Question about Sony Grand WEGA KDF-60XBR950 60" Rear Projection HDTV
A blue light on the bottom of the screen
In the left hand corner a blue light is showing on the screen. It is about 12 inches long and about 5 inches high. I tried to adjust the color setting but the light is still there.
  • Anonymous Mar 31, 2014
    you can see through it but it changes color off and on to stripes
  • 934 Answers
Color distoritions on DLP based rear projection tvs like this are either produced by the video board or light engine itself.. I'd like to qualify that by saying unless there are no other symptoms, however slight. These are clearly a set of symptoms that you need to take to a qualified shop though. They can perform a number of tests on the board and light engine based on the service manual for that unit. It is clearly NOT the kind of repair you want to take the shotgun approach to repairing. The light engine in this unit, for example, is Sony p/n#A-1606-039-A and cost roughly $900.00 plus a $500.00 core plus shipping. Not for the weekend backyard tech. The upside is it's possible that this is something that can be repaired at component level. And please don't kill the messenger. Although the solution may not be what you wanted to hear it is based on more than 20+ years as a certified technician. As a few noteworthy tips: (1) Take the unit into the shop you choose, don't have them charging you for pickup and delivery. (2) Always find out the cost of an estimate before you take it in and when you take it in get the estimate first before authorizing repair. (3) Find a reputable shop. Like going to the AMA to locate a doctor don't hesitate to contact NESDA to find a reputable tech. http://www.nesda.com/locator/state_search.php Good luck. Bill
Posted on Jun 12, 2007
How to turn off monitor
1. Go to the desktop
2. Right Click
3. On that list, you should click personalize
4. In the lower right hand corner, click Screen saver (It's in blue letters)
5. In the bottom left hand corner of the window that just popped up, click "Change power settings"
6. In the left side of the new window, (It's in the light gray area) click on "Change when the computer sleeps"
7. Then from here you can set when you want to turn off the display and or put the computer to sleep after how long you have been inactive.
8. Remember to click the "Save changes" button to save what you've done.
May 25, 2014 | Total Gym Cyclo Trainer
How to wire trailer plug
hope this helps
6 pin socket
6 pin plug
7 pin socket
7 pin plug
5 pin socket
5 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
7 pin socket
7 pin plug
12 pin socket
12 pin plug
small 6 pin round plug & socket
1 tail, clearance - brown
2 left hand turn - yellow
3 right hand turn - green
4 stop - red
5 electric brakes - blue
6 earth - white
small 7 pin round plug & socket
1 left hand turn - yellow
2 reverse - black
3 earth - white
4 right hand turn - green
6 stop - red
7 tail, clearance, side markers - brown
roundskt.jpg round socket
large 5 pin round plug & socket
3 earth - white
5 right hand turn - green
6 stop - red
large 7 pin round plug & socket
2 reverse - black
3 earth - white
6 stop - red
7 pin round heavy duty plug & socket
1 earth - white
2 left hand rear , clearance and marker - black
3 left hand turn - yellow
4 stop - red
6 right hand rear , clearance and marker - brown
7 reverse/auxilary - blue
7 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
7_flatsocket.jpg flat socket
12 pin flat plug & socket
2 reverse - black
3 earth - white
6 stop - red
8 battery supply - orange
9 auxiliaries - pink
10 earth - white
11 rear fog lamp - grey
12 auxiliaries - violet
Feb 02, 2013 | 2004 Toyota RAV4
I need the USB firmware update utility for a JVC LT-32P679 TV.
my tv won't show a picture the blue light on the bottom left hand corner just keeps blinking
Apr 05, 2011 | JVC Televison & Video
My PT-44LCX65 has been showing numerous color spots recently. In August, I noticed a dark green spot in the top left corner, and also a less visible maroon spot near the center. Today (12/16/2010) I'm...
THAT IS GOING TO MOST LIKELY BE A PROBLEM WITH THE OPTICAL ENGINE AND PANASONIC HAD SEVERAL MODELS THAT HAD PROBLEMS WITH EEPROM CORRUPTION THERE WAS A RECALL TYPE OF EXTENDED WARRANTY I SUGGEST CALLING PANASONIC THEY WILL SEND SOMEONE OUT TO FIX IT MOST LIKELY FREE OF CHARGE :)
Dec 17, 2010 | Panasonic PT-52LCX65 44" HDTV
The lower left hand corner of the screen is turning blue
catually is problum is related with blue lcd & blue polizer but first you clean the optical unit if the problum gon then ok other wise must chang blue lcd & blue polorize with uv filter plese contect to your nearst sony service centre
Feb 05, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Screen appears blue
Try Moving The Speaker You Have There Away From It?
www.Myspace.com/CrossRoadsToNowhere2007
Jan 05, 2009 | Sony KDF-E55A20 55 in. LCD Television
Tv shows blue screen
my tv screen is blue and has a red key at the bottom left hand corner
Oct 04, 2008 | Apex Digital AT2002S 20" TV
When takining photos all the shot recently appear with a blue tinge. Before taking a photo, the screen displays the following; 'P' left hand top right corner. light bulb left hand side and along the bottom...
You are in Program mode most likely, with some sort of white balance setting that is not sunlight. Go into menu and try to change back to auto mode,or reset all or default. Sometimes removing the battery for 12 hours gets it back into default mode. the HQ is just the resolution that it is shooting in.
Apr 22, 2008 | Cameras
Blue/green line left side of the screen top to bottom
I have a green line on the left side of my laptop, can you tell me what is that?
Mar 26, 2008 | Televison & Video
RCA HDLP50W151 50 in,, got blue line on left part of screen
If you have a DIRECTV - push the reset on the Directv receiver.
JB
Jan 08, 2008 | RCA HDLP50W151 50" Rear Projection HDTV
Sony Grand WEGA KDF-60XBR950 60" Rear Projection HDTV Logo
270 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
