Question about OKI MICROLINE 320 Turbo Matrix Printer
Broken rubber track
How does one change either of the rubber studded tracks that advance the paper underneath the drum?
    Problem Solver:
  • 8 Answers
Remove the case. This is done placing the tip of a flat blade screwdriver in the the slots on the bottom front edge of the printer and prying up gently start at one side and work your way across.
With the case removed next you want to remove the Reset Spring this is the metal piece hold the gears in place on the right side of the printer.You remove it buy sliding a flat blade screwdriver under it and prying up gently.
Next remove the tractor gear buy lifting the tab up with a small flat blade screwdriver while pushing gear off. Then remove drive shaft this is the bar the tractor slide on, it will slide right out.
To remove the tractor itself slide it to the larger gap on the left hand side.
Note when installing the new tractor you must line up the timing marks. These are a small dot on the side of the tractors, make sure they are in the same position on both tractors before sliding the drive shaft back in.
The part numbers for the tractors are
53350302 for the right
53350202 for the left
Posted on Jan 15, 2009
What are the features of Alesis Nitro drum set?
The Alesis Nitro is the best-selling electronic drum kit . It is a complete 8-piece drum kit featuring tom pads, a dual-zone snare drum, cymbals, an aluminium mounting rack, and a powerful electronic drum module that gives you hundreds of percussion sounds and 60 built-in tracks.
From the last few years alesis nitro review is very good. It have a features like :
1) It had a Dynamic, comfortable pads for great feel and natural response.
2) It had a
8" high-quality rubber drum pads (dual-zone snare, three single-zone toms)
3) It had
60 built-in play-along tracks, sequencer, metronome, and performance recorder
Sep 11, 2017 | The Office Equipment & Supplies
Why does my 2006 toyota sienna power sliding door not close properly
Could be resistance in one of the tracks, or the motor.
If the motor hits a resistance the door opens in case the resistance is a human.
Jan 13, 2013 | 2006 Toyota Sienna
Samsung WF218ANW drum tilted off track
It may be a suspension spring has come off or leg has broken if it is both drums off track.
If it's just the inner drum then the bearings may have failed or the spider that the shaft is connected to may have broken.
Start with the springs at the top and suspension first.
Dec 29, 2012 | Samsung WF218ANW 4.0 cu. ft. High...
Dryer is making a"knocking" sound
drum rollers/glides:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Dec 25, 2010 | Dryers
I have a New Bright caterpillar(1985 vintage) "The Cat 245", and I am looking for the rubber tracks. The cat works, but the rubber tracks are broken. Looking for a company that makes tracks for...
I got the same problem with tracked toys. They seem to stop producing those tracks, what I did is to buy a new set of tracks from a model kit store, usually tracks from a 1/25 scale model kit battle tank. You could buy the accessory tracks from the hobby store and bring your old one to comape it.
Hope that helps you out!
Thanks for using Fixya!
Dec 17, 2010 | Toys
Need to find replacement for broken belt/track.
Belts for cleated tracks are no longer available from arctic cat. You will have to find a used belt on EBAY, at a salvage yard, or upgrade to a rubber track. An Arctic dealer can look up pieces needed to upgrade to rubber track from the old accessory parts listing to do the upgrade. You will need to replace your drive sprockets and possibly the drive axle to run a rubber track with out cleats.
Oct 24, 2010 | Interactive Toy Concepts Crossfire Arctic...
I have nuendo 3 hooked up via midi out by a m-audio 1X1 usb midi cable to a yamaha qy70. The QY70 is receiving the signal, but, everything is coming in on midi channel one. Whenever I set the drums on...
the changes which you make should be selected and set to a default mode.other wise the changes will get deselected to what it was default before automatically. in some cases its the software issue,.so reload the software again as new and check out. also check the connections its a rare chance but many times its possible,
check out.keep updated.thanks.
Jan 25, 2010 | Steinberg Nuendo 3 for PC
Kubota mini digger KX36-2: changing rubber tracks
Undo the nut the nipple fits onto ,thats the valve itself.
Then lift up the machine with the arm over the side that the tracks off  about 2 - 3 foot  so it helps the track to go in and on and start putting the track on at the sprocket end first.
When you get the track to the idler end it will push the grease out as it rolls on or you can lever it home with a big bar before tracking up .
Dec 31, 2009 | Garden
Black track on the printed papers
Bad drum
(or sometimes: a little part of a previously jammed paper that blocks access of the laser beam to the drum)
Apr 06, 2009 | Brother HL-6050DN Laser Printer
Wheel Stud
If you remove the wheel drum you can knock out the broken stud. It is pressed into the hub. Take the hub to aan auto parts store ( so you get the same size stud) and buy a new stud. put the stud into the hole in the hub. When you remount you remount the tire and tighten the lug nuts that will pull the new stud up tight in the hub.
Hope this helps
Good luck Loringh
Oct 18, 2008 | 1996 Kia Sephia
OKI MICROLINE 320 Turbo Matrix Printer Logo
383 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
