Question about Haier HC48C1VAR Central Air Conditioner
Central heat/air unit for home blows cold air
When I turn the unit on the heat stays on for about 3 minutes, then the cold air kicks on and stays on until I turn it off.
  • taystorm Mar 10, 2009
    Same thing. Have had to replace the central board TWICE. Units are junk!
    Scholar:
  • 80 Answers
Replace your thermastat or if it is a replacement check your wires to make sure you have them right. Refer to the instruction manual for setting the heat anticipator and the cooling anticipator!
Red to Yellow calls for cooling
Red to White is usually calling for heat
Red to Green calls the Indoor Fan
Red to Orange is the call to a reversing valve on heat pump units!
Posted on Aug 22, 2010
    Problem Solver:
  • 16 Answers
Could just be heat trapped in ductwork for attic temp or from not running for more than a few hours.
Posted on Aug 12, 2009
Amana Wall unit blows cold air before heating
the unit works by chilling air and the byproduct is heat in the compressor, this is used for heating in the winter and then reversed in summer to blow cold air. It has to blow cold and warm up before it can blow heat.
Mar 17, 2017 | Amana Heating & Cooling
Central heat not blow hot air
you posted in november if it was very cold auxillary heat issue.
Nov 11, 2013 | Goodman Heating & Cooling
Inside fan turns on when outside unit is in defrost mode when heat is selected. This causes it to blow cold air for about 10 to 15 minutes prior to the outside fan starting.
The inside fan will run while the unit is in defrost. The electric heat strips should kick on to help prevent you from feeling this cold air. When the unit is in defrost it is essentially running in the A/C mode. You should make sure the electric heat elements are working then go from there.
Dec 11, 2010 | Goodman PHKJ048-1 Air Conditioner
Goodman central air conditioner not blowing normally
It sounds like the compressor is not coming on in the outside unit. If it worked fine and was cooling before, then your compressor probably over-heated and tripped the internal overload switch which causes it to stay off while everything else is working. The most common cause of your compressor over heating is an incorrect refrigerant charge, though it could be a few other things like a restriction in the copper line set. You will be able to hear the fan motor and the compressor kick on if you listen close while the system first turns on. If the compressor is over-heated, then after it cools to a save temperature, it will come on again, but only till it over-heats again. I would have the charge checked on the system, but remember that if the compressor is over-heated when the technician gets there, there is nothing he can do until it cools down and time is money! It's best to not run it until the problem gets figured out. Hope this helps and points you in the right direction. Good luck!
Jul 17, 2010 | Heating & Cooling
Heating unit blows warm air then turns to cold air
it sounds like unit could be kicking out the low pressure switch or if it is a electric furnace it could be the sequincers
Jan 11, 2010 | Ruud UBHC Air Conditioner
Will not blow cold air
pls check your remote setting
Apr 27, 2009 | Heating & Cooling
I have central air and heat(the unit is about 8 yrs old)..when my heat kicks off there is still extremly cold air continually coming through the vents as if there is still a fan going,but it's not from the...
Does it look like a box with four flex ducts or pipes coming off of it? if so its a fresh air/ heat recovery ventilator, supposed to bring in fresh air, keep in mind, the outdoor unit does not bring in air, it is just a pump to the indoor unit. that unit may be running independently, or wired incorrectly
Jan 17, 2009 | Fantech AEV1000 Air Exchanger 120 cfm
Arcoair central heat /air conditioning unit
The blower motor kicks on when there has been a 24 volt control failure.
This usually means that a limit switch has tripped.
Most likely that would be a high temp limit switch or a rollout switch.
First, make sure the filters are clean. and the evap coil is clean. If eaither are dirty/clogged, it will partially block airflow, causing the furnace to overheat, causing the high temp limit to trip.
A rollout switch typically trips for three reasons.
1 flame rollout into the burner compartment due to poor airflow.
2 overheating af teh metal plate the rollout is mounted to, due to dirty, old, rusted components.
3 a bad limit switch.
If your unit has an LED light, count the flashes and it will hepl popint out the problem.
(locate the wiring diagram/flash code list, and correspond the flash count, with the code.)
First, check filters.
Jan 14, 2009 | Heating & Cooling
sounds like your drain is stop up in wich is filling your air swich up with water the causes a miss fire the indoor motor will run untill you turn it off when this happens
Jan 13, 2009 | Omega Trane Furnace Draft Inducer Blower...
Haier HC48C1VAR Central Air Conditioner Logo
239 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
