Question about OKI B8300 Laser Printer
B8300 toner error
I have just installed a new toner in my Oki B8300. Since installation, I am getting 'Change toner Error'. I have used the printers IP address to check the printer status and it states the toner is empty. Is this a toner sensor error. Is it fixable?
  • 1 more comment
  • martin ford Jun 15, 2007
    I have purchased a new toner which is working fine.
    The toner I was putting in before (when the machine was off) has been in put before, only briefly, by an OKI engineer.
    I have made a note of this. We are putting another of these on our network shortly so I will put in the toner which wouldn't work before and see if it works. If it fails I will try this fix however this fix states that the problem was due to changing the cartrdige whilst machine was on however, it wasn't on.
    Thanks.
  • Anonymous Mar 14, 2014
    oki pro 910 printer am getting a cyan toner sensor error , how could i fix this as i am in the middle of a job
  • Anonymous Mar 24, 2014
    Have an error message that printer needs to install toner?
    Scholar:
  • 77 Answers
From Oki's site: Symptom: The toner counter did not clear after installing a new toner cartridge. Cause: The printer was not powered off when the new toner cartridge was installed, Therefore the counter did not cleared. Resolution: 1. Enter the PCU Diagnostic Mode, By turning off the printer and holding down the MENU and OK buttons on power up. (Release the buttons once you're in the PCU DIAG MODE) 2. Press the MENU button 14 times until the operator panel reads " Counter Display " 3. Press the MENU button and the BACK/C button at the same time, This will put the printer into the Feed Counter Clear Mode (Release the buttons once you're in the Feed Counter Clear Mode) 4. Press the up arrow 5 times until the operator reads " Toner Counter Clear " 5. Press the OK button, The operator panel will now display " Toner no " 6. Press the up arrow once and the operator panel will display " Toner yes". Now press the OK button and the green data light will flash to indicate that the clear process is complete 7. To exit the PCU Diagnostic Mode, By turn the printer off and then back on this will allow you to exit the PCU Diagnostic Mode Hope that helps. If it does not please let me know Ed
Posted on Jun 13, 2007
  • Edward Paulinski Jun 16, 2007
    Sorry for the waste of your time and mine
    Thanks for the rating
    Ed
How do I fix the "change toner cartridge" error.
Has the cartridge got a chip? Does this chip need replacing?
Feb 11, 2015 | OKI B8300 Laser Printer
OKI C9800 CYAN TONER SENSOR ERROR
remove drum units and clean optical sensors located at the back end of he drum slots and clean corresponding reflective plates on drum units
Jul 30, 2014 | OKI C Office Equipment & Supplies
Exactly what is the error on the operator panel?
Jul 30, 2014 | Oki Electric Industry C9800 Printer
Our Oki 8300 printer has an errror code L4-02. What does this mean?
I have an error code L4-02 with Oki B8300. what is the solution?
Oct 28, 2010 | OKI B8300 Laser Printer
Toner sensor error
Hi
This error comes up when the printer detects that the toner of particular color is missing. This indicated that the indicated color toner is missing from the printer(eg-- C = Cyan, Y = Yellow, M = Magenta, K = Black).
C5150 may face a toner sensor error after installing used sets of toner cartridges and sometimes even after installing new toner cartridges as well. This error can be bypassed. This can be disabled by following these steps---
1. Turn machine on while pushing and holding the (+/-), menu buttons at same time.
2. Menu window will show OKI USER.
3. Scroll to Engine Dialog Mode is indicated Push Enter button.
4. Diagnostic Mode xx xx xx S Mode is indicated.
5. ( = 2 ) . Press (- or +) button until “ENGINE - PARAMETER SET =2” is displayed.
6. Push Enter button.
7. TONER SENSOR - ENABLE is displayed.
8. Push Enter button.
9. Press (- / +) TONER SENSOR = DISABLE is displayed.
10. Press ON LINE CANCEL buttons at same time.
11. (*) is displayed.
12. Restart the Printer.
Daniel Scott
Jun 22, 2010 | OKI C5150n Led Printer
I have attempted to install 3 different black toner cartridges in my OKI c3400. I keep getting an error: "Toner cartridge lock lever is improper, drum missing, or toner sensor error. OFFLINE." I first...
The plastic shutter in the ID is fully or partially covering the toner sensor window.
Move the cover upward to allow for the sensor to become fully exposed prior to reinstalling the drum.
0.106?openelement&fieldelemformat=gif
Mar 16, 2010 | OKI C3400n Laser Printer
I just installed a new toner cartridge. I now get
Are you sure that you removed the plastic strip that is used to ship the toner? If so unseat and re-seat the cartridge, and make sure that your installing a compatible cartridge.
Oct 06, 2009 | OKI C5150n Led Printer
OKI B8300 Call for Service error
http://www.printcopy.info/shop_e/cdrom.php?brand=OKI
Here is a link to service manuals for OKI
Feb 07, 2008 | OKI B8300 Laser Printer
OKI 9800 with "342" error code
problem might be with toner recycle coil which runs around the back of the belt unit. as the cyan unit is the furthest down the line if any blockages occur it can back up and lift the drum unit up. check the square opening of the recycle unit on the cyan end. Make sure you change waste toner unit when prompted or you might break a gear (big job) Karl Oki engineer
Aug 24, 2007 | OKI 9800hdn Laser Printer
OKI B8300 Laser Printer Logo
617 people viewed this question
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
