer Aspire 9500 Notebook
Monitor Aspire 9500 doesn't work anymore
The notebook is alright; Windows starts; but I cannot see anything on the screen ... it remains black; if I take a lamp and look at the monitor, I can really see the logon mask; so I think the monitor is allright, but it seems as the power of the light showing the panel is not strong enough to brighten it out - what am I to do?
  • Acer Master
  • 4,338 Answers
You need to replace the inverter board.
Here is a tutorial for the Aspire 5100 which should be a good guide as to how to replace the inverter board on your laptop.
You can purchase it on this site:
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Feb 16, 2009
Acer aspire 5520G laptop,,the screen remains black,,starts up well just the screen remains black
Hi, this fault sounds like the screen backlight inverter has failed. There is not much detail in your question but start the laptop and watch the screen very closely. Watch for the windows logo to appear in the center of the screen. If you can see it but it is very dim then the backlight has failed. A replacement inverter is likely to cure this, it is usually mounted at the bottom of the screen assembly behind the plastic facsia. Also connect an external monitor and then try power up again. If you get a display on the external monitor then the inverter is the most likely cause. Check the connection cable as well before spending out on an inverter especially if the fault was intermittent before final failure. I will need more details to help more if this does not cure your fault.
Hope this helps
Steve at Olive Country Computers in Spain
Feb 15, 2011 | Acer Aspire 5520-5579 Notebook
Acer aspire one power button comes on but screen doesn't come on.
1/ Take a close look at the display in bright light; can you see anything there? (If so then the CCFL (or its power supply) needs replacing on the display
2/ hook up an external monitor and see if that works (or at least if the light stays green on the monitor)
3/ Any boot beep? any "Windows sound"?
4/ try removing the battery and (using only external power) see if it starts.
4/ remove the battery AND the external supply, hold the power switch in at least 30 seconds. Hoojk it up again, try it.
Oct 16, 2009 | Acer Aspire One PC Notebook
Acer Aspire 5100 laptop's screen remains black at start-up
This is probably a hardware issue with the monitor. Just to make sure, uninstall, and reinstall the monitor's driver. If that doesn't fix it, it's a hardware issue.
You will have to either take it to a shop, or contact the manufacturer (your computer should be under warranty if you've had it for less than a year).
Sep 19, 2009 | Acer Aspire 5100 Notebook
Acer aspire 5310 the screen just blank and not
Possibly the monitor is defective - usually most laptops have a blue plug at the back for an external monitor, if plugging in a normal monitor brings up a screen, then likely the laptop monitor is defective. If you get a splash screen and bios info on trying to start it,it indicates your windows is defective or has lost it's start-up files - a windows reinstall will fix that.
Aug 29, 2009 | Acer Aspire 5315 Notebook
Laptop starts to boot then screen goes black
when the windows are going in the booting and it is colored black, the problem can be wrong with the windows or set the mode dual setting LCD 1st graphic assign it, try to use external LCD Monitor or connect to back of laptop
Dec 14, 2008 | Acer Aspire 3680 Laptop
Acer Aspire 5585 Laptop LCD Problem
Have you tried booting into "Enable VGA" mode via the "Windows Advance Option" screen? By press F8 before Windows XP loading screen comes up. In this mode the Video Card drivers are disabled. So if your screen appears normal and not white in this Mode then it is your video card drivers which are causing the issue.
Aug 19, 2008 | Acer Aspire 5610-4648 Notebook
My monitor will remain black when notebook is powered up
test it with another monitor if you things then maybe the LCD has a fault.  Come back here for more instructions
Oct 15, 2007 | Acer Aspire 5100 Notebook
Acer Aspire 9500 Notebook Logo
129 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
