Question about Microwave Ovens
Bulb blown in microwave
Hi, i have got a toshiba er6860w microwave and the light bulb has just blown. can you tell me how to change the bulb and are the bulbs readyly available .
thank you
john
  • 25 Answers
Yes you can get them. Need to remove it first to find out what type it is. If it does not have a access door you have to remove the cover.
Posted on Jan 14, 2009
How to change light globe in microwave
EVER HEARD OF GOOGLE????
LG LMVM1935 manual
Google
That gets you to the manual.
Page 3 is the table of contents that lists oven light replacement on page 29.
Just maybe, if I teach you this you'll be able to do it yourself next time!
Sep 21, 2016 | LG LMVM1935 Convection/Microwave Oven
The microwave is working, but the light doesn't come on. can it be changed if blown?
yes. bulbs of microwave can be replaced.
Mention your brand/model/size and someone can help identify the right bulb and procedure to replace yourself.
See below an example Microwave Repair Replacing the Internal Light Bulb 40W Whirlpool Part...
Apr 15, 2016 | Microwave Ovens
General Electric Spacesaver II JEM31E001 microwave light bulb....Burned out. removed outer side panel door and removed burned out bulb and can't find replacement can you advise. Is it safe to use the...
These are very standard appliance globes and your local hardware store can tell you which one if you take the blown one with you.
But if you want to order one you can do so from this online site.
Aug 19, 2014 | Microwave Ovens
Ge wes1450ds1bb lightbulb stopped working
You usually have to take the cabinet top off to access the bulb. There will be screws all sides to take off before it will slide off.
Mar 02, 2014 | Microwave Ovens
I went to change a light bulb, light bulb pulled out of threads. Tried to remove threads and without turning power off and shorted something out. Underneath lights and fan will not work. The microwave...
I would say you have blown a fuse on the unit. As you now have found out, that's one of the reasons why you unplug any electrical equipment before working on them. You will have to take the outer cover off the microwave and locate where the fuse is. It is most likely on the back of the main PCB or possibly inside a plastic sleeve or mounting near where the cord enters the unit.
Feb 22, 2014 | GE JVM1440 Microwave Oven
Light doesn't go off and microwave doesn't work
follow this steps and fix it. God bless you
  1. Inspect the power cordUnplug the power cord and check for voltage at the outlet. Also inspect for damage, shorts, or burn marks that can be a possible safety hazard.
  2. Bad door switchIf your microwave does not work at all and you know everything is plugged in properly and the outlet is functioning, then also check the door hooks and the door release button. Using a volt-ohm meter on RX1, check your terminals. When your microwave door is closed you should have a reading of zero. Once the door is open the reading should change to infinity. If these readings do not match up, replacement of the door switch is necessary.
  3. Blown fusesTo determine if your fuse has blown out, which may attribute to your microwave not running, you need to pull the fuse out using a pair of fuse pullers. Lay it down and using a volt-ohm meter on RX1, check both ends of the fuse in question. If you do not get a reading of zero, then you will need to replace the fuse.
  4. Bad fan motorLocate the fan and remove the leads. Again using the volt-ohm meter on RX1, check the terminals. If an infinity reading is displayed, it means that the fan has gone bad and requires replacement.
  1. Light bulbIf your microwave light bulb is not working, perhaps it has blown. The first step is to replace the bulb and power on the microwave. If this does not correct the issue, the next step is to check the socket and wiring to verify if that is the problem.
  2. Light bulb socket & main control boardIf your microwave light bulb is not working after the installation of a new bulb, check the light socket as well as the wiring to ensure they are properly operating. If these sources are functioning properly, the next step is to check for a faulty control board as a possible root cause to your microwave light bulb malfunction.
Nov 14, 2013 | Sharp R305KS Microwave Oven
Bulb blown on Russell Hobbs CJ/AL28 microwave
Just open the top cover and find the location of the bulb , it may be in the right side near the control panel. Remove the bulb and get a similar bulb with the same rating from any electrical shop and fix it
May 25, 2009 | Microwave Ovens
Goldstar MIcrowave stopped working when light bulb blew out.
when that happen to me i change the bulb and the fuse in of the microwave f the don't work send it to the company that made it and they should tell what wrong.
Mar 11, 2009 | Goldstar MV-1501 Microwave Oven
Chaning light bulb in microwave oven
If there is no door over the bulb that can be removed by a screw or otherwise, then the cover has to be removed. DANGER!!! ALWAYS UN-PLUG BEFORE ATTEMPTING REPAIRS!!
Feb 02, 2008 | Microwave Ovens
After changing a blown oven light, the clock works but nothing else turns on, including the fan, light, microwave
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, linked here on Fixya:
http://tinyurl.com/yzjozk
Nov 27, 2007 | Whirlpool MH7135XE Microwave Oven
Microwave Ovens Logo
156 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
