Question about Canon PIXMA MP160 All-In-One InkJet Printer
I9900 printer has error 5B00 & won't print
Printer error 5B00 ink absorber pad is full....help!
  • Canon Master
  • 4,338 Answers
You may need to change the ink absorbers. But try resetting the printer:
Canon I series service mode
1. Start with printer OFF
2. Hold down RESUME and then press and hold down POWER Button.
3. Release the RESUME but continue to hold down the power button
4. Press the RESUME twice, then release POWER button.
Now you have put the printer in Service Mode so it will accept Service commands. Here is the list of Service commands;
A. Press the Resume button once = Print Service test print
B. Press the Resume button twice = Print EEprom data sheet
C. Press the Resume button Three = Initialize the EEprom
D. Press the Resume button Four = Clear Waste INk Counter
E. Press the Resume button Five = Change Destination settings
F. Press the Resume button Six = Head Refreshing (Cleaning)
G. Press the Resume buttom Seven, Eight, Nine, = Not used
H. Press the Resume button Ten = Return to selection Menu
To EXECUTE anyone of the above commands you "MUST Press the Power button one time. Then the function will be executed. After that function has been executed the printer will REMAIN in Service Mode,.. waiting for another command. You can only execute one command at a time. If you are through with all the commands you want to do, just press the power buttom one more time and it will turn the printer off and you will be out of Service Mode. One more note. When you get the printer into Service MOde and it is ready to accept a command, the green light will be on and steady. As you issue a command by pressing the resume button, it will alternate the color from green to orange with each press of the resume button. Remember, if you issue either one of the commands to force a print make sure you have paper installed.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Jan 14, 2009
How to Use CannonCopier
ink pad absorber most likely full
http://www.en.rellenadodecartuchos.com/2014/05/how-to-get-rid-of-5b00-error-message-on-canon-printers.html
not 100 percent certain as you did not mention the make and model number I am assuming you have a multifunction printer with ink jet printing ??? ????????
Mar 22, 2016 | Office Equipment & Supplies
How to reset canon pixma MX338 printer error code 5B00...need solution URGENT....PLEASEE HELP
The waste ink absorber is full and is triggering error 5B00. To reset the error you need to replace the ink absorber. You may find a cheaper ink absorber kit on Ebay or Amazon.
Feb 03, 2011 | Canon PIXMA MX300 All-in-One Printer
Won't print error message 5b00 on screen. How can
5B00 is the waste ink absorber full message, only a Canon repair shop can reset the error code.
Jul 27, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Canon i9900- absorber pad full - How do I replace ??? I Thank-You, in advance for your Time, Courtesy, and Help !!! Best Regards, Alton Davis P.O. Box 6 Centre, AL 35960 Toll Free 877-446-0393 email:...
The pads are on the very bottom under the printer engine, after removing all the upper covers there are 6 screws holding the print engine in place, and the cable from the power supply must be removed. After changing though, you must enter diagnostic mode to reset the counter for the ink absorbers.
Jun 20, 2009 | Canon i9900 InkJet Photo Printer
I keep getting mssg : check printer error 5B00. i found the answer to this, its about ink or something. after i clean the pad, and i connect the printer again, but i still get the same problems..... some...
Hi guys, Error code 5B00 indicates absorber full error. To fix this problem you need to reset waste absorber counter and replace waste ink absorber. Unfortunately you don't write the printer model so I cannot write reset procedure here.
Jun 05, 2009 | Canon PIXMA MX310 All-In-One Printer
Indicates waste ink absorber is almost full on cannon i9900 print
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink full" error.
The waste ink absorption pads cannot be emptied, only replaced.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you. Once they are replaced, it'll be functional again.
May 16, 2009 | Canon i9900 InkJet Photo Printer
Check printer 5B00
Hi guys,
Dec 25, 2008 | Office Equipment & Supplies
Waste ink tank full..error 5B00
Normal 0 false false false MicrosoftInternetExplorer4 st1:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Waste PAD ink Reseterfor Canon Pixma iP6320D
You need to Remove the ink Cartridge first in order for the code to take effect.
1) Closethe print head cover.
2) While pressing the Stop/Reset button, press the Power button. (Do not release the buttons. TheLED lights in green to indicate that a function is selectable.)
4) While holding the Power button, release the Stop/Reset button. (Do notrelease the Power button.)
5) While holding the Power button, press the Stop/Reset button 2 times,(Canon idle will appear)and then release the Power and Stop/Reset buttons.(Each time the Stop/Reset button is pressed, the LED lights alternately ineither orange or green, starting with 0.
6) When the LED stops blinking and lights in green, press the Stop/Resetbutton 4 times. (Each time the Stop/Reset button is pressed, the LEDlights alternately in either orange or green, starting with orange.)
7) Press the Power button 2 times. ( the '' Canon" appear twice).The LED lights in green, and the selectedfunction is performed. (When the operation completes, the printer returns tothe menu selection mode automatically.)
8) Power off then back on and test.
9) Congrats!!
Prepared By Jeffrey Vicada (EDS- Technical Engineer) Philippines
Dec 03, 2007 | Canon Pixma iP6210D InkJet Photo Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
167 people viewed this question
old marine
old marine
