Question about Magic Chef CES3760 Electric Kitchen Range
REPLACEMENT COST OF MAGIC CHEF ELECTRIC RANGE MODEL 6898XVB
I HAVE BEEN LIVING IN MY HOUSE FOR 8 YEARS, THE ELECTRIC RANGE THAT WAS IN THE HOUSE WHEN WE BOUGHT IT IS A MAGIC CHEF MODEL# 6898XVB, I NEED TO REPLACE IT BECAUSE OF A SMALL ELECTRICAL FIRE IN THE COIL, I AM LOOKING FOR A COMPARABLE REPLACEMENT FOR INSURANCE PURPOSES,
    Genius:
  • 2,920 Answers
You should be able to buy one for between 400 to 600 dollars new.i would check lowes or home depot to see what they have in stock.
Posted on Jan 13, 2009
Where would I look to get replacement broiler element for an electric Magic Chef Chateau over and under oven model 251v-2cw. It's in great shape other than just blowing this element.
Is the model number listed 251v-2CW that of the Oven or the part # of the element? That number is not showing up as either as a proper model #. Can you double check the Oven's Model # and list the Serial Number as well?
Dec 27, 2010 | Magic Chef 31000 Gas Kitchen Range
Code F-3 or F-5 appears when oven heats
this is usually a temp sensor probe problem.check you wiring between the probe and the electronic control board. at room tempt check the resistance on the probe if it less than 500 ohms replace the probe.
Feb 23, 2010 | Magic Chef 9512 Electric Single Oven
F-7 and beeping is occurring on my Magic Chef,
Hi sixgunromeo,
The error code F7 means that the Function key is shorted or stuck. TO fix this error, replace touch pad or if touch pad is part of the clock, replace the clock (ERC).
Hope it helps.
Thank you for using FixYa.
Dec 05, 2009 | Magic Chef 31000 Gas Kitchen Range
Broken glass in oven door
The inner glass panels are still available and replaceable.
Cost about $45.00
Mar 08, 2009 | Magic Chef CER3725AA Electric Kitchen...
Microwave not heating up food
This model is a lower-end type that probably didn't cost very much. Since it's over 2 years old, you have no warranty left. Most appliance repair shops charge extra $$ for servicing installed items in the home. You'd probably be better off purchasing a new comparable model. The labor fee alone might equal what you paid for it.
Jan 08, 2009 | Magic Chef Microwave Ovens
Broken glass top on Magic Chef range
all i want to know is how to turn on the self cleaning oven to clean it. i can't remember and i can't find the book
Jul 25, 2008 | Magic Chef CER3740 Electric Kitchen Range
Magic chef range
if you give me a model number i be might be able to help try here get your model number off the serial plate from the range http://www.maytag.com/support/manuals_literature.jsp if that dont work reply to this thread with model number
Jan 15, 2008 | Kitchen Ranges
MAYTAG MAGIC CHEF SELF CLEANING GAS RANGE
Here are the codes for magic chef:
F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board F2 Oven too hot Check oven temperature sensor F3 F4 Open or shorted oven temperature sensor Replace F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Replace clock assembly (also called the ERC) F7 Function key shorted Replace touch pad F8 Analog/Digital converter Replace clock assembly (also called the ERC) F9 Door latch Check door lock circuit F10 Function key stuck Replace touch pad
Nov 18, 2007 | Maytag MGR5751AD Gas Kitchen Range
Magic Chef CES3760 Electric Kitchen Range Logo
297 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Dan Webster
Dan Webster
Mike Carew
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
